Old 10-12-2005, 10:17 AM   #1
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Default What parts do I need to replace OE clutch
http://www.subaruparts.com/diag/?mod...category=100-1
What parts from this list do I need to replace my OE clutch completely?
MF-DIF is offline   Reply With Quote
Old 10-13-2005, 10:46 AM   #2
WilkinsSubaru
Vendor
Member#: 43552
:o) Need Parts Now?
You will need:
Clutch Disc
Pressure Plate
Pilot Bearing (In Flywheel)
Throwout Bearing
You may need a flywheel depending on the condition of yours. You can buy aftermarket clutch kits that come with everything you need and some even include the flywheel. Some people change the dust boots and some other minor extras but most of the time it is not necessary.
You may want to check out the sticky at the top of the forum page. There should be a transmission and clutch FAQ to answer any questions that you may have.
Thanks,
Jackie
Wilkins Subaru
410-689-8061
[email protected]
WilkinsSubaru is offline   Reply With Quote
What parts do I need to grease? jasona Normally Aspirated Powertrain 11 09-27-2005 05:58 PM
Replacing stock downpipe - what bolts do I need to replace the spring bolts? ImportVenom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-22-2004 01:33 AM
What parts do I need to add a turbo? Acejam2k Legacy Forum 21 10-12-2003 07:11 AM
What parts do i need to add a turbo to my car? Acejam2k Normally Aspirated with bolt-on Forced Induction Powertrain 4 09-29-2003 12:25 AM
What parts do I need to hook up amp?? entropy111 Car Audio, Video & Security 1 10-01-2001 02:51 PM
