Old 10-11-2005, 05:24 PM   #1
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
Default 3" Perrin Turbo Inlet w/ FP Green 3" Inlet
Well I have been sitting here staring at my DB SZ49 and FP Green w/3" inlet. Yesterday came my new Perrin inlet for the Green, and it was time to compare and take some pictures while Im waiting on some other parts. It becomes obvious just how big a difference their really is once set side by side.
SSFWRX is offline   Reply With Quote
Old 10-11-2005, 05:27 PM   #2
Rallycarperson
Member#: 53971
#35 SP Rally Car
MAP-RALLY.com
Yes there is a difference on paper...but I doubt you will feel any difference in power though. PITA to install too.
~Mark
Rallycarperson is offline   Reply With Quote
Old 10-11-2005, 05:28 PM   #3
InfamousDX
Member#: 25413
damn... lucky enough to have both those turbos though!
it's no question as to why it's a bitch to fit in there!
Old 10-11-2005, 05:37 PM   #4
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
I most certainly will feel a difference. The SZ49 has a 5 degree clip which hurts spool and power under the curve on my JDM 2.0 When I looked back at my previous FP Green I made more power and torque down low, and a much smoother curve. The SZ49 on my car misses the motors peak VE resulting in late spool and probably lower power.
Now onto the turbo inlet and 3" opening. I have a distinct feeling that there will be quite a bit of difference from a 2.4". Yes it does taper at the turbo, however the volume of air in there should help in the smallest bit as a plenum, and the taper at the turbo should draw a little more air in at a higher rate of speed.
Mike at Gruppe-s has noted improved throttle response from the 3" on the dyno. And thats hard to do on the nasty Mustang rollers they have.
Old 10-11-2005, 11:46 PM   #5
jstbstn
Member#: 35020
02 WRX - Stage WTF
04 WRX Wide Wagon - Stg 3
Do the TGV sensors need to removed to fit the 3" inlet, since the small inlet tube curves around them???
jstbstn is offline   Reply With Quote
Old 10-11-2005, 11:58 PM   #6
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
on a USDM motor it is said that they can be damaged if installed with a turbo that requires a 3" inlet hose becuase of the size of the housing. On my JDM motor I have no worries. I think removal is key, but that can require some workarounds.
Old 10-12-2005, 12:38 AM   #7
chris-man
Member#: 90572
2013 WRX STI
07 ninja ZX6R
nice turbos
chris-man is offline   Reply With Quote
Old 10-12-2005, 01:57 AM   #8
Chris Cuevas
Member#: 75547
2016 STi-ICE Silver
SRP P&P'd VF22 + NOS= RIP
The Turbo inlet hoses arent that bad to install. Just a little patience and maybe a few bad words and she is in.
I am sure that it will make a difference with the green !
Chris Cuevas is offline   Reply With Quote
Old 10-12-2005, 10:38 AM   #9
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Big tube small area, and u had a say a few bad words to get it in? Sounds like the first time getting a piece of a$$
Token-Negro is offline   Reply With Quote
Old 10-12-2005, 11:47 AM   #10
pux888
Member#: 8356
02 STi swap
12 WRX limited
You think the clip is really hurting your power? I remember Clark saying that w/ a 12 degree clip on the Green they picked of like 40 whp in the midrange, due to the excessive backpressure on that turbo. Think he said it was like 3:1! Anywho, just curious.
pux888 is offline   Reply With Quote
Old 10-12-2005, 06:11 PM   #11
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
That may be on a 2.5L. On my 2.0 when I compare the Green to SZ49 plots everything is shifter 4-500 RPM to the right. This is proof in the pudding. Jerry at DB even says approx a 400RPM later spool becuase of the clip. A clip is great once the turbo is spooled...my problem is getting it spooled.
Old 10-12-2005, 10:55 PM   #12
Synic Motorsports
Vendor
Member#: 96179
1996 Ver.7 Brighton
03 DC5-T
so is the green with the 3 inch inlet just a bigger inlet, or the compressor housing bigger. does it use the red compressor?
Synic Motorsports is offline   Reply With Quote
Old 10-13-2005, 12:30 AM   #13
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
3" inlet using the FP Red compressor housing as far as I can tell.
Old 10-13-2005, 06:41 AM   #14
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
The Red's compressor housing is different cuz it has a bigger inducer. It most likely has the housing off of the Green for a DSM.
spoolinsuby is offline   Reply With Quote
Old 11-23-2006, 06:48 PM   #15
subenerd
Member#: 72630
2004 STi
OMGHi2U Thanksgiving Day bump
Maybe some one can help me here...
What size would fit the 8CM FP 18g? The 3" inlet or the 2.4" ?.
subenerd is offline   Reply With Quote
Old 11-23-2006, 07:33 PM   #16
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
It should be the standard 2.4" (not 2 1/4", BTW) inlet, unless stated otherwise. It didn't say anything on FP's website about the 7cm or 8cm using a 3" inlet, so I'd say 2.4".
firebox40dash5 is offline   Reply With Quote
3" FP Green, 3" hard pipe inlet, manifold, uppipe, dp, TXS short ram & more Adrenalin Rush Engine/Power/Exhaust 22 02-12-2012 12:48 AM
FS-> FP Green 3", perrin 3" intake, 70mm APS CAI, APv1 silvergrey05 Engine/Power/Exhaust 9 10-14-2008 11:36 AM
FP Green, 3" Perrin Inlet, Intake [email protected] Engine/Power/Exhaust 17 07-15-2008 12:14 AM
FP 3" FP Green and 3" Perrin Turbo inlet snwman Engine/Power/Exhaust 5 05-11-2007 10:40 PM
New FP Green 3" Inlet Pics and a Question SSFWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-05-2005 10:56 PM
