Old 10-09-2005, 05:58 PM   #1
mybluesubi
Member#: 53526
1997 Impreza
black
Default Ihi Rhb525 Vi55
I just bought a turbo on ebay and would like to get some more info on it but can't seem to find much, even on IHI's site. What is this turbo capable of and will it work on an EJ22? Was it worth the 165 with shipping I paid? Should I get a bigger one or another one and twin turbo it? The inlet on it is pretty small and I'm not sure if that's an issue when it comes to air flow. Any help or advise is greatly appreciated.
mybluesubi is offline   Reply With Quote
Old 10-09-2005, 06:11 PM   #2
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Subaru Stars
post picture of it please, i know the rhb52 or vf 11 came on the ej22t. just not familiar with the other numbers, i will be able to tell you if i see it.
Kawikid20o2 is offline   Reply With Quote
Old 10-09-2005, 06:14 PM   #3
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Hmmmm... not too sure about the ole e-bay turbo's...
Do you have all the piping etc. for a turbo on your car, or do you just have to turbo itself? Is the engine just an EJ22, or is it EJ22T?
Did you already recieve the turbo, or did you just win the bid, or buynow?
Sko is offline   Reply With Quote
Old 10-09-2005, 06:25 PM   #4
mybluesubi
Member#: 53526
1997 Impreza
black
I have the turbo sitting in front of me but the only camera I have is on phone and we all know they don't take good pics. I'll take a few and put them on my cardomain site since I don't have one of my own. The engine is an EJ22 no T. I have an intercooler on it's way and as far as the piping goes I don't have any of it. I do have a BOV and boost controller. I'm still deciding on which turbo timer to get. The exhaust is going to be done by an exhaust shop since I really don't wanna get into changing the front engine cross member and pay out the a$$ for a new header. I'm not looking to spend a lot on this project I just wanna be able to climb up a mountain in 5th at 250+ feet per minute at 75-80 without having to dump it into 4th gear. I do live at near 7000 ft and most of my driving is at this elevation or higher. The lowest elevation I drive at is about 4400 ft and that's in SLC Utah. I guess what I'm really needin to know is if this turbo will boost to 6-7 psi without problems.
Old 10-09-2005, 06:28 PM   #5
mybluesubi
Member#: 53526
1997 Impreza
black
Guess I forgot to add, this is what the turbo says on it exactly, TurboSpec VI55 9302, Serial No RHB525 029A, Parts No 8 94400 191 2
Old 10-09-2005, 06:53 PM   #6
mybluesubi
Member#: 53526
1997 Impreza
black
As you will be able to tell the turbo is brand new not rebuilt never used. The site is http://www.cardomain.com/ride/725841
Old 10-09-2005, 07:27 PM   #7
25rsESP
Member#: 56985
2006 WRX Wagon
wow im suprised you say you need more power... with those underbody neons on there you should go plenty fast enough.
25rsESP is offline   Reply With Quote
Old 10-09-2005, 07:46 PM   #8
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Subaru Stars
wrong flanges for subaru uppipe and down pipe, regular rhb52 would work but this is different. And twin turbo is a biotch.
Old 10-09-2005, 09:31 PM   #9
mybluesubi
Member#: 53526
1997 Impreza
black
I'm not worried about the flanges cause I will buy the ones I need and have them welded on when the exhaust is done. There isn't an up pipe that will bolt right on to the header that's on there now. I'm also gonna havta have a downpipe made cause I'm having the entire exhaust straight piped with no more cats to deal with.
Old 10-09-2005, 09:34 PM   #10
Sko
Member#: 90396
2005 Legacy 2.5i
I guess best way to test it would be to finish the project, and have it tuned, you'll know how fast it's spooling and where the power is then, hopefully it's at around 2.5-3k rpms.
Just be careful til you get it tuned.
Nick
Old 10-10-2005, 08:40 PM   #11
Tats
Member#: 5692
WTF? YES! I am
better than you!
Zing!
Tats is offline   Reply With Quote
Old 10-12-2005, 12:08 AM   #12
prescottsti
Member#: 84902
04 Chevy Silverado
Duramax Diesel 500Hp
the down pipe flange looks Subaru the up pipe/manifold flange looks Mitsubishi. I'm not sure afaik all mitsubishis use Mitsubishi turbos so who knows what its off of
prescottsti is offline   Reply With Quote
Old 10-12-2005, 05:35 PM   #13
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
neither the dp or up are suby flanges ... 3 bolt dp...suby only has 4 and 5 bolt patterns the turbo is not for a subaru the exhaust housing is not for subaru, y not just sell it and buy the proper turbo.
less fabrication.
Old 10-13-2005, 10:19 PM   #14
mybluesubi
Member#: 53526
1997 Impreza
black
I still don't know if this turbo will produce boost on an EJ22. I would go with a bigger turbo if I thought that my engine could handle it. The block has about 87k miles and the heads have 267k miles. It is still producing great compression and pulls about 20 inches of vacuum at 6700 ft elevation which to my understanding is pretty damn good. No oil leaks and decent lower to mid range power. The car has never had good higher end power for climbing at elevations above 5000 ft at speed. It is a 4 bolt UP and DP flange. Besides, I'm not going with a stock UP or DP. I'm going to have the entire exhaust custom built.
Old 10-13-2005, 11:23 PM   #15
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Subaru Stars
it will definitly produce boost, the turbine and compressor wheels are the same its just different housing.
FS : IHI VF22 Turbo maddhatteroo7 Engine/Power/Exhaust 15 06-09-2010 04:46 AM
IHI VF22 and IHI VF29 ImprezMeWRX Engine/Power/Exhaust 7 03-02-2008 09:18 AM
ihi vf22 ihi for sale all offers considered toulakid Private 'For Sale' Classifieds 15 04-05-2006 03:38 PM
IHI VF-30, IHI VF- 23, MRT up- pipe, and more avtwrx Private 'For Sale' Classifieds 5 09-09-2003 11:28 AM
Replacing IHI RHB5 with IHI RHB6 Tim Prudence Normally Aspirated Powertrain 2 11-30-2000 12:07 AM
