Old 10-11-2005, 09:50 PM   #1
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Default COBB Access Port Map Question: Turbo Noise!
I have a very loud rushing air sound coming from the turbo(?) when I'm at WOT. I'm not sure if it's a vacuum sound or a boost sound? It happens at higher RPM's too @5500 and up...
Anyway, this only happens on the High wastegate duty cycle map, Stage 2 for 93 and 91 octane. I'm using this because my boost pressure was coming in at 10-11PSI tops on the standard stage 2 93 octane. Now it's 14-15 PSI with this map and it even feels like it pulls harder too.
The car is a 2004 STi with a Ultimate racing downpipe, and an HKS TBE + Access port. No other mods. I'm wondering what this sound is and if it's safe?? REALLY loud air rushing sound that builds in pitch. Thanks for your help.
essogas is offline   Reply With Quote
Old 10-12-2005, 09:08 AM   #2
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Check your BPV and TBE. It might be normal though. My turbo got considerably louder under load when I reflashed with a 19psi protune v. a 17psi off-the-shelf cobb map.
MF-DIF is offline   Reply With Quote
Old 10-12-2005, 09:57 AM   #3
jays05
Member#: 78165
05 STI 35r + e85
Boost leak? I'd check the IC to TB hose and the turbo to IC hose.
jays05 is offline   Reply With Quote
Old 10-12-2005, 04:37 PM   #4
essogas
Member#: 35703
2004 WRX STi
^^Boost leak!? Really. But it feels like I have more power. I will check it though. Also, this sound should be duplicated under the other maps too, if it was a leak, right? Currently, it's only the one kind of map at WOT. Hmmm... I think I will switch maps again to be sure it's only this one map....
Old 10-12-2005, 05:54 PM   #5
jays05
Member#: 78165
05 STI 35r + e85
The boost leak came to mind because your boost levels are really low. Are you at a high elevation? I had a leak for a while, it was on the TB to IC hose on the TB side.
Old 10-12-2005, 10:41 PM   #6
STI_FFY
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
After my tune and the increased boost, my STi sounds kinda like that vent weight on top of a pressure cooker when someone walks across the room. Instead of a low steady hissing sound like on the stage 2 93 octane map of the AP, it now is louder and stutters (the sound pulses rapidly). I think this is either the wastegate fluttering or the bypass valve doing so. A stiffer spring in one or the other might solve it.
STI_FFY is offline   Reply With Quote
Old 10-13-2005, 12:20 AM   #7
essogas
Member#: 35703
2004 WRX STi
I always thought my boost was a bit low, too. Hmmm, Better investigate this. How do I check for a leak though? Just make sure the hoses are clamped tight, look for holes?
FS: (SoCal) Cobb Access Port V1 04 WRX - PDXTuning maps for a VF 39 LBrandWRX Engine/Power/Exhaust 9 08-26-2010 05:05 PM
94 Octane maps for Cobb access port? specR1 AccessPort 12 05-05-2008 10:15 AM
For Sale: 1 NEW 05 STI Cobb Access Port 1 NEW 04 STI Cobb Access Port VERY Cheap!! mrtrex Engine/Power/Exhaust 13 09-21-2006 08:51 AM
New Access Port maps on Cobb website Alard Engine Management & Tuning 7 03-29-2005 02:58 PM
