Old 08-27-2001, 12:47 PM   #1
Cjchaps
Member#: 3181
07 Rav4
Question Planning to change lotsa fluids, good or bad idea?
I took my stock WRX to a racetrack last week, and realized some of the stock fluids are not cutting it. My brakes got all spongy after the day was done, most likely because of the brake fluid. I burned a bunch of manual transmission fluid. So I think I will empty and refill the following:
1)Brake fluid
2)Manual Trans Fluid
3)Read diff fluid - Not sure if I should do this one?
4)Power steering fluid - Is it better to go with a higher grade?
Also, are there two brake fluid containers? I noticed two yellow caps that both said brake fluid on them.
Does anyone know how to check the read-diff fluid levels?
Is there any other fluids you guys would recommend changing out?
-Thanks
Cjchaps is offline   Reply With Quote
Old 08-27-2001, 01:51 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
First off, how do you burn manual transmission fluid? The seals would be melting out of your transmission before you could heat the fluid to the burning point. It is not the same as an Automatic Transmission.
Changing the Brake Fluid is a sound idea, the factory fills with a DOT3 fluid. There is only 1 brake fluid reservoir, it rests atop the Brake Master Cylinder.
The P/S uses ATF, it's pointless to try to upgrade the P/S fluid unless you can quantify the results.
To check the Rear Diff. fluid level, remove the upper plug on the rear diff. cover. With the vehicle sitting level, the fluid should be at the bottom of this hole when cold. Just like the Manual Trans. fluid, there is no need to replace this fluid except for mileage.
SubyTechMaster is offline   Reply With Quote
Learning to snowboard after ACL knee surgery...Good or bad idea? trailertravis13 Off-Topic 19 12-17-2007 12:01 AM
Good or bad idea with Cobb? GregUnd Texas Impreza Club Forum -- TXIC 17 05-09-2002 11:16 AM
Boost controller with nothing else but a boost guage, good or bad idea? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-08-2002 09:07 AM
New clutch? Good or bad idea? GregUnd Texas Impreza Club Forum -- TXIC 13 12-19-2001 10:48 AM
FMIC: Good or Bad Idea Byrner13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-29-2001 07:51 AM
