Closed Thread
Old 10-12-2005, 08:17 PM   #1
wuuusaa
Member#: 92894
2015 Wrx
Default Strongest Block?
Does anybody know what was the strongest block Subaru ever produced and that can handle the most boost stock?
Thanks Alex
wuuusaa is offline
Old 10-12-2005, 08:39 PM   #2
bmxpunk
Member#: 89599
1995 almost 22B:)
red
If I am not mistaken an i could be it would be our blocks, the ej22t. But there are also 2.0 liter closed deck blocks found in japan and europe.
bmxpunk is offline
Old 10-13-2005, 06:13 AM   #3
BlackSun
Member#: 93591
2007 WRX STi Limited
UGM
I've been told the same thing.... The Leg 2.2 is the strongest stock block... DynoComp tuned a 2.2 with a Garret rotated mount turbo on 100 octaine gas at 400 to the tires! Great block in my opinion, and I have an STi!
BlackSun is offline
Old 10-13-2005, 06:32 AM   #4
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
The EJ22T out of the 91-94 turbo Legacy's is a closed deck block, the EJ20 from the Ver3 (I think) Spec C is closed deck also. These are the only 2 closed blocks Subaru produced that I know of. I have heard of a 2.2 taking 30+ psi on completly stock internals with a little over 150K miles.
spoolinsuby is offline
Old 10-13-2005, 08:47 AM   #5
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
The overseas 1st gen Legacy/Liberty turbos had the EJ20G which is closed deck as well. The v1/v2/v3 blocks were all closed deck too, IIRC. The 22b also has a closed deck block that is very similar to the EJ22T block but varies slightly.
legacy92ej22t is offline
Old 10-13-2005, 03:06 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ej22G -22b block(uber rare) the ej20G legacy RS and V1.V.2 (not v3) and usdm ej22T
Jaxx is offline
Old 10-13-2005, 03:55 PM   #7
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
Oh ya, that's right. V3, MY97, was the year they dropped the closed deck. My bad.
Old 10-13-2005, 04:26 PM   #8
legacymaximus
Member#: 98451
94 legacy TW
I have heard that the closed deck 2.0's forge is not as strong(dense) as the 2.2 closed deck's forge and also does not have the oil squirters. This has been talked about before by Zephyr but i couldn't find the link but there is a lot of good info. It might be over on legacycentral now that i think about it.
-max
legacymaximus is offline
Old 10-13-2005, 06:51 PM   #9
bluice
Member#: 74718
2000 Impreza 2.5RS
burgundy
Default close deck
i believe all EJ20G/EJ22G made in '94 and earlier were all close deck. correct me if im wrong.
bluice is offline
Old 10-13-2005, 07:17 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
-max
Max,
He was comparing it to the other more modern open deck blocks. The EJ20G closed deck blocks use the same medium pressure casting method that the Ej22T blocks used. They have the same cross hatch marks on the blocks. And they have under piston squirters. Both of mine do...
And Mark is Xephyr, not Zephyr. Maybe why your search didn't bring up that old thread? But you are correct, quotes from it are stickied at the top of the engine forum on Legacy Central...
But one needs to be careful when block shopping, after MY94, all non-sti blocks, Legacy and WRX went open deck. I know of one member who recently got an Ej20G from a Legacy that he thought was closed deck, and he pulled the heads to find it open. He had been led to believe it was a '91, but when I ran the applied engine code for him, I found it to be later...
Matt Monson is offline
Old 10-14-2005, 03:36 AM   #11
napphappy
Member#: 56170
95 Impreza L
Ugly
Keep in mind the STi closed deck blocks, including the RS-RA will be stronger due to the forged pistons.
napphappy is offline
Old 10-14-2005, 09:13 PM   #12
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
i have 2 ej22t that have piston oil squirters in the cases.
jaxscuby is offline
Old 10-15-2005, 01:58 AM   #13
LibertyEJ22T
Member#: 69198
I have 2 EJ22T also right now, haven't really torn these down though. One of them has about 160k and the other one only has 80k. If I had extra cash I'd just keep buying them up and freshen them up for resale. I love this engine for it's superior durability.
LibertyEJ22T is offline
Old 10-15-2005, 02:02 AM   #14
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
They just need to be screwed back in.......
reddevil is offline
Old 10-15-2005, 02:41 AM   #15
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
crossposter!
00Maddog is offline
Old 10-19-2005, 12:00 AM   #16
Guru Imakuni
Member#: 58773
Does that mean you could bolt on a bigger turbo and put in some larger injectors and just run it like that?
