Old 10-10-2005, 02:54 AM   #1
chinoWRXL
Member#: 89123
02 WdBody STi Wgn
03 L
Default Apexi Boost Gauge backlight Help
i installed my boost gauge today. apexi el series with the main control unity. i used a vampire clamp to the cig lighter 12v for power. the boost needle works and displays boost but the backlight doesn't work.
after driving for a bit, the backlight would flicker on really quick and it would almost seem like it was reseting. the light would never stay on. i changed the wire from the gauge to the control unit and it was the same issue.
anyone know whats going on? im suspecting possibly a short in power supply but when i check the neg and positive lines they do not cross. i grounded on the yellow wire just to the left of the cig lighter. the only time i can get the gauge to do the flicker and reset is when i jiggle the positive (black) wire. could i have possibly not vamped the power supply correctly?
i did buy it used so ive got no warranty coverage on it, i think. and yes i did disconnect the battery before removing any wire and i did ground myself to discharge static buildup. but you never know.
thanks in advance.
chinoWRXL is offline   Reply With Quote
Omori Boost Gauge Backlight Issue diggnationfan87 Electrical & Lighting 0 03-10-2010 07:08 PM
Apexi EL Boost Gauge install help! bhkim126 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-11-2003 04:07 PM
I need a little help with the power for my apexi boost gauge... turbocharged North West Impreza Club Forum -- NWIC 3 03-09-2002 01:49 AM
I need a little help with the power for my apexi boost gauge... turbocharged Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-08-2002 06:27 PM
I need a little help with the power for my apexi boost gauge... turbocharged Newbies & FAQs 0 03-08-2002 06:14 PM
