Old 10-12-2005, 11:01 AM   #1
DarkSong
Member#: 40731
2004 WRX
Java Black Pearl
Question replacing 04 WRX foglamp bulbs?
I've searched all over this forum, a couple of others and google searches are coming up blank for me. The passenger side fog lamp went on me, and in the owners manual they suggest to take it to the dealer for replacement, since it is "difficult" to do. I'm looking for advice or a HOWTO or something to help me get to the bloody things myself - this "take it to a dealer" jazz just isn't acceptable, y'kno?
I want to replace the stock bulbs with something that throws a bit more light, and I imagine the dealer wouldn't install aftermarket parts like that without whining at me in some way about voiding warranty, blah blah. So, any help with doing this would be appreciated - I'd like to get this done with before the weather here in Western NY gets much colder. Thanks!
DarkSong is offline   Reply With Quote
Old 10-12-2005, 11:10 AM   #2
Okita Souji
Member#: 41097
2005 WRX
You'll have to remove the fogs through the bottom of the bumper.
http://www.subaruparts.com/guides/20...ps_Revised.pdf
See steps 11 and 12.
Okita Souji is offline   Reply With Quote
Old 10-12-2005, 11:41 AM   #3
Yotsuya
Member#: 935
Jack Soo Fan Club
You can get to the bulbs from the wheel wells, if I remember correctly.
<-- changed foglight bulbs over a year ago and forgot how it was done.
Yotsuya is offline   Reply With Quote
Old 10-14-2005, 07:30 PM   #4
woody77
Member#: 94498
2004 WRX - Sold...
I found it easiest to actually pull the fog light housings, swap bulbs, and reinstall, than try to do it on-vehicle. You need to go up through the underside of the bumper (peeling back the splash guard), and pull the two bolts. Then the lights come out through the front of the bumper (pop out the plastic around them first). You should be able to get enough slack in the wiring to get it loose from the front, if not, unhook the electrical connector from underneath and then pull out the housing
Where the electrical connector meets the housing, you rotate the back of the housing, and it comes off, revealing the retaining wire for the bulb, and the connection for the positive lead.
Takes a couple minutes to figure it out, but it's not that bad (unless your garage floor is filthy...)
woody77 is offline   Reply With Quote
DIY fog light bulb replacement 04 wrx steakraw Interior & Exterior Modification 0 08-24-2008 09:42 PM
Replacing 06 WRX foglight bulbs _JsWRX Electrical & Lighting 3 02-13-2007 05:08 AM
07 wrx rotors replace 04 wrx rotors? wrXiconZ Brakes, Steering & Suspension 4 02-09-2007 10:42 AM
04 wrx hvac bulbs rapeacivic Electrical & Lighting 6 11-22-2006 04:26 AM
Replacing 04 WRX Gauge faces with STI faces Imapuertorro Interior & Exterior Modification 2 03-15-2005 11:32 AM
