Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-10-2005, 05:13 PM   #1
tubular031
Member#: 88767
2003 Cobb Stage2 WRX
Sexy Blue
Default LT1 Camaro, LS1 Camaro and a WRX
Ok my Boss was giving me a hard time for buying a 03 WRX. He use to have a LT1 Camaro and he keeps saying that his Camaro would destroy my little japo car. From all the mile numbers I see around the Internet, they are all pretty even with the LS1 having a slightly better time (stock to stock). I know that when it comes to turns the WRX will stomp on the Camaro. I will soon be going to cobb stage 2. How will I hang with the Camaro and firebird guys after stage 2? (in a stright line)
**EDIT**
Thanks for all the great info guys! Once again NASIOC members rock!!
Ok lets talk a little about handling now. How does a stock Camaro compair to a stock WRX?
tubular031 is offline   Reply With Quote
Old 10-10-2005, 05:22 PM   #2
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
If they are stock and you are stage 2 then you will work them.
Smoby is offline   Reply With Quote
Old 10-10-2005, 05:27 PM   #3
shoWRoX
Member#: 24724
03 BMW-325i
That latest Camaro's actually handled quite well. They were nice handling RWD setups, unlike the poor RWD handling setup of the same era Mustangs. So, coupled with their very powerful V8's and a good RWD a WRX would still need to be worried straight line and twists.
The problem with those cars became their weight.
Also, 0-60 and 1/4 mile is better and then it gets even worse for the WRX once higher speed and HP come into play.
T
shoWRoX is offline   Reply With Quote
Old 10-10-2005, 05:34 PM   #4
roninsoldier83
Member#: 61966
2016 Golf R & 13 WRX
Sold: 06 STI & 15 WRX
I think you should look more at average trap speeds between the 3 cars, rather than ET, as your ET is a large reflection of your 60' ft time, which is determined by *your* ability to launch rather than your car having a better power/weight ratio. If they're stock and you're stage 2, there's a good chance you can pull a better ET than them, and possibly even trap higher than the LT1 (possibly), but I'm pretty sure the LS1 will be trapping a few MPH higher than you, and would walk away from you from a roll. Just my $.02
roninsoldier83 is offline   Reply With Quote
Old 10-10-2005, 05:38 PM   #5
F0rcedFed
Member#: 95752
A stock WRX vs. a stock LS1 will lose badly, they are a firm low 13 second car, a stock WRX is a 14.0-14.5 second car depending on if you launch but have fun with the broken parts, these are not drag cars. You are comparing a RWD drag 8 cyl vs. a rally car. I know nothing about the stage upgrades for these cars however I know the LS1 camaro is not a toy
F0rcedFed is offline   Reply With Quote
Old 10-10-2005, 05:49 PM   #6
roninsoldier83
Member#: 61966
FYI, a stage 2 WRX has the ability to run low 13's as well, when my car was "stage 2" (Ecutek, not AP or UTEC) I was running pretty consistent 13.3's (with 1.7-1.8 60' ft times), that's why I said he might be able to pull a faster ET, but the LS1 should be trapping higher. It's all depending on the drivers, I've seen bad drivers in LS1's spin their wheels to the tune of 14's, and WRX's bog their way into the 15's. I would give the edge to the LS1, but you *can* beat him (assuming you're stage 2 by then) if you get a good launch and he can't launch worth a piss.
EDIT: There's a possibility you can pull a quicker ET, but unless something is wrong with the guy's car, the LS1 should still be a faster car, especially at higher speeds where launching isn't an issue.
