Old 10-12-2005, 02:23 PM   #1
SubaruGenuineParts
Member#: 82767
Exclamation Trouble with new oil filter 15208AA09A - DETAILS INSIDE
10/12/05
Subaru has issued (snipped) the following statement:
Please be advised that oil filter, part number 15208AA09A, may potentially exhibit a small amount of seepage that is noticed during the installation process.
Although seepage is slight, we are requesting that all inventory of this part number be removed from stock immediately.....
No official recall of the product for the consumer at this time
BUT....
I have learned the following.
suspected bad batch numbers:
your oil filters should have a series number stamped on them
if you have one of the following series numbers,
then your filters are suspect of this seepage issue
  1. F08
  2. F09
  3. F10
One would think you should be able to exchange them for a known "good" oil filter at any Subaru Dealership, but again, there is no known official recall at this time.
That's all I have for an update at this moment.....
Jamie Thomas
[email protected]
www.subarugenuineparts.com
www.subiegal.com
SubaruGenuineParts is offline   Reply With Quote
Old 10-12-2005, 02:39 PM   #2
STi-MAN
Member#: 70252
05 STI
blue
i dont like the new filters at all, look exactly the same as the purolators, but more pricey. they should bring back the black ones.
STi-MAN is offline   Reply With Quote
Old 10-12-2005, 02:52 PM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
So the filter in question are the brand new ones that were just released and the one you notified us about a little while back Jamie? I'm still using ones I purchased a couple years back before the black ones came out. After I use up my stash, I still have two of the black ones to use
Hank3 is offline   Reply With Quote
Old 10-12-2005, 03:01 PM   #5
SubaruGenuineParts
Member#: 82767
exactly.
these are the brand new ones, the most recently released filters from Subaru.
these 09A took the place of AA100....
jamie
Old 10-12-2005, 03:36 PM   #6
highdensity
Member#: 75145
1994 Toyota Camry
Junkyard Racing Green
so you're saying i should find a dealership and trade the ones i just got?
highdensity is offline   Reply With Quote
Old 10-12-2005, 06:35 PM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Jamie is saying that Subaru has determined that there is a problem with certain lots of the new oil filter, that Subaru has informed the dealers and is recalling all such filters from the dealers ONLY at this time.
There is no recall being issued to the Customer at this time. With no official recall, it is a good bet that the dealer would not give you a new one for nothing.
Samurai Jack is offline   Reply With Quote
Old 10-12-2005, 06:44 PM   #8
Thumper23
Member#: 11571
good thing I still have a stock of black ones then
Thumper23 is offline   Reply With Quote
Old 10-12-2005, 06:47 PM   #9
lovesmysuby04
Member#: 71494
07 Legacy GT
11 SSM Hatch
Call your dealership to determine if they will take it back cause mine said they will.
lovesmysuby04 is offline   Reply With Quote
Old 10-12-2005, 11:43 PM   #10
highdensity
Member#: 75145
1994 Toyota Camry
word.
turns out i got AA060's, so i'll be alright for the time being.
Old 10-13-2005, 03:10 AM   #11
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
wow thank's for the info jamie. i'll have to see what we're putting on at my dealer
00Maddog is offline   Reply With Quote
Old 10-13-2005, 09:27 AM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Originally Posted by highdensity
word.
AA060's are NOT RECOMMENDED for turbo models. per subaru.
they are for non-turbo's only....
Jamie
Old 10-13-2005, 03:07 PM   #13
highdensity
Member#: 75145
1994 Toyota Camry
doh! well, guess the search continues...
Old 10-14-2005, 03:14 AM   #14
pignoseWRX
Member#: 93152
2006 Impreza WRX
SGM
uhoh... i think i put one of those on my cars last week... will have to check the batch i guess...
pignoseWRX is offline   Reply With Quote
Old 10-15-2005, 03:33 PM   #15
NMLegacy
Member#: 40866
2005 LGT 5MT wagon
2006 FXT Ltd
Default AA09A filters are junk!!!!
I changed oil and filter on my wife's '06 FXT last week and used the "new" 15208AA09A filter. She came home last night and complained of oil smell. So I went out today and looked under the car, oil everywhere! ! I put the car on my lift and the source appeared to be from the filter. After cleaning everything up I started the car and observed the filter. Within seconds oil was seeping out between the rolled lip and the outer circumference of the can. Piece of JUNK! ! Batch number F08R05E1. As I always fire up all cars after oil changes and observe the filter for any leaks, I know the filter did not leak initially. But the leak occured within 300 miles because that is what it has.