Guru Imakuni is offline
Old 10-19-2005, 10:09 AM   #17
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
...you'd need to tune it, obviously. A lot of people on the LegacyCentral.org forums just crank their tiny turbos on their stock engines with no management. I don't hear much about them blowing up but a tiny turbo blowing very hot air into a stock motor at ~16 psi, with a MAF sensor that maxes out around 11psi, is a receipe for knock. Knock will bring down the strongest of engines (even an SRT-4).
DeusExMachina is offline
Old 10-19-2005, 11:42 AM   #18
Guru Imakuni
Member#: 58773
Tuning is what seperates the men from the blown motors. Just wondering because someone in OT linked an eBay listing to a Legact turbo that I last saw going for $~450, plus it's like 15 minutes away. So turbo and injectors vs. wrx swap. Hmmm...
Old 10-19-2005, 01:33 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
Noone, here or on Legacy Central is running 30psi on stock heads. There is just no point. The heads don't flow enough for really big turbos. If you want to run a big turbo on an Ej22T block, you want to change the heads to Ej25 or Ej20 heads. Do a search in the AFI forum for HOK, Wedge, No-Coast-Punk, Xephyr and Drac9 to see a few of the set ups that have been run. Those are all 400+hp cars.
Old 10-19-2005, 02:14 PM   #20
thomez
Member#: 90921
2004 STi
PSM/charcoal BBS
I read that the limit on stock rods was about 30psi, but wouldn't it matter much more on the HP of the setup rather than strictly the amount of boost?
that makes no sense to me... the limit on stock internals must be HP related rather than boost, right?
I am looking for one of these motors right now for possible use later in my car
thomez is offline
Old 10-19-2005, 05:28 PM   #21
Guru Imakuni
Member#: 58773
I've got ej25 heads last I knew so that's cool! I was reading over on Legacy Central and I think it brings down the compression ratio to like 7.xx:1 with ej25 heads. Are the ej22t motors really rare? I ask because at this moment a high output ej22 is pretty useless when I have an RS transmission and the reason I looked at this swap was because the Legacy Turbo was cheap (it's at $812 right now with 29 hours left). An ej20 would probably be more suited for my needs since (especially considering this car is likely to sell for over half the cost of a well budgeted WRX swap) there's more available information out there for it and tuning is easier for it with ECUTek and the likes. I think.
Old 10-19-2005, 08:48 PM   #22
thomez
Member#: 90921
2004 STi
PSM/charcoal BBS
are all of the Legacy's from 91-94 turbo 2.2's or are some of them NA 2.2's ??
just curious as I look for a car/motor
thomez is offline
Old 10-19-2005, 11:12 PM   #23
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
90-94 Legacy motors were available in both NA and Turbo version. The block was the main difference (closed versus open), but they also differed with low compression factory forged pistons and they also came with 370cc versus 270cc (or something close to that) injectors. The heads were different but interchangable to a point.
However, and a big however, is that the NA 90-94 blocks had the same crank and rods as the turbo models. The NA block has no trouble taking modorate boost (as far as I have seen). I doubt the NA block could take 30 psi, but I plan on taking mine up to 12-15 if I get the money. Currently I am running 8 psi and expect no failures due to the bottom end. I "destroyed" an 220,000 mile NA motor twice where the pistons broke and shattered and yet the bottom end was fine. Even after I drove it without water for over 20 minutes (melting all plastic touching it) it still drove fine when refilled with water and new oil (although something had obviously warped). They are strong motors.
reddevil is offline
Old 10-20-2005, 03:03 PM   #24
wuuusaa
Member#: 92894
2015 Wrx
Hey Thanks So Much Guys, You'll Were All Very Helpful.
Gracias Alex
wuuusaa is offline
Old 10-20-2005, 03:54 PM   #25
Matt Monson
Member#: 832
99 2.5RS, '85 911
Actually,
The turbo blocks use moly coated cast pistons, not forged. But they are still a high quality piston.
And the FSM lists different part numbers for the Turbo vs NA cranks. I have never compared them side by side to check the differences. But my best guess is that the turbo crank gets a bevelled edge like the EJ20G cranks got. But they are both forged cranks...
Closed Thread
delete sense of nature MWSOC Private Classifieds 7 06-23-2010 12:11 PM
block alignment pins Legacy777 Private 'Wanted' Classifieds 2 06-02-2010 03:47 PM
GF8 STI block of the engine Mirone Car Care & Detailing 2 06-02-2010 08:35 AM
What car has the strongest stock block and tranny? disque71 Off-Topic 88 05-18-2006 04:01 PM
Strongest block ever produced? wuuusaa Alaskan Impreza Club Forum -- AKIC 11 10-13-2005 06:08 PM
