Old 10-11-2005, 09:42 PM   #1
scooterforever
Member#: 55011
Default Oil analysis after 6,000 miles of alky injection
I just got back the results of my first Blackstone Labs analysis. I'm sold, and plan to keep sending them oil samples after each oil change. I have been running alky injection (50/50 water / methanol) for about 6,000 miles, and was interested in what the quality of my oil looked like. In general I am pleased by the results, but thought I would post them to the forum. The high silicon reading is interesting, I still use the stock intake and paper filter. Something to watch, I suppose. The discussion at the beginning of the paragraph is because I thought the oil was 10W30, but it turned out to probably be 5W30 (caught me... I had taken it to the dealer ). With the increased timing from alky injection, I was pleased to see a lack of lead content (read:bearings OK) in the oil. Anyway, here's the analysis, I have ~ 61,000 miles on the car, and use a 7 mm nozzle on the WI (have gone through nearly 10 gallons of mix in the 6,000 miles of WI):
scooterforever is offline   Reply With Quote
Old 10-11-2005, 10:12 PM   #2
rubberbiscuitt
Member#: 96566
2002 wrx sedan
black
i found blackstone's website but i couldn't find; what's their turn around time?
rubberbiscuitt is offline   Reply With Quote
Old 10-11-2005, 10:13 PM   #3
scooterforever
Member#: 55011
Turn around time is great, but it takes about a week or two for them to mail you a sample kit. I took the sample earlier and stored it in a clean jar. A week later the sample kit arrived, and I transferred the oil to it. They emailed me the analysis (pdf file) the same day they received it.
Old 10-11-2005, 10:35 PM   #4
InfamousDX
Member#: 25413
Blackstone labs is awesome. But congrats on the good readout!!
Old 10-11-2005, 10:38 PM   #5
DemolitionNine
Member#: 93607
Whats it cost for their Oil Analysis?
I've done it before with Caterpillar Diesels... but not for our cars.
Just curious! Interesting find!
Thanks
-Matt
DemolitionNine is offline   Reply With Quote
Old 10-11-2005, 11:31 PM   #6
scooterforever
Member#: 55011
$20 for the basic analysis, which is what I got.
Old 10-11-2005, 11:58 PM   #7
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
No lead. Nickel and copper is low. Aluminum is low so likley no piston scuffing either. Mine is due back any day, I hope it is better this time.
ebeck is offline   Reply With Quote
Old 10-12-2005, 03:04 PM   #8
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Nice results for a modded WRX! Do you have a modlist and details on your water injection setup? I assume you meant 0.7mm not 7mm injector in your first post.
drees is offline   Reply With Quote
Old 10-12-2005, 03:15 PM   #9
hondaeater69
Member#: 60324
How old is the air filter?? If it isn't that old/dirty, i would check the system for leaks.
I run my oil MORE than twice as long as you do, and my latest UOA showed less than a 1/3 that much silicon. (7.5K on oil, 4 ppm silicon)
Old 10-12-2005, 03:23 PM   #10
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
scooterforever - I'm assuming this is full synth. right?
snvin is offline   Reply With Quote
Old 10-12-2005, 09:07 PM   #11
scooterforever
Member#: 55011
Wow, thanks for the questions/feedback.
Honda -- yeah, the silicon is concerning. The stock air filter is actually pretty new, only about 7k miles. I will recheck how it is seated, and look for leaks in the airbox. My idle is rock solid, and boost is firm without any sounds of leaks, so I think the post-turbo setup is leak-free. But I'll keep my eye out for it.
Snvin -- full synth. Been that way since 20k miles or so.
Drees -- yeah, 0.7 mm WI nozzle, LOL. Here's my mod list:
VF-34, MadDad DP+3CE+Borla Hush, GP Moto-style equal length headers, STi pinks, Walbro, stock intake, SpeedFactor TMIC, Aquamist 2d injection, EcuTek custom tune, stock pulley (used to be underdrive, went back to stock) and stock bypass valve. Boost peaks at 20/21 lbs under WOT, with the cold I'll see 21.4 lbs, in the summer less. Tranny upgrades, to the extent it impacts engine load: 4EAT with ProTorque TC, Level10 valvebody, Amsoil synth ATF, ATF cooler, etc.
Used oil analysis FXT 6,144 miles German Castrol Syntec 0W30 bluesubie Service & Maintenance 4 11-19-2005 08:21 AM
Oil analysis after 3k of using Torco Race Fuel Concentrate The Deliverator Service & Maintenance 8 05-19-2005 12:51 PM
What oil after 50,000 miles of Subaru bulk? UKscooby General Community 4 04-01-2004 07:51 PM
Question about different types of oil and the 10,000 mile checkup bambams247 Service & Maintenance 0 08-29-2003 03:07 AM
6,000 miles and my STi is using oil, THIS IS BS!!!!! SilverSTi STi Forum Archive 72 07-16-2003 06:25 PM
