#1 |
Member#: 48544
Vehicle:2002 WRX WRB |
I'm planning on getting a 20g td05 turbo from deadbolt and would like to stay with a TMIC, would this would, or do I need to go with a FMIC? How much would I lose keeping a TMIC.
Thanks
#2 |
Member#: 50891
You will be losing a handful of whp if you go with the TMIC, but not a lot, about 6-10 whp from what I've seen.
You will spool quicker. You will heat soak quicker. Either wrap your turbo and dp, get an IC sprayer, or both. |
#3 |
Member#: 38016
SCIC
Vehicle:06 GG EVO IX GT3082R ETS Kit |
Get a Perrin FMIC and you will be set. Enjoy that 20g
#4 |
Member#: 25413
TMIC will give you some nice throttle response but you can squeeze out more power from the FMIC.
#5 |
Member#: 48544
I'd like to stay with a tmic, and don't really need to squeeze out every hp, so a turbo xs or perrin tmic should be fine for the 20g? I just like the look of the tmic rather than pipes for the front mount.
#6 |
Member#: 93667
Vehicle:'03 Build'n a 2.12L 331whp/331wtq |
The Hyperflow is one of the best flowing TMIC if you can go that route. Kinda' expesive, but if you have an oversize scoop you won't have heatsoak problems. I have a HUGE scoop on mine and the extra air even keeps the heatshield cooler.
Kevin |
#7 |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
I'm doing an SBR20G with a Spearco TMIC tonight, I'll post up results tommorow.
Jorge (RiftsWRX) www.ProjectWRX.com |
#8 | |
Member#: 22965
Vehicle:2008 BMW 135i SGM |
#9 | |
Member#: 69212
Vehicle:'11 A3 Quattro K04 DSG Lava Grey |
#10 |
Member#: 36823
Vehicle:03 MBP WRX Sold :( 93.5 Single Supra :) |
There was a thread a while back that showed two cars same mods....except one TMIC and one FMIC.........the FMIC got 17 more whp.
#11 |
Member#: 56885
Vehicle:2000 IMPREZA Ra Blue 500hp@1.75 bar |
FMIC
---------------------------------------------------------------------------------- ITS ONLY MY00 500hp@1.75 bar http://spaces.msn.com/members/bosaleh/ |
#12 | |
Member#: 22965
http://forums.nasioc.com/forums/showthread.php?t=782505 |
#13 |
Member#: 79394
Vehicle:02 gda wrb |
the 20g is a badass turbo, it deserves a fmic
#14 |
Member#: 56485
AKIC
Vehicle:2009 Ram 1500 CC SPT R.I.P. Bro |
I second the FM. -Gene
#15 |
Member#: 84498
Vehicle:2003 Impreza WRX W raith R eady B lue |
Yup.
#16 | |
Member#: 36823
#17 |
Member#: 88905
if you plan on making big power and you don't want the added lag, go with a FMIC. now i know your thinking FMIC = Lag. But thats not true if you set it up right. What you should do is get a fmic kit where the piping is small diameter on the side that comes from the turbo and goes to the ic (just a bit bigger then the outlet side of the turbo, about 2.25 inches). then on the colder side it can be a bit bigger but no bigger then 2.5 inches. also the size of the ic matters too. you want to size it to your application. if the inner volume is too big you will get lag, if its too small it will restrict flow and you might as well put a restrictor plate on your car like nascar does
. I have a fmic that i built myself on my car. i used smaller piping and with the stock wrx turbo. Lag is not an issue.... |
#18 | |
Member#: 50891
1. the FMIC ran 2 more psi of boost (19 vs 21) that alone could make the 17 whp difference. 2. The TMIC hit peak boost before 4,000 RPMs. The FMIC 5,000 RPMs 3. The TMIC hit peak torque at around 4,400 RPMs. The FMIC 5,500 RPMs 4. TMICs heat soak quickly on a dyno and that always affects the numbers. On an open road at 70mph that will not be an issue. Now, I'm not dumping on FMICs I've had them on my vehicles before. But, if your trying to justify the extra cost, effort and loss of stealth factor because "I want more power" as your argument. The data just isn't there. |
#19 |
Member#: 48544
Well I'm not sold on the FMIC yet, but I'm leaning towards a TurboXS FMIC and painting it black for the stealth factor. I'm not sure if there is a better intercooler for the 20g, like the smaller injen that would have less lag. I would also like to keep the fog lights on my '02. Any other suggestions?
#20 | |
Member#: 32460
Vehicle:2005 Forester XT OBP |
I have the Turbo XS fmic painted black, stealthy imo...I like it, leaves me more room in case I want to go bigger plus not heat soaking light to light is another + for me. |
#21 | |
Member#: 60042
Vehicle:2004 WRX STI Rotated T67 ALLABOUTSPEED |
Next monday Rifts will be tuning my car with this FMIC and the DB20G. Stay tuned. |
#22 |
Member#: 48544
Is your DB20g a td05? Let me know the results. I never heard of the ssautochrome, got a link?
#23 | |
Member#: 90438
#24 | |
Member#: 60042
#25 | |
Member#: 6124
![]() That's a SBR 20G with a header, TBE, intake, and spearco TMIC at 19 PSI. That is actually a very STRONG result, since the averages I see are 320-340 for Deadbolt's, and 330-350 for SBR's. At the same PSI, etc. Here's another example ![]() SBR 20G on a FMIC ![]() SBR 20G on a TMIC Jorge (RiftsWRX) www.ProjectWRX.com |
| Thread Tools | |
| Display Modes | |
| FS: 08+ WRX / LGT turbo flange for FMIC or TMIC | CasopoliS | Engine/Power/Exhaust | 7 | 08-15-2011 10:38 PM |
| fmic or tmic with a td05-20g | subiedude03 | Factory 2.0L Turbo Powertrain | 1 | 10-31-2008 05:31 PM |
| WTB: 18g turbo, FMIC or TMIC, UTEC, 255lph FP, etc. | DFL2.5RS | Private 'Wanted' Classifieds | 12 | 01-08-2007 08:49 PM |
| What turbo should I get, FPgreen or a 20g? | josh04 | Factory 2.0L Turbo Powertrain | 23 | 07-02-2006 10:14 PM |
| Should I Go FMIC? | THE ONE | South West Impreza Club Forum -- SWIC | 16 | 07-21-2005 02:03 AM |
