Old 08-27-2001, 03:15 PM   #1
Apexboy
Member#: 343
1998 Legacy GT
Granite Pearl
Default Best (Worst) trip to Canada
The worst day in Canada....<br>
Took a day off of work to go up to Victoria with my girlfriend. Got across the border, Phew! no problems there.<br> About a mile or two down the road, right by the "Welcome to Surrey", my car jerked and jerked and jerked. All my lights came on. and pulled off to the side of the road. I couldn't figure out what happened... Tried to start the car, grrrgh grrgh grrgh (metal grinding sound) <br>
Called AAA and had me tow over to a Subaru Dealership in Langley. They took the car apart, and found that the bolt holding the pulley broke inside, and made the timing belt come forward. From what they said, most likely, the timing belt skipped couple times, and maybe bent a couple valves... please please, not the valves!!!! <br>
I saw the plastic cover that covers the pulley, and whoa!!! You can actually see the track of the timing belt burned into the plastic. It was actually bubbling on the other side.
So, here I was, stuck in Canada with a limp car, called Mike at Smart Sevice in Seattle, arranged a flatbed truck to take my car back to Seattle... $300 CAD. <br>
Still waiting for Mike to call me back on the damage....
<b>Lessons learned:</b><br>
1) Become a member of AAA or CAA<br>
2) If you're already a member, upgrade to the plus level. It covers 100 miles for towing.<br>
3) Have your cellphone ready at all times!!!<br>
4) Don't skip work for a day in another country... It's not worth it.
Apexboy is offline   Reply With Quote
Old 08-27-2001, 09:08 PM   #2
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Default Re: Best (Worst) trip to Canada
If you have the DOHC engine, you may indeed be in for some valve issues I just had a similar experience with my 89 RX. where the bolt holding one of the timing belt pulleys on loosened, and allowed the belt to jump several notches. However, that particular engine being non-interference, I had zero (none, zip, nothing) damage, even after cranking and cranking, hoping irrationally that it would start...
Good luck...
rrubel is offline   Reply With Quote
Old 08-27-2001, 10:17 PM   #3
tahrndt
Member#: 1315
Sombody please help me out here. I understand that Hundah uses an interference engine if the timeing belt breaks or is damaged you are S.O.L.
What is the Soob Phase I and Phase II 2.5s? What exactly is the difference between a non-interpherence and one that interferes?
TIm
tahrndt is offline   Reply With Quote
Old 08-27-2001, 10:59 PM   #4
Steve 2.5
Member#: 1452
2002 Legacy GT Sedan
I believe all modern Subaru engines are non-interference so your valves should be all right. If you look at the pistons they have cutouts in them to clear the valves in case the timing belt brakes and some of the valves get stuck in the open position.
With an interference engine, if the timing belt breaks and the valves are stuck open when the piston reaches TDC the piston can strike the valves and bend them.
--Steve
Steve 2.5 is offline   Reply With Quote
Old 08-28-2001, 01:03 AM   #5
Apexboy
Member#: 343
1998 Legacy GT
Granite Pearl
@###$!!!! I went and visited Mike at the shop and found that 2 of my cylinders have 0 compression. They took out the spark plugs, the 2 on the passenger side is ok. The driver's side ones... BLACK!!! Crap!!! Since mine is a 16V, I have possibilities of 8 valves... oooh, the headaches...
Old 08-28-2001, 02:12 AM   #6
czo79
Member#: 6752
The phase II EJ25's are non-interfearance, although this was explained to me as being true, 95% of the time. Go figure. As for the phase I, they are interfearance engines....
I don't know about the EJ20 or EJ22.
Micum
czo79 is offline   Reply With Quote
Old 08-28-2001, 10:56 AM   #7
Apexboy
Member#: 343
1998 Legacy GT
Granite Pearl
ooh... this sucks... Since mine is a Phase I engine, the valves are shot.
And of course, since 2 of my cylinders are ok, I have 8 valves to choose one. hmmm, eeny meeny miney moe.
Subaru should start making rubber valves. So when the piston hits it, BOING! ...
Old 08-28-2001, 11:32 AM   #8
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
doh, sorry to hear your engine is toast. but you can rebuild the car.. better.. stronger.. faster..
froggert is offline   Reply With Quote
Old 08-28-2001, 05:50 PM   #9
Apexboy
Member#: 343
1998 Legacy GT
Granite Pearl
Just found out that I bent 2 exhaust valves. 1 per cylinder. Damage is ~$1K or a bit lower...
What can I say... not due to reckless driving, and couldn't have been prevented. So, I guess this is the price we pay.
Old 08-28-2001, 11:16 PM   #10
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
How many miles and mods or on the motor?
nitrohuffer is offline   Reply With Quote
Old 08-29-2001, 12:37 AM   #11
Apexboy
Member#: 343
1998 Legacy GT
Granite Pearl
So far, I am running 74K. I have a Intake and APEXi Megaphone Dunk series exhaust system.
trip to Canada nhmtns Eastern Canada 6 04-16-2006 10:51 AM
my trip to canada Will98RS Canada Region Forum 5 03-21-2003 11:03 AM
My trip to Canada, eh. *56k beware* JC Member's Car Gallery 9 03-04-2003 12:41 AM
Bug-eyed trip to Canada Paisan Tri-State Area Forum 5 07-23-2002 12:43 AM
Rally trip to Canada cancelled Flashboy Mid Atlantic Impreza Club -- MAIC 9 09-24-2001 03:37 PM
