Old 04-20-2007, 01:00 PM   #1
sshus924
Member#: 61172
2006 WRX STI
Rally Blue
Default Denial of warrantee
First Incident-
Make: WRX STi 2006
Mileage: 3,879
Time out of Service: 1 week
Problem & Probable Cause: Left rear end link broke; right rear end link bent in "U"shape. Had luggage in car and went over big dip in highway and not a rut or pot hole. The suspension seemed to bottom and heard a loud noise.
Submitted for Warrantee: yes
Reason for Denial: Dealer said I must of hit a huge pot hole or big crack in the road.
My Story: The endlinks are very flimsy given how the rest of the STi suspension is built. I replaced the factory ones with Cobb Billet Aluminum ones and have had no problems since. The part was definately defective as a design as others I know have had the same problem.
Second Incident-
Mileage: 6,800
Problem & Probable Cause: Oil leak from main oil line coming from Turbo and back into engine block. Pin hole found in oil line right before banjo fiting of line coming out of turbo. Defective oil line.
Submitted for warrantee: yes
Reason for Denial: Dealer said that line had been twisted and that is why it failed.
By Story:No one ever went near the oil line.
Modifications: Cobb Stage 2; Cobb Turbo back exhaust; Cobb lowering springs; Defi Gauges; Cobb blow-off Valve
sshus924 is offline   Reply With Quote
Old 04-20-2007, 01:50 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
It wasn't touched when installing the cobb turboback exhaust? I'd say they probably came to that conclusion since the car is modded and very likely someone was in there. had you been stock it would have been a different story.
Mavrik is offline   Reply With Quote
Old 04-20-2007, 02:18 PM   #3
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
If you're not stock then don't expect to get parts replaced under warranty. For example, the COBB springs lower the car too much so I don't blame the dealer for not covering the endlinks...although they were probably flipped during the install...very common. I don't know why people refuse to understand that you pay to play.
conker69 is offline   Reply With Quote
Old 04-20-2007, 02:35 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
I have seen rear sway bars installed incorrectly(it is easy to do) and damage the endlinks.
blackfang is offline   Reply With Quote
Old 04-20-2007, 02:39 PM   #5
Mavrik
Member#: 90347
Yamaha FZ8
flipped end links usually result in the vehicle sitting higher then stock in the rear.
Old 04-20-2007, 04:19 PM   #6
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
If you mod your car in any way shape or form you give the dealership just cause to deny you .
imprezzakc is offline   Reply With Quote
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 139 08-17-2015 06:02 PM
I bought a new car two weeks ago, I just got a denial of loan letter from some bank.. DeusExMachina Off-Topic 29 02-07-2010 07:55 AM
Denial of Warranty for Brakes (different than sticky) scoobynuts Warranty Issues & SOA Problems 17 03-22-2006 09:37 PM
Going out of warrantee inspection Alan B Service & Maintenance 2 08-26-2004 02:06 AM
For all of you guys with Dealership Denial issues. houston Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-23-2001 04:28 PM