Old 10-10-2005, 06:02 PM   #7
sean10mm
Member#: 96932
I wouldn't want to straight-line race a 4th generation Camaro. The LT-1 versions were rated between 275-305 HP. The LS-1 versions were rated anywhere from 305-320 HP. Oh, and they all deliver 320-340 ft-lbs of torque. Even a Cobb Stage 2 isn't really going to match those numbers (certainly not the V8 torque curve), you are going to be counting on AWD and less weight to even the odds, so if you aren't racing from a dead stop, you are probably always hosed in a straight line unless the Camaro driver screws up.
sean10mm is offline   Reply With Quote
Old 10-10-2005, 06:10 PM   #8
roninsoldier83
Member#: 61966
To add to that, it is an accepted fact that the LS1 was underrated, and actually had around 350hp (same motor as in the Corvette), this is proven by the large number of people putting down 300+ wheel horsepower bone stock. Also, it's said an LS1 is an LS1, I've seen dynos of stock Z28's (rated 305hp) putting down identical numbers as a stock SS (rated 320hp), the power ratings don't really matter, they all pretty much have around 350hp.
Old 10-10-2005, 06:16 PM   #9
BoostinEJ20
Member#: 73710
agreed...stage 2 wrx gets to about mid 13's, stock ls1 camaro will do low 13's...wrx's are not drag cars, but they are very fast...my .02
i always respect v8 rwd chevy's and pontiac's because i came from one, and my father used to have a 69 camaro and that thing was serious...i was actually looking at a 02 SS and wrx's but realized that i live in new england and i should get away from the rwd v8 for a daily driver.
BoostinEJ20 is offline   Reply With Quote
Old 10-10-2005, 06:18 PM   #10
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
If these Camaro and Firebird guys are import haters/muscle junkies, what makes all y'all think that their cars would be stock?
I wouldn't drag with those suckers, even at stage II.
KingOfSiam is offline   Reply With Quote
Old 10-10-2005, 06:20 PM   #11
WinglessSTi
Member#: 73067
2004 STi
Cobb Stage 2
he can beat you..but if you ever driven one..it feels like driving a big boat
wrx is very fast? ***
WinglessSTi is offline   Reply With Quote
Old 10-10-2005, 06:21 PM   #12
ewright
Member#: 68803
2004 WRX STi
those cars are insanely cheap to modify and make big power with
ernie
ewright is offline   Reply With Quote
Old 10-10-2005, 06:29 PM   #13
wrxdwpsti
Member#: 96845
04 WRX STi
i' say that if he was LT-1 you would have a chance...but idk about LS-1...now if you were in a STi that would be a different story...
wrxdwpsti is offline   Reply With Quote
Old 10-10-2005, 06:43 PM   #14
ktm
Member#: 36003
2006 WRX Ltd Wagon
WRB, Stg 2
Wow. This is a first. Nearly everyone agrees that an LS1, even an LT1, would beat a Stage 1/2 WRX. Most of the time you get the delusional group who think that their F/I 4-cylinder AWD is the shiznit and will beat a McLaren F1.
Kudos to ronin who pointed out that you should look at traps instead of ETs. The only reason the WRX performs well in the 1/4-mile is due to AWD. If it were a FWD or RWD vehicle, it would not show as well.
ktm is offline   Reply With Quote
Old 10-10-2005, 07:05 PM   #15
quazimoto
Member#: 70395
If it were RWD only it would faster.The reduced drive train reduction would equal more power to the wheels and i don't think wheel spin would be to much of a problem.Perfect example:Conquest TSI.
quazimoto is offline   Reply With Quote
Old 10-10-2005, 07:07 PM   #16
ktm
Member#: 36003
2006 WRX Ltd Wagon
WRB, Stg 2
Wrong. The WRX has a low ET for one reason only: AWD. Why do you think that a 225 hp WRX can have the same 1/4 time as a 350z, which has 65 more ponies and is RWD? Look at other RWD vehicles that have a similar weight and power (E46 330Ci and IS300) and you see that they do not perform nearly as well as the WRX.
Old 10-10-2005, 07:08 PM   #17
roninsoldier83
Member#: 61966
One more note, even though the LS1 will obviously be faster, there is actually 1 more slight advantage a WRX would have. Gearing:
WRX: 3.454 (1st) 1.947 (2nd) 1.366 (3rd) 0.972 (4th) 0.738 (5th) 3.90 final drive (3.54 rear w/1.1:1 conversion)
Camaro: 2.66 (1st) 1.78 (2nd) 1.30 (3rd) 1.00 (4th) 0.74 (5th) 0.50 (6th) 3.42 final drive
As you can see, we actually have slightly shorter gears, with the exception of our disgustingly tall 4th & 5th gear ratios, which are still shorter given the the lower (numerically higher) final drive (3.90 vs 3.42). Just a quick bit of info, as gearing is another factor to consider.
