South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 10-12-2005, 02:24 PM   #1
thrdeye
Member#: 24569
2011 Impreza WRX
Default What size washers do I need for banjo bolts on brake caliper?
Over the weekend, my caliper began leaking where the brake line screws in with the banjo bolt.
What size washers do I need for this, b/c now that the sun is setting early, time is of the essence and I'd like to just swing by advance auto after work and pick em up.
Any tips on keeping this from happening in the future? I've had the brakes and lines on there for 2 years without issue.
thrdeye is offline   Reply With Quote
Old 10-12-2005, 02:35 PM   #2
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
I don't think that regular washers will do. I believe they are a soft aluminum that kind of "seal" with the banjo fitting. I think I would just go to Subaru with this one.
dropmech is offline   Reply With Quote
Old 10-12-2005, 02:39 PM   #3
wilddave1
Member#: 9101
2005 Jeep Wrangler
Aprilia Tuono
Yeah, I think it's more of a crush washer/bushing. I'd get them form subaru. IMHO.
wilddave1 is offline   Reply With Quote
Old 10-12-2005, 02:40 PM   #4
thrdeye
Member#: 24569
2011 Impreza WRX
Yeah, I think that they are maybe brass. IIRC, one side of the washer has a square edge and the other is a rounded edge.....
Anyone else?
Old 10-12-2005, 03:21 PM   #5
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I thought they were copper.....
Then again, I haven't torn apart my brakes in quite a while.....
IronMonkeyL255 is offline   Reply With Quote
Old 10-12-2005, 03:24 PM   #6
thrdeye
Member#: 24569
2011 Impreza WRX
yes, copper. I figured that out with the powar of teh int4rw3b
Old 10-12-2005, 03:33 PM   #7
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
UM, take an old one down to your local AUTOZONE and have them check in their nut and bolts section(the one behind the counter.)
Pacobeagle is offline   Reply With Quote
Old 10-12-2005, 11:22 PM   #8
thrdeye
Member#: 24569
2011 Impreza WRX
Well, this is why the caliper was leaking. It must have just been threaded in there on imagination. IS THIS FIXABLE? CAN IT BE RETHREADED, ETC?
Old 10-12-2005, 11:42 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....don't think so unless that was one with the 8mm nut....then ya might be able to get the one with the 10mm nut and use that one.....dunno the actual thread size
Old 10-12-2005, 11:49 PM   #10
thrdeye
Member#: 24569
2011 Impreza WRX
Old 10-12-2005, 11:50 PM   #11
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Actually....maybe....theres some things called Threadserts...(Helicoil) for this app...
Chris..you will have to find a DECENT Bolt Store...not home depot...not Advance...
Maybe Napa...but doubtful...
You need to find a SPECIALTY Nut and BOLT STore...should be listed in the yellow pages......Asheville has one..called ASHEVILLE NUT AND BOLT...and have Thousands of fasteners...as well as the hi end helicoil kits...
Hope that helps..
Hi Scotty..
Bill
Old 10-12-2005, 11:51 PM   #12
thrdeye
Member#: 24569
2011 Impreza WRX
It's amazing that ist's been this way two years....and just now shown a problem....
Thanks Bill!!! I took a personal day to fix this tomorrow.
Old 10-12-2005, 11:52 PM   #13
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Those are the ones...
specifically...
Here
Bill
Old 10-13-2005, 12:07 AM   #14
thrdeye
Member#: 24569
2011 Impreza WRX
Anyone know what size it is? i believe that it is the stock WRX banjo bolt.
Old 10-13-2005, 12:39 AM   #15
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Chris -
I've used the Helicoil stuff a few times now (I/C holes for the BOV, swaybar mounts, and the bolt holes for my seat) and they've been rock-solid. They've been lifesavers for sure. Hope you get it fixed tomorrow dude
Keep us posted...
Hank3 is offline   Reply With Quote
Old 10-13-2005, 01:13 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
....I believe that a special helicoil is necessary for this type of application.....make sure ya get the right one.
Old 10-13-2005, 08:02 AM   #17
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
I believe that the thread pitch is something like 1.0mm versus the regular 1.25mm pitch. It's a fine thread pitch for sure.
Old 10-13-2005, 08:29 AM   #18
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Let me check the manual for you Chris...maybe it will give the diminsions of the bolt
Bill
Old 10-13-2005, 09:20 AM   #19
thrdeye
Member#: 24569
2011 Impreza WRX
Bill
Thanks man. I wish you were still around here!
Thanks for all the help from everyone else as well.
Old 10-13-2005, 10:02 AM   #20
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
bolt is 10mm x 1.0 thread pitch
Bill
Old 10-13-2005, 12:16 PM   #21
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
HA, told ya. hee hee hee hee hee. Hope you get it back together.
Old 10-13-2005, 01:28 PM   #22
thrdeye
Member#: 24569
2011 Impreza WRX
Well, i'm making progress. We'll see how in goes when i put the new coil in
Old 10-13-2005, 03:19 PM   #23
thrdeye
Member#: 24569
2011 Impreza WRX
I think I Got R Done
Old 10-13-2005, 03:22 PM   #24
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Old 10-13-2005, 03:50 PM   #25
thrdeye
Member#: 24569
2011 Impreza WRX
Bill,
again. I really appreciate you man. You were my first "scooby friend" I would say....way back when we did the up pipe in the thunderstorm at your house.
What size hose do I need for..... Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-16-2008 05:27 PM
what size wrench do i need for this top bolt? 04 sti rear diff skewbnewb Transmission (AT/MT) & Driveline 10 05-02-2008 11:26 AM
What size wheel would i need for sti front brakes jakesurfin Brakes, Steering & Suspension 1 04-19-2008 09:25 AM
quick one: what size washers do i use for the lower brace with an ALK? sigma pi Brakes, Steering & Suspension 8 03-22-2005 02:15 AM
What size wrench do I need for the O2 sensor? Rich10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-31-2004 04:31 PM
