Old 10-11-2005, 01:12 AM   #1
thsiao
Member#: 72260
2006 Cayenne
Exclamation Urgent help!!! What is what in a relay...
Is 85 the Ground on the relay and 86 where I hook up my Hella Supertones or is it backwards?
thsiao is offline   Reply With Quote
Old 10-11-2005, 01:28 AM   #2
pityr
Member#: 31719
Im spacing out alittle here but I believe it should be constant power to 30. Power wire to the hellas on 87. Switched power on 85 and ground on 86. Ground the hellas to the chassis.
pityr is offline   Reply With Quote
Old 10-11-2005, 02:10 AM   #3
thsiao
Member#: 72260
2006 Cayenne
I'm confused... according to this LINK and the place where I bought my Hellas, GND is suppose to be on 85 and signal on 86... which way is it?
People that have the Supertones with the relay installed please help me!
Old 10-11-2005, 02:16 AM   #4
pityr
Member#: 31719
Originally Posted by IntraWRX
pin 30: +positive from battery (i put an inline 20A fuse here)
pin 86: stock connection from original horn (you only need one of the original horn connections-- i've got the 2 hellas and the oem driver side horn hooked up)
pin 87: to hella horns (you'll need to split this signal, or daisy chain the horns)
pin 85: to battery ground (-)
quoted from the linked thread.
I have 4 hella's isntalled BTW.
ussually 85 and 86 are interchangeable. One is just the signal from your stock horn and the other is the ground.
Old 10-11-2005, 02:20 AM   #5
rubasu2
Member#: 26342
04' Sti
You do not need to add a relay for the Hella Supertones.
Unless you like pityr and intend to hook up four horns.
-Brian
rubasu2 is offline   Reply With Quote
Old 10-11-2005, 03:21 AM   #6
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
four horns!! crap that must be loud.
yeah 85 and 86 can be switched, makes no difference.
00Maddog is offline   Reply With Quote
Old 10-11-2005, 12:14 PM   #7
thsiao
Member#: 72260
2006 Cayenne
Ok great... one more question... is there another way of testing to see if both horns are working besides unplugging one? Kinda lazy to unplug and stuff...
Old 10-11-2005, 12:40 PM   #8
2phless
Member#: 69343
1998 TransAm cnvrtbl
If only one horn sounds it won't really sound 'horn like.' Like one flat note. Loud, but not 'piercing'. Each is a different note, that, in a chord, produces that unpleasant resonance.
Without unplugging one I don't know how to describe the sound of one horn blowing.
For reference: It's louder than the sound of one hand clapping.
2phless is offline   Reply With Quote
Old 10-12-2005, 08:02 AM   #9
Wires
Member#: 36677
2003 WRX Wagon
Sedona Red
Usually that's true, but if you are using a relay with diode supression, they become non-interchangeable.
For relays with resistor supression, or no supression, they are indeed interchangeable.
Wires is offline   Reply With Quote
Old 10-12-2005, 08:32 AM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
85 and 86 are always the relay coil. As Wires said they are interchangeable unless the relay has an internal suppression diode, if it does the cathode side of the diode must get the positive connection, and the anode the negative. If there is a diode it will be shown on the diagram on the outside of the relay. The standard automotive "cube" relays (Hella, Bosch etc.) generally do not have the diode.
Old 10-12-2005, 04:36 PM   #11
davis10
Member#: 70011
VOLTMETER
davis10 is offline   Reply With Quote
Old 10-13-2005, 06:11 PM   #12
909
Member#: 18776
Sorry to hijack.
If I wanted to add a relay to my aftermarket HID's, how would I wire it up?
909 is offline   Reply With Quote
Old 10-13-2005, 06:24 PM   #13
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Depends on what you are trying to achieve. I'd search this forum for some good threads.
What is this in my BOV? solidace46 Water/Methanol Injection, Nitrous & Intercooler Cooling 0 06-02-2010 08:00 PM
What is happening in the movie when this song is playing? Gerkins31 Off-Topic 12 06-01-2009 01:37 AM
What is this in my fuel return line, and why is it there...argg munkis Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-19-2004 07:21 PM
What Is Best In Life? Bigred14 Texas Impreza Club Forum -- TXIC 25 10-17-2001 11:48 AM
What is involved in removing the front grill? delectron General Forum Archive 2 08-31-2000 07:03 PM