Old 10-10-2005, 07:12 PM   #18
ktm
Member#: 36003
2006 WRX Ltd Wagon
WRB, Stg 2
True, but let's not muddy the water any more than we already have.
Old 10-10-2005, 07:59 PM   #19
Finn McCool
Member#: 95425
2001 Firehawk
My LS1 came stock with 345hp and 350tq but that's really only on paper. Most LS1s will dyno the same with the exception of the 01-02's which dyno higher due to higher flowing exhaust, better intake and better cam.
My LS1 went 12.34 @114 mph with just bolt-ons. It also made 365 rwhp with just bolt ons. With ported heads and a big cam it made 437 RWHP and 404 RWTQ.
You stand a good chance taking a stock LT1 with a stage 2 WRX, a stock LS1 would be pushing it. If the LS1 had any mods whatsoever (or a good driver in a 6 speed car) it wouldn't be any contest at all.
Finn McCool is offline   Reply With Quote
Old 10-10-2005, 08:04 PM   #20
ewright
Member#: 68803
2004 WRX STi
no replacement for displacement
ernie
Old 10-10-2005, 08:38 PM   #21
Balr14
Member#: 84809
2005 Forester XT
My FXT will beat any stage 2 WRX and many STIs. It doesn't have a chance against my big, heavy GTO and I give it a headstart.
Balr14 is offline   Reply With Quote
Old 10-10-2005, 08:43 PM   #22
REX8
Member#: 24038
So your stock FXT runs 13.3-13.5? Any slips to back that up?
Cause last time I checked, it takes a stage II FXT to honestly run 99+ in the 1/4 and a mid 13. Which is what you'd have to do. No doubt an FXT hands it to a stock WRX, but a stage II, not if your stock (or he's at 3k RPMS )...no way.
And you can't really compare your GTO to a 285 horse LT1. Your car is a beast compared to an older LT1...apples to oranges...I don't know what you think thats telling us.
Old 10-10-2005, 08:44 PM   #23
roninsoldier83
Member#: 61966
That's cool man, what does your FXT run in the 1/4 mile? Is your GTO an 05? If so, didn't they bump the power up to 400hp in 05? I would expect the 400hp RWD car to beat the 230hp AWD wagon/SUV
Old 10-10-2005, 08:54 PM   #24
Balr14
Member#: 84809
2005 Forester XT
My FXT runs high 12s. It already has good weight transfer and gearing. Just needed a better turbo setup. My GTO is technically an LS2, but I can't tell you what the difference is between it and an LS1, except a few more CIs. It's got a more mods than the FXT, but they are smaller, cheaper mods.
I'm just pointing out that you don't see many stock LT1, LS1, LS2 engined muscle cars. Even my old 96 TA had a supercharger. For every dollar you spend making a Subaru 4 go fast, I can spend 40 cents and get just as much power in my muscle car. Plus, it will be very hard to break and mods won't have much effect on resale value.
Old 10-10-2005, 08:55 PM   #25
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
ernie
Tru dat. Cant wait to get a accessport or a utec and be the wagon with the big balls. (Bigger injectors, bigger fuel pump, bigger turbo )
trxdam is offline   Reply With Quote
diff between a 300hp wrx and 400hp wrx? (joke...and serious q inside) OneArmedScissor Proven Power Bragging 20 02-23-2014 01:31 PM
2002/2003 WRX or LS1 Camaro/Trans am? ConfusedBuyer General Community 92 04-14-2008 12:48 PM
Oh sweet, an LS1 camaro 6mt with only 74k!! skywaffles Off-Topic 27 12-22-2007 03:18 AM
Camaro/Corvette rims fit the WRX? JoBamBo Tire & Wheel 7 09-09-2005 02:49 PM
