Old 10-11-2005, 01:05 PM   #1
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Default Need help with headlight wiring...
Ok so my aftermarket nokya bulbs finally melted my headlight harness so I went to pep boys and bought 2 heavy duty pigtail connectors.
Now my question is...all I had to do is cut the stock one off and just splice the wires into the new one right?
second, on the left headlight, lets say you're standing facing the car with the hood up, if you look at the wires, I know the one on the right is the low beam wire, but which one of the other two is for the high beam? The center one?
and same question for the right headlight...
any help would be appreciated!!!
Erexxx is offline   Reply With Quote
Old 10-11-2005, 03:55 PM   #2
pityr
Member#: 31719
the center one is the shared power.
pityr is offline   Reply With Quote
Old 10-11-2005, 04:18 PM   #3
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
ok so the one on the left is high beam?
Old 10-12-2005, 12:20 AM   #4
pityr
Member#: 31719
One is high and one is low. Since you know the one on the right is the low beam then the one on the left will be the on high beam.
Old 10-12-2005, 01:45 AM   #5
Handsdown
Member#: 29355
could a multimeter help in this case?
Handsdown is offline   Reply With Quote
Old 10-12-2005, 02:11 AM   #6
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
thanks guys for your help but i got it all installed and everything is good to go
02 wrx to 04 STi front end swap, help with headlight wiring Unlikely Hero Electrical & Lighting 12 03-25-2011 01:40 AM
Help with headlight wiring with pics! jordanderson Electrical & Lighting 6 12-14-2006 08:48 PM
Need help with clock wires for guages steak Electrical & Lighting 3 10-01-2003 02:59 PM
Need help...Burnt headlight wiring lawchang Bay Area Impreza Club Forum -- BAIC 2 08-17-2002 10:21 PM
Need help with one wire for turbo timer dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-22-2002 05:01 PM
