Old 10-09-2005, 07:24 PM   #1
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
Default Why the change in torque split on the 06 STI?
How does going from 35/65 to 41/59 provide an improvement?
Zoso is offline   Reply With Quote
Old 10-09-2005, 07:48 PM   #2
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
It is supposed to better reflect the actual weight split between the front and rear axles.
My own personal opinion is that they moved the split closer together to increase the reaction time of the system. However, I'm not sure that I would consider the reduced range over which the DCCD can now operate as an improvement. Seems like the wider range over which it can operate, the more adaptive it can be....assuming it was fast enough to keep up with the dynamics of the vehicle.
But certainly the 41/59 split is probably optimum for most conditions.
-Michael
f4phantomii is offline   Reply With Quote
Old 10-09-2005, 07:50 PM   #3
shemoves
Member#: 80663
2005 STi
I thought the new split was was 49/51....either way, I was suprised by it considering how much the STi understeers.
shemoves is offline   Reply With Quote
Old 10-09-2005, 07:59 PM   #4
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
Remember that they base all their tuning on the JDM models, not the American models. The new torque split has a big affect on high-speed stability, along with the revised aerodynamics. Overall, the car is quicker through high speed corners, a bit slower through low-speed corners, and is far, far more stable on real roads with mid-corner bumps and humps. I could push it further and go faster with greater confidence than the older cars. The older cars were a bit more chuckable, and probably a bit quicker, but nobody this side of a professional race driver could really take advantage of it. The first of the facelift STI's had to be manhandled so heavily into the corners that most Japanese owners didn't know how well they could actually handle, as they literally ran out of arm strength to find out.
Cheers,
Paul Hansen
www.avoturboworld.com | www.sevenphotos.com | www.scoobymag.com
AVOjapan is offline   Reply With Quote
Old 10-09-2005, 08:18 PM   #5
WRX-pilot
Member#: 31162
. //Team Blew
This is what I figure, some of the complaints have been the DCCD not being reacting quick enough. Like F4phantomii said, 41/59 is probably sufficient anyways (I have seen some actually like the second to last setting on the dccd).
Now in manual mode the DCCD is constantly locking up when turning, braking and accelerating. With the DCCD at only 59% RWD it can lock up and reach 45:55 or 50:50 faster than 65% RWD could. This is just my idea of why they would do this, I wouldn't go around saying this is an official reasoning but on the other hand I wouldn't be surprised if this was true.
It does seem like Subaru is trying to make the DCCD work faster, part of the reason they added sensors to detect which way the front wheels are pointed.
-Michael
Also, edmunds has a little bit on it, they do mention that 41:59 better torque range:
http://www.edmunds.com/apps/vdpconta...4/pageNumber=1
"The improvements also allowed Subaru's engineers to change the standard torque split from 35-to-65 front-to-rear to 41-to-59 and give the DCCD system a greater range of torque distribution"
WRX-pilot is offline   Reply With Quote
Old 10-09-2005, 08:39 PM   #6
wrb2006sti
Member#: 96895
2012 STI
Ice Silver Metallic
petter said that the 06 handles much better than the previous models due to the new steering sensor and the revised dccd
wrb2006sti is offline   Reply With Quote
Old 10-09-2005, 08:55 PM   #7
WRX-pilot
Member#: 31162
. //Team Blew
so did makinen
http://www.subaru.co.jp/impreza/spec...pecial_1m.html
(Get about 40% of the way through the video)
Old 10-09-2005, 10:03 PM   #8
nightia
Member#: 93538
2005 STI
he's hardly going to says its worse, is he?
Looking forward to some real world track times between the 05 STI and the 06 STI, suspect a slightly better time with the 06 STI, possibly 1-2 seconds?
nightia is offline   Reply With Quote
Old 10-09-2005, 10:21 PM   #9
gc822
Member#: 81217
the new split is 49/51
gc822 is offline   Reply With Quote
Old 10-09-2005, 10:39 PM   #10
fastfreddy
Member#: 66148
05 STI
Given the fact that they have gave out very little informantion as to why they did this, maybe it was a cynical attempt to change something mechaincal so that people might buy an 06.
Had the 05 out in the rain yesterday in an autoX, and there's not much wrong with the 05 setup.
The rear bias makes the car sooo much fun to drive...
fastfreddy is offline   Reply With Quote
Old 10-09-2005, 11:34 PM   #11
Zoso
Member#: 37962
2006 CGM STI
Can you post where you're getting this info from? I'm pretty sure it's 41/59.
Old 10-09-2005, 11:37 PM   #12
Zoso
Member#: 37962
2006 CGM STI
He didn't seem to think it was necessarily better then the 05 but rather different. He did mention that the 05 oversteered easier and that the 06 was more predictable and easier to drive fast, but I don't remember him actually coming out as saying it was much superior or anything like that.
