Old 10-09-2005, 03:00 PM   #1
rbmour
Member#: 45225
2003 wrx
pearl blue
Default exact ap procedure for ap after v34 install?
I again, for those who saw the other post, installed v34, pinks, ap, dp, up and fp to my 03 wrx yesterday,
got it narrowned down, its got to be something im doing wrong with the ap.
I did not "unmarry" and how do you do this, the ap from the car before i 1) installed/downloaded new software on computer from cobb tuning. 2) downloaded v34 map from ap maps (not street tuner, because that wouldnt have worked, thats different right) picked 03 v34 93 octane map, reflashed base map on car, runs like garbadge. 300 301 codes, flashing ecu, overheating, really quick and cooling down really quick.
any ideas?
Thanks, Ryan
rbmour is offline   Reply With Quote
Old 10-09-2005, 03:39 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Did you disconnect the init and test connectors after flashing your basemap?
mcowger is offline   Reply With Quote
Old 10-09-2005, 03:53 PM   #3
23b_Rex
Member#: 79394
02 gda
wrb
^ i'm pretty sure he did or else the cel would just be flashing and it'd say "no codes found"
you did connect the green connectors and the blue connector when flashing your base map right?
23b_Rex is offline   Reply With Quote
Old 10-09-2005, 05:25 PM   #4
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Engine management forum...
Try and keep your problem confined to one thread so that we can see all the info and help you better.
Agkelos is offline   Reply With Quote
Old 10-09-2005, 05:49 PM   #5
rbmour
Member#: 45225
2003 wrx
pearl blue
sorry about the forum mixup.
yes, i disconnected the plugs.
i thought i heard you have to unmarry the ap before the flash,
is this true and what would happen if you didn't?
RYan
Old 10-09-2005, 06:41 PM   #6
hondaeater69
Member#: 60324
This happened to me once, i'm not sure what caused it. I reflashed the base map again, and it went away. It was weird, my car started then died, threw about 10 different DTC's, i thought my ECU was fukked, but it was fine after i flashed the same map again. . .go try a reflash. You may want to DL the file again, and try putting it in a different "slot' on the ap. report back after you try this.
To answer you Q, yo uare supposed unmarry the AP before upgrading the SW, but it's not technically required. I have successfully upgraded an AP without unmarrying it. ..
Old 10-09-2005, 08:19 PM   #7
JRSCCivic98
Member#: 67080
You don't have to unmarry anything.
1) Download the latest Map Manager software from Cobb's Site. http://www.accessecu.com/support/apmm_v1.63.exe
2) Uninstall the old version and then install this version.
3) Download the latest v1.30 map for VF34. Pick one of the following for either 93 octane or 91 octane.
93 - http://www.cobbtuning.com/wrx/access...2093%20oct.ptb
91 - http://www.cobbtuning.com/wrx/access...2091%20oct.ptb
4) Download the map to your AP.
5) Go to car and turn off all your accessories (lights, radio, dome light, air, etc.)
6) Connect the green connectors under the dash and the white flashing connector.
7) Plug in your AP to car.
8) Pick the VF34 map to flash and then turn the key to the ON position and hit flash button.
9) Wait for the thing to finish.
10) Turn key to OFF position, unplug the AP from car, unplug flash connector and unplug the green connectors.
11) Start the car and enjoy.
JRSCCivic98 is offline   Reply With Quote
Old 10-09-2005, 10:36 PM   #8
rbmour
Member#: 45225
2003 wrx
pearl blue
Default thanks
thank you all so much
this helped.
i appriciate it.
Ryan
p,s. i just got back from my taking another stab at working on the ca
reflashed base map, same probs, ill try reduing the software.
Thanks
after v34 install misfiring cyl 1, can you buy... rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-11-2005 01:11 AM
when do i do oil change after v34 install exactly? rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-01-2005 08:59 AM
Use for hoodscoop after FMIC install. 2phless Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 61 06-06-2005 05:04 PM
Alignment for Wheels after spring install Tricky_D Brakes, Steering & Suspension 4 05-26-2005 06:38 PM
AP still ECU specific after ST install? hondaeater69 Engine Management & Tuning 2 04-24-2005 04:17 PM
