Old 11-03-2005, 11:05 PM   #101
timmah
Member#: 54203
2011 WRX
I have one sitting around.....how should I go about cutting this puppy open ?
timmah is offline   Reply With Quote
Old 11-03-2005, 11:32 PM   #102
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
well, you could poke a flathead screwdriver into the side and peel it open like a can, or you could hack saw it, or you could use an exhaust cutter (the kind withthe sharp cutter wheels) all will work. the screwdriver method is pretty easy though.
Jerry
00Maddog is offline   Reply With Quote
Old 11-03-2005, 11:33 PM   #103
JM530
Member#: 69212
'11 A3 Quattro K04
DSG Lava Grey
I just noticed seepage on my garage floor and I just got my oil changed earlier this week. Looks like I'm heading back to the dealer!
JM530 is offline   Reply With Quote
Old 11-04-2005, 09:05 AM   #104
timmah
Member#: 54203
2011 WRX
Jerry
I will give this a shot this weekend (I'm not bothering to return it to Subaru for 5 bux) and i will post up pics.
Old 11-04-2005, 09:21 AM   #105
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
are you guys trying to say that these new filters do not have a check valve?
afaik... all subaru OEM filters have a check valve.
i've never heard anything different
Jamie
Old 11-04-2005, 10:04 AM   #106
JRSCCivic98
Member#: 67080
Look inside Jamie... it does not look like it has one. We would love it if you'd consider calling SoA and asking the tech line directly though.
BTW, I just installed mine this morning so we'll see how it does. It did not leak uppon startup and idle after the change. All I know is that if something bad happens and is related to this filter SoA will replace my motor one way or another. I've been changing my own oil on all my cars since I could drive and have never had a problem due to a mistake in the process. Crap for that matter I know more about my car then the grease monkey that I see changing oil at the local Subaru place. You know they are noobs when they say they've never installed SS brake lines before.
Wouldn't it be funny if a class action lawsuite happens because of something as small as them being too cheap to provide a good oil filter.
JRSCCivic98 is offline   Reply With Quote
Old 11-04-2005, 11:21 AM   #107
SubaruGenuineParts
Member#: 82767
doubt that this seepage would cause a failed engine...
it's a little drip here and there...
not a gush of oil all over the place
SubaruGenuineParts is offline   Reply With Quote
Old 11-04-2005, 01:26 PM   #108
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
Originally Posted by Jfrankon
Jamie:
Do you offer the six pack o' turbo filters anymore? I can't find them on your site (only can find the non-turbo ones).
Thank you for keeping us all informed.
Am I the only one who can't find these filters? Please clue me in.
Jfrankon is offline   Reply With Quote
Old 11-04-2005, 02:02 PM   #109
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
The oil filter only leaks a little bit, and if it gets to the point that damage is done to the engine, then that is not Subaru's fault. You have an oil light to tell you that the oil is low, and you would notice the oil on the ground. If you continue to drive the car with little or no oil, then damage that occurs would be no one elses fault but your own. Even if the dealership does the oil change, you should know not to drive the car with no oil.
And just because they never installed SS brake lines does not make them a noob. Most dealerships do not install aftermarket components, and how may times have you heard that Subaru brake lines need to be replaced?
RexyGirl is offline   Reply With Quote
Old 11-04-2005, 02:08 PM   #110
BryanH
Member#: 993
Originally Posted by timmah
According to Purolators site, the bypass pressure on the PureOne for the WRX is 14-18psi
so if the OEM bypass pressure is 23 psi and the PureOne bypass is 14-18 what does that really mean?
Not to be stupid here but is the PureOne OK to use for the long term or is it letting to much pressure through?
BryanH is offline   Reply With Quote
Old 11-04-2005, 02:13 PM   #111
SubaruGenuineParts
Member#: 82767
Old 11-04-2005, 02:58 PM   #112
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
Thanks Jamie! Order placed!
Old 11-04-2005, 03:15 PM   #113
timmah
Member#: 54203
2011 WRX
Exactly what I am trying to find out.
Old 11-04-2005, 03:29 PM   #114
BryanH
Member#: 993
Great! If you get a good answer then we will both know...becuase the difference in price is peanuts...I just need to remember to order them from Jamie before my next oil change.
Old 11-04-2005, 03:29 PM   #115
JRSCCivic98
Member#: 67080
Girl, I check my oil level every week just to make sure all is well, but to allow a filter to be used that even has a slight leak is total BS on SoA's part. I mean common!!!... how many cars have you had that you just looked under at the oil filter, noticed some leaking and said... oh well, it's designed that way.
Oh and as for noticing oil on the ground... that's going to be a little hard with the undercover in place. There is plenty of channels in that thing for oil to drop into before it overfills and starts showing up on the ground. Do you really want to start making it a point to pull the guard down every week and check the seal on the oil filter. What the hell?
