Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-08-2005, 08:13 PM   #1
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Default hydra q
Under settings/isc/pwm isc valve, what are your numbers for min and max pwm duty. Thanks
rjrutzky is offline   Reply With Quote
Old 10-09-2005, 12:06 PM   #2
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Didn't Elementuning provide you with a base map with those already set?
DarthChicken is offline   Reply With Quote
Old 10-09-2005, 02:44 PM   #3
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
yes, but it doesn't seem to be working properly. if you want to keep your numbers secret I understand
Old 10-09-2005, 03:26 PM   #4
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
On my car, I use 17.2 and 88.4... no secrets here, I was just curious if you had a base map from Phil, because if you didn't there might be something else wrong, thats all.
When you say its not working properly, what are you seeing? Stalling, or reving too high on startup, or something along those lines, or something else?
Old 10-09-2005, 06:02 PM   #5
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Yeah, I'm just stressing, because this is a new V7 motor swap that I wired for AVCS myself, so there could be a million different things going on. Mine was alot higher than 17.2 on my base map, making the iac really open up. I just wanted to make sure I didn't have another prob like you said. I thought my IAC might be bad and I didn't want to make tuning corrections to fix a faulty part. Thanks for the numbers Darth
Old 10-09-2005, 06:15 PM   #6
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
FWIW, mine is currently set to 20 and 90, but that is on a '99 2.5RS, so your mileage may vary.
Shane
Warp3 is offline   Reply With Quote
Old 10-09-2005, 08:52 PM   #7
bboy
Member#: 56468
04 Improved STI
Dirty White
20 and 84.4
max vacuum 609
Old 10-09-2005, 09:06 PM   #8
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I've seen a few problems with the ISC valves on a couple of car I've tuned. One had the ISC valve gasket/o-ring installed out of its grove. This air leak required me to run 4 as the min duty but once fixed we increased the min pwm duty to 18.
On another car it just needed to be cleaned but this also had me using 8 to idle the car low enough.
On my own personal car I had the tan and black one-way valve attached to the fuel tank purge control solenoid valve go bad. Since my car was already tuned I new it was something mechanical. Sure enough the valve was damaged and leaking so I tossed it in the garbage and just eliminated the purge since I'm not sure those valves are reliable at 30+ psi.
One other thing to check is the max vacuum. I'm tuning a car currently that had a vacuum leak which I didn't know about so in the end the Max Vacuum was set to close to the idle vacuum resulting in a high idle after the vacuum leak was fixed. Raising the Max Vacuum to 610 mm/hg and normal idle returned.
Thanks,
Phil
(240)246.0302
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
2004 Sti Hydra EMS II 2.6 ECU SOLD tolishel Engine/Power/Exhaust 8 07-07-2010 04:50 PM
FS - Harness for Hydra (fits 05-06 Sti) 05pearl Engine/Power/Exhaust 2 06-16-2010 02:15 PM
Hydra with Hydra mist only? BuggeyEYED Water/Methanol Injection, Nitrous & Intercooler Cooling 10 03-27-2008 11:32 AM
Hydra- Fuel pump wont turn off when hydra is powered up...whats the cause? White 2.5rs Other Engine Management 9 10-17-2006 09:06 PM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