Fortunately a little oil goes a long ways, the oil was still way above the add mark, and I had a AA080 on the shelf for the STi, so the car is back on the road.
So hey vendors, I got three cars that need this filter, what do you have that works? I'll take this filter (and the others I bought with it) back to the dealer I got them from, but unless I see some sort of technical bulletin addressing it I do not want to trust another AA09A filter.
Judging from this thread others have had this problem. I'm lucky, , but Subaru had better address this.
Cheers!
NMLegacy is offline   Reply With Quote
Old 10-15-2005, 07:40 PM   #16
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
i checked in my parts dept today, and was informed that they knew about the bad filters and had pulled them from the shelf. they are still selling 09A's, updated i was told, and i changed the oil today with one. i'll check on it the next couple days and make sure everything is good. i hope the problem is fixed!
Old 10-15-2005, 08:56 PM   #17
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Originally Posted by NMLegacy
... I put the car on my lift...
Now *that* is a proper home garage!
Old 10-15-2005, 08:57 PM   #18
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
09A's will be the oil filter for the turbo from now until????
there was simply a batch with a kink or "dink" which allowed for this seepage.
those #'s affected have been recalled.
the replacement filters will be fine.
subaru is all over this issue right now.
Jamie
SubieGal Home
Old 10-17-2005, 06:26 AM   #19
Turbo20VJetta
Member#: 46004
05 Saabaru
Stage 2
Jamie
Yeah, but the stock unit is so freaking small!
I really can't see how the bigger AA060 is going to get that much hotting bering close to the exhaust. How long is the oil in the filter, a few seconds at most? Plus, it is white and not black.
Turbo20VJetta is offline   Reply With Quote
Old 10-17-2005, 09:22 AM   #20
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I'm just telling you what SUBARU has stated.
AA060's - (white) = we are not allowed to sell them for non turbo models.
AA09A (white) = turbo model oil filter
Jamie
Old 10-17-2005, 12:20 PM   #21
Turbo20VJetta
Member#: 46004
05 Saabaru
Stage 2
Jamie
Oh, I understand. I am just saying that I don't understand why.
Not sure why, but the stock filter on my Saabaru was black and very small.... I wonder if the tiny filter had something to due with my oil being rather dirty looking after 3,000 miles. Much more so than other cars I have owned.
Old 10-17-2005, 04:43 PM   #22
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
Jamie,
the description of the oil filters you posted seems to match the 6 filters i received a few weeks ago.
any suggestions on what i should do w/ them now?
ekw is offline   Reply With Quote
Old 10-17-2005, 04:47 PM   #23
cbr600f3
Member#: 55067
2015 Audi S3
Monsoon Gray
Originally Posted by Turbo20VJetta
Yeah, but the stock unit is so freaking small! .
This is the only case where size doesn't matter. Ability to trap particulate matter has little to do with the size of the filter.
cbr600f3 is offline   Reply With Quote
Old 10-17-2005, 07:26 PM   #24
Turbo20VJetta
Member#: 46004
05 Saabaru
Stage 2
I would agree with that but the small filter is going to get clogged up before the larger one with everything else being equal.
I worry about going 7,500 miles on something that is so freaking small when I go to syn. In reality is it an issue, I don't know....
Old 10-18-2005, 12:02 AM   #25
cbr600f3
Member#: 55067
2015 Audi S3
Monsoon Gray
^^yeah I don't think i have the stones to go 7500 though. I still change around 3500 with mobil 1.
Probably overkill but i loose about 1/2 quart until the next change anyway.
My First and *Last* Experience with Subaru's New Oil Filter DrewDeezy Service & Maintenance 36 02-02-2009 11:48 AM
Can you swap a 04 center console with a 05 center console? Details inside! 1FSTREX Interior & Exterior Modification 21 10-08-2008 07:39 PM
OEM Oil Filter-15208AA09A & 15208AA100: Button Service & Maintenance 2 09-25-2006 08:01 PM
My 05 STi leaked oil with the new oil filters SinisterMinister Warranty Issues & SOA Problems 3 12-29-2005 05:57 AM
What to do with used oil filters? Bottom Feeder Service & Maintenance 3 11-30-2001 05:09 PM