Point is... the old 100 filters didn't leak at all. New ones seem to leak (I'll tell you if mine does tomorrow when I have to crawl under the car again to check on this stupid filter just to make sure. I installed it this morning when I did the oil change. SoA are just cheap asshats to introduce such a crappy filter, but we won't be able to tell just how crappy it is until more of us use them and see how they hold up.
[middlefinger]Thanks SoA for adding yet another thing I have to keep watching from time to time!!![/middlefinger]
Oh and as for the "Oil light" thing... by the time that turns on it's already too late.
Old 11-04-2005, 03:31 PM   #117
BryanH
Member#: 993
VERY true. If the oil light comes on get our your check book and dont even bother stopping...your engine is already toast. Drive straight to the bar and have a drink!
Old 11-04-2005, 03:33 PM   #118
JRSCCivic98
Member#: 67080
AMEN brotha!
Old 11-04-2005, 05:00 PM   #119
RexyGirl
Member#: 63616
with mods :)
First of all, you are supposed to check your oil periodically, that's your responsibility.
Second, it's not supposed to be designed that way, a problem occured in production, Subaru caught it and is taking care of it. Subaru didn't make the filter, so don't blame them. They are doing what they can to correct the situation. If you bought an item at Walmart, and it was recalled, who would you blame? Walmart or the company that made the product? All this was was a bad batch that got out after production, and Subaru caught it.
I think you are taking this a little too far...your car is a machine, and crap happens...If your that unhappy with Subaru, go buy another car and see if they recall your oil filter when they discover there is a design flaw....Look how long it took for Ford to take action when the trucks were catching on fire, they were FORCED to issue a recall....
Old 11-04-2005, 06:36 PM   #120
Mycues1982
Member#: 86995
2005 Tacoma
Damn I just recieved a box of 12 of the defective filters , guess I'll be seeing about sending them back
Mycues1982 is offline   Reply With Quote
Old 11-04-2005, 06:44 PM   #121
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Yes, the PureOne should be fine to use. Since it has a *lower* bypass pressure than the OEM, it will *not* result in higher oil pressures than OEM.
Old 11-04-2005, 06:55 PM   #122
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Rexygirl, if I bought a recalled item at Walmart, I'd blame the manufacturer more, but it would also diminish my trust/image of Walmart. Walmart (Subaru) gets to choose whose parts they will sell; enough bad decisions on which vendor to use (which hasn't yet happened for Subaru) and the company's reputation will suffer.
Old 11-04-2005, 07:40 PM   #123
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
I agree with rexygirl and subigal (two of our vendor representatives) Subaru responded to the problem immediatly, and did a dealer recall. I personally applaud them for that. The fact that they leak a little will only be a small anoyance until the next oil change, not a threat to anyone's engine. If you ran a business the size of SOA what would've you done differently. Would you throw millions of dollars at an unfortunate short term annoyance? If you would, you wouldn't be in business for long. I think Subaru's response was appropriate.
Oh, and the oil light... It's there to warn you of a low oil condition. It will first come on when you are going around a corner and the pressure switch gets starved for oil then it will go out. That is certainly not too late, however it is a serious warning that means you need to put oil in as soon as practical. If it goes on steady that's a different matter, pull over and put oil in immediately. Still not too late, but don't ever drive with a steady oil light on...
Rocket's two cents...
STirocket is offline   Reply With Quote
Old 11-04-2005, 09:28 PM   #124
JRSCCivic98
Member#: 67080
Exactly the way I see it.
Old 11-04-2005, 09:35 PM   #125
JRSCCivic98
Member#: 67080
Originally Posted by STirocket
IIf you ran a business the size of SOA what would've you done differently...
I WOULD NOT have switched oil filter manufacturers from the Japan one to an American one so that the higher-ups (executives) could pocket even more money then they already make. Maybe I just value my car more then the average person, but I believe anyone who's a real "car person" would sympathize with me on this. I don't look at my car as a thing that gets me from point A to point B... to me it's like a family member. This is why if you mess with my car we're going to fight.
My First and *Last* Experience with Subaru's New Oil Filter DrewDeezy Service & Maintenance 36 02-02-2009 11:48 AM
Can you swap a 04 center console with a 05 center console? Details inside! 1FSTREX Interior & Exterior Modification 21 10-08-2008 07:39 PM
OEM Oil Filter-15208AA09A & 15208AA100: Button Service & Maintenance 2 09-25-2006 08:01 PM
My 05 STi leaked oil with the new oil filters SinisterMinister Warranty Issues & SOA Problems 3 12-29-2005 05:57 AM
What to do with used oil filters? Bottom Feeder Service & Maintenance 3 11-30-2001 05:09 PM
