Old 10-27-2005, 05:46 PM   #51
shemoves
Member#: 80663
2005 STi
Originally Posted by todd_fuller
Is there someplace the specific serial numbers are documented? I bought two from my local dealer last weekend. They were aware of the problem with the filters and indicated that they pulled all the problem filters yet when I bought the filters they were F10 serial numbers. When I called back, they said that they were only selling the 'new' shipment from Subaru and they didn't know what serial numbers were effected. I'd like to get new filters but if I can't convince them the ones I have are bad, I don't think they're going to give me new ones!
If they are unused, just return them...have your reciept?
shemoves is offline   Reply With Quote
Old 10-27-2005, 05:47 PM   #52
shemoves
Member#: 80663
2005 STi
Hey Jamie, I still have a bunch of the old ones...Part # 15208AA100. Are the new ones better, or should I just use these up?
Old 10-27-2005, 05:50 PM   #53
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
if you don't want them i'll take them....
they're still good.
Bishop is offline   Reply With Quote
Old 10-27-2005, 06:02 PM   #54
timmah
Member#: 54203
2011 WRX
just went to dealer today, doing oil this weekend.....
stamp on top of filter says f10r19e1
should i take this thing back or what?
timmah is offline   Reply With Quote
Old 10-27-2005, 06:12 PM   #55
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Its been said like 403938495895 times that batch F10 is a bad batch.
cdvma is offline   Reply With Quote
Old 10-27-2005, 06:16 PM   #56
timmah
Member#: 54203
2011 WRX
argh.
the one time i decide to use an OEM oil filter, i get pwned.
Old 10-27-2005, 06:43 PM   #57
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
well, not really.....as Jamie has not posted the serial numbers from the "new" shipment from subaru. Maybe the new shipment is F10 as well, just different numbers at the end....
food for thought.
Drews_WRX is offline   Reply With Quote
Old 10-27-2005, 06:58 PM   #58
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Does nobody read this thread?
Originally Posted by Subie Gal
yes those ones are okay
F08, 09, 10 - - -according to Subaru
were the affected filters...
Jamie
check the serial ## on the filter.
if it has F08, F09, F10... it is NOT the updated one
hell.. we only just GOT the updated ones last week.
Jamie
Old 10-28-2005, 02:01 AM   #59
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Originally Posted by SubaruGenuineParts
UM....
actually the black version is much smaller than the 09A
When I put the two side by side, my white one (09a) was marginally taller (< 1/4") than the black one (100) and substantially narrower on the cross-section, looking down on the two filters as positioned in the pic above.
Subietonic is offline   Reply With Quote
Old 10-28-2005, 02:40 AM   #60
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
I think mine is leaking too... batch # starts with F07... I get out of my car and I can SMELL oil... this is BS... I'm pissed!
I like the black filters! If I knew they were going to do this I would have purchased 3 cases of them months ago... aRG!
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 10-28-2005, 01:02 PM   #61
shemoves
Member#: 80663
2005 STi
Has anyone cut open a 'good' new one yet to compare?
Old 10-30-2005, 04:00 PM   #62
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
I have an F09.. This thread should be a sticky! This is going back to the dealer next week.
Old 10-30-2005, 04:37 PM   #63
timmah
Member#: 54203
2011 WRX
i just got a purolater pureone. looks exactlye like the subaru one, except it has a better gasket design. i bet the gasket is the problem on the subarue ones. its really small
Old 10-30-2005, 06:30 PM   #64
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
From the descriptions above, it seems more like a problem in the metal shell; in any case, the PureOnes are nice filters, but do have a different bypass valve pressure setting than the OEM ones.
Old 10-30-2005, 11:53 PM   #65
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
do you have more info on the pressure setting, i am considering switching to pure one.
cnstman is offline   Reply With Quote
Old 10-31-2005, 12:39 AM   #66
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Does the different pressure setting really matter?
wrx2 is offline   Reply With Quote
Old 10-31-2005, 08:41 AM   #67
timmah
Member#: 54203
2011 WRX
i highly doubt it. you are certainly not going to blow up your car using a non-oem oil filter.
Old 10-31-2005, 09:21 AM   #68
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
No, but over time you may develop an oil leak because the pressure will eventually blow out the front engine seals. Alot of the cars we see with front engine seals leaking have aftermarket filters on them. This has also been proven by Subaru thru research. Thats why if you ask someone about the older Subaru's they will say they always developed oil leaks.
RexyGirl is offline   Reply With Quote
Old 10-31-2005, 10:13 AM   #69
timmah
Member#: 54203
2011 WRX
Is the pressure bypass REALLY that drastic? I mean, it's not like it's bypassing at all times. Cold starts and usually WOT runs when the pressure is building up quickly.
I just can't see a non-oem filter blowing up engines. Wouldn't crankcase ventilation (PCV, etc) have a part to play in this as well (seals).
And upon searching, I can find the PureOne bypass pressure. Can you provide me with the OEM bypass pressure?
Old 10-31-2005, 12:19 PM   #70
shemoves
Member#: 80663
2005 STi
Ehh, were you listening to rexygirl? it happens over time. Which means the difference is not drastic, but enough to cause a problem. And she did not say its gonna cause your engine to blow...just not run as well for as long. I definitely don't mean to be rude, but it seems that what she said "went in one ear and out the other."
Old 10-31-2005, 12:25 PM   #71
timmah
Member#: 54203
2011 WRX
I'm not one to just listen to word of mouth. Show me the hard proof, and I'll accept it :-)
I know what the pressure bypass PSI is for the PureOne, what is it for the OEM filter, also made by purolator?
Thanks
Old 10-31-2005, 12:46 PM   #72
shemoves
Member#: 80663
2005 STi
Thanks
Fair enough. I have no idea what the pressure is on the oem...what is it on the PureOne? Perhaps someone knows what the OEM bypass PSI is...? Hmm, this just made me think, I wonder if the pressure is different 'tween the old black ones and the new white ones.
Rexygirl...would you happen to have a link where we could look at the research (on related info) Subaru did?
Old 10-31-2005, 12:49 PM   #73
highdensity
Member#: 75145
1994 Toyota Camry
Junkyard Racing Green
IIRC, oem bypass pressure is 23 psi.
highdensity is offline   Reply With Quote
Old 10-31-2005, 01:30 PM   #74
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
The problem isn't the gasket, it's the way the filter case was clamped to the base, it leaks there.
drees is offline   Reply With Quote
Old 10-31-2005, 02:14 PM   #75
timmah
Member#: 54203
2011 WRX
According to Purolators site, the bypass pressure on the PureOne for the WRX is 14-18psi
My First and *Last* Experience with Subaru's New Oil Filter DrewDeezy Service & Maintenance 36 02-02-2009 11:48 AM
Can you swap a 04 center console with a 05 center console? Details inside! 1FSTREX Interior & Exterior Modification 21 10-08-2008 07:39 PM
OEM Oil Filter-15208AA09A & 15208AA100: Button Service & Maintenance 2 09-25-2006 08:01 PM
My 05 STi leaked oil with the new oil filters SinisterMinister Warranty Issues & SOA Problems 3 12-29-2005 05:57 AM
What to do with used oil filters? Bottom Feeder Service & Maintenance 3 11-30-2001 05:09 PM
