#1 |
Member#: 97988
Vehicle:2006 WRX STI Aspen White |
I am interested in installing a set of defi BF guages on my 2005 STI. i know they are a bit pricey but from when i hear they are pretty sick guages and are a great match for my OEM guage cluster. I was wondering if anyone installed a set of three of these guages and control unit in their STI (more specifically Boost, EGT and Oil pressure.) and about how much i would pay on average for install.
Also i an debating installing the guages on the A pillar versus the tripple hood style mount over the deck. If anyone has pictures they would be greately appreciated.
#2 |
Member#: 45758
Vehicle:2004 STi silver |
I'm about to install my Defi Boost, EGT, and Oil Pressure gauges probably sometime next weekend or even tomorrow. I'll let you know how it goes. jsalicru posted instructions that are quite detailed; here's the link:
http://homepage.mac.com/jsalicru/GaugesHowTo.html As far as the price goes for having someone else install them, I'm not sure. I usually prefer to do all modifications myself if I have the tools and time. Good luck; I'll keep you posted. -Tony |
#3 |
Member#: 97988
sounds good tony. yeah i was contemplating instaling them myself but i have never worked with my subaru (or with any subaru for that matter) before. I figured i would do up some nice gauges before i tampered with the turbo.
thx for the link and lemme know how the diy install goes. i may just end up putting em in myself. -anthony |
#4 |
Member#: 45758
Ok so here's the verdict...I'm almost done with the installation; things went well until I went to install the oil pressure sensor. I used the information that jsalicru provided, but was unable to find the subaru part # for the adaptor. I need to get the adaptor before I can install the oil pressure sensor. If you have any questions with anything else along the lines of the installation, let me know.
-Tony EDIT: found the part #'s, here they are... For the adaptor (Main Galley Plug): 11024AA210 For the gasket needed: 037018200 Go to www.subaruparts.com if you want; they have the parts listed there. Good luck. Last edited by STiLIN04; 10-15-2005 at 12:23 AM. |
#5 |
Member#: 11571
NESIC
Vehicle:'08 BMW 135i F/A-18C |
I did the install myself. Except I had an oil temp gauge so I used an oil filter sandwich adapter.
And luckily, my stereo harness had all the wires marked, so that made the wiring a snap |
#6 |
Member#: 97988
Thanks for the part numbers tony. I will hopefuly be installing my kit this weekend. Say a prayer for me im hoping my first mod goes off without a hitch. Thanks again.
- Anthony |
#7 |
Member#: 97350
Vehicle:'08 STI DGM |
Good luck on the install. Let us know how it goes. This will hopefully be one of my weekend projects soon.
#8 |
Member#: 45758
Installation complete!
It was quite easy with the directions I used from jaslicru. Yesterday I got the oil gallery plug and the crush washer that goes with it. Today it took all of 25 minutes to install the oil pressure sensor. The majority of the time was spent working the threads into place in the tight space provided. It is absolutely necessary to buy a 17mm crowfoot in order to crank down the oil pressure sensor. First I connected the sensor to the gallery plug, using thread locker 3/4 of the way around the threads. Then I went ahead and hand-tightened the sensor/gallery plug combo to the block. Don't forget the crush washer! I put a little thread locker on it just to tack it to the gallery plug while I lowered it down to the hole in the block. It was almost impossible to get in there. After I got it down as tight as I could with my two fingers, I used the crowfoot to tighten it. It helps to take a piece of paper and wedge it between the extension bar and the crowfoot to hold it in place. I then reinstalled the IC and tightened all the hoses etc. and started it up. No oil leaks, so I'm good to go. Any more questions, feel free to ask. -Tony |
#9 |
Member#: 97988
sounds good tony. Thanks for the heads up on the parts you purchased. hopefully I will be getting around to my install this weekend. If I have any troubles i will be sure to hit you up with some questions!
#10 |
Member#: 70027
Vehicle:2004 WRX STi Platinum Silver |
Can you show with some pics exactally where the gallery plug goes into? I know as you mentioned that it is located under the intercooler. Thanks in advance!
#11 |
Member#: 45758
http://www.scoobymods.com/forums/sho...9258#post19258
The pictures show the location of the plug pretty well. -Tony |
#12 |
Member#: 70027
Thanks for the info, never thought of checking scoobymods...Nice some pics, FIMIC is on so install we go quick. Thanks again!
| Thread Tools | |
| Display Modes | |
| STI genome controller with Defi BF guages? | freshjive959 | Interior & Exterior Modification | 6 | 07-09-2007 02:58 PM |
| Install new brake pad on my 2005 sti | narathip | Brakes, Steering & Suspension | 2 | 04-29-2007 10:36 AM |
| Defi BF guages and guage pod | ckanderson | Interior/Dressup/Audio & Security | 9 | 09-21-2006 01:34 PM |
| Defi BF guages only on w/parking lights | damn_4eat | Electrical & Lighting | 6 | 04-12-2004 10:59 PM |
| Defi Bf Guages Very Good Deal | wickedbluwrx | Tri-State Area Forum | 8 | 08-04-2003 09:02 AM |