I hope this mechanical DCCD turns out to be a good improvement and not something that going to suck, it is the first year for it and I'm a bit worried. Hopefully it will be succesfull and carry over to the 07+.
Old 10-09-2005, 11:49 PM   #13
flyinpig
Member#: 43640
2015 Levorg sedan
You're correct, the SOA website states 41/59 split.
..Normally, DCCD splits power 41% front and 59% rear. Sensors monitor parameters such as wheel slippage, steering angle, throttle position and braking to help determine torque distribution to the wheels with optimum traction...
'06 STI Features and Specs
flyinpig is offline   Reply With Quote
Old 10-10-2005, 12:26 AM   #14
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Jesus people thats not the limit. You could possibly set it to the same as the 05s Manually. In automatic mode however it has the new split of 41/59.
You can still goto 50/50 and 35/65, the range hasn't been changed.
Old 10-10-2005, 01:20 AM   #15
WRX-pilot
Member#: 31162
. //Team Blew
Since you seem so dissapointed with us would you care to show how this is?
Old 10-10-2005, 02:26 AM   #16
kpxplaya415
Member#: 51614
correct me if i'm wrong, enable manual DCCD mode and spin that dccd switch up and down for the different settings...
kpxplaya415 is offline   Reply With Quote
Old 10-10-2005, 09:08 AM   #17
Zoso
Member#: 37962
2006 CGM STI
Guys I don't want to turn this into another DCCD torque or slip thread. The actual GEARING on the 06 STI has been changed to 41/59 and that is what I ment for this thread to focus on.
I'd also like to discuss the addtion of a mechanical LSD into the center diff. I don't get this, it has a mechanical LSD and an electronic variable one now as well?
Old 10-10-2005, 11:47 AM   #18
WRX-pilot
Member#: 31162
. //Team Blew
I didn't ask how to work the DCCD I asked how he knew that manual mode still allowed 65% rear since auto would only go to 59%
Old 10-10-2005, 12:35 PM   #19
f4phantomii
Member#: 58504
2004 STi w/o wing
Yes....I think the range is reduced. If it isn't, and Subaru simply changed the "nominal" split to 41/59, then the car should be better all around.
But I don't think that's what they did....I think the range on the 06's is from 50/50 to 41/59 and no further split beyond that, either in Auto or manual mode.
Anybody know?
-Michael
Old 10-10-2005, 01:22 PM   #20
kpxplaya415
Member#: 51614
haha i thought the range was still to 35/65, but i guess that's the answer we're looking for eh...
Old 10-10-2005, 01:42 PM   #21
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I agree. Going 155mph on the highway.. I was glued to the ground
sizzflair is offline   Reply With Quote
Old 10-10-2005, 06:51 PM   #22
wrb2006sti
Member#: 96895
2012 STI
Ice Silver Metallic
he did say much better in the new drive subaru magazine. also somewhere on the web is him driving a stock 06 and drifting it and having alot of fun in it hes a great driver. he is the tarmac man well loeb had something to say about that but hey
Old 10-10-2005, 11:40 PM   #23
RexStage1
Member#: 75210
2006 RB320 STI
2008 DSG GTI
The new split has me annoyed. Mid-corner corrections accompanied by throttle lift causes a bigger change from understeer to oversteer...and getting back on the gas hard causes not only understeer again but yanks the wheel because of torgue steer. And mid-corner shifts, well you get my point. All of this in auto and not driving like I'm on the track.
RexStage1 is offline   Reply With Quote
Old 10-10-2005, 11:44 PM   #24
Zoso
Member#: 37962
2006 CGM STI
I've noticed this to a small degree just everyday driving, but I'm pretty sure that if you're driving hard mid-corner throttle lifts and mid-corner shifts arent' a good idea in any car.
Old 10-10-2005, 11:58 PM   #25
RexStage1
Member#: 75210
2006 RB320 STI
2008 DSG GTI
I added the part about not on the track to reference daily driving (sorta). When driving 6 or 7/10th's on public roads where the corners have more than one apex or are sweeper like, the cars response is very drastic. It is enough of a difference from the '04 that it is always a bit of a surprise. I have not played with the manual setting, perhaps I should play with it.......the DCCD that is?
how do i change the amber side marker light on my 06 sti? FLYBYSTI Electrical & Lighting 3 01-26-2009 10:13 AM
torque split to the wheels??? db97 Tire & Wheel 4 11-15-2006 11:22 PM
What size is the torque bolt on the injectors on an 05 STi? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-10-2006 03:40 PM
Why the change in plugs from 02 to 03? FalconRS Normally Aspirated Powertrain 4 11-21-2005 11:50 AM
Change in Insurance Rate on the Scooby blue-sun Mid West Subaru Owners Club Forum -- MWSOC 6 03-31-2003 02:09 PM
