Old 10-13-2005, 02:01 AM   #1
colombo140
Member#: 97790
2008 STi
Default 2.0 WRX, What gas to use?
So I just bought a WRX. It didn't have the owners manual with it. I was wondering what grade gas should I use? What does Subaru suggest? I put premium in tonight and it seemed like it was running a lot smoother but I don't know if I'm just mental or if it actually does help it. Thanks all.
colombo140 is offline   Reply With Quote
Old 10-13-2005, 02:07 AM   #2
dust12
Member#: 13417
91+ is recommended by the owners manual. It actually does help.
dust12 is offline   Reply With Quote
Old 10-13-2005, 02:09 AM   #3
Sports Wagon
Member#: 43081
91+ is not only recommended but required. It does say you can use lower grade but only if no other alternative is there. Emergency use only.
Sports Wagon is offline   Reply With Quote
Old 10-13-2005, 02:12 AM   #4
colombo140
Member#: 97790
2008 STi
Sweet! Thanks to both of you! I'm glad I found that out before I put any real miles on her.
Old 10-13-2005, 02:36 AM   #5
hondaeater69
Member#: 60324
I use 94 which is the higest i can find at the pump around here. I would recommend the same.
Old 10-13-2005, 03:44 AM   #6
hotrod
Member#: 14141
2002 Impreza WRX
Where you live, in hot summer weather run the highest octane you can find locally.
The engine needs extra octane in very hot weather to give its best performance.
If your into that sort of modification, WI is very effective in the desert southwest.
Larry
hotrod is offline   Reply With Quote
Old 10-13-2005, 03:59 AM   #7
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
hmm...if your car is running a lot smother now, it makes me wonder what the previous owner used. Low grade gas can kill compression and eventually kill the engine...literally.
I'd suggest getting an owners manual cause it come in handy a lot.
Enjoy your new ride!
wrxskier18 is offline   Reply With Quote
Old 10-13-2005, 04:06 AM   #8
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
yes high octane is worth the money. i only wish i could get 91+ in alaska, our gas is worse than cali's.
00Maddog is offline   Reply With Quote
Old 10-13-2005, 12:20 PM   #9
colombo140
Member#: 97790
2008 STi
Larry
Larry,
Whats this WI? I've never heard that before.
Old 10-13-2005, 12:22 PM   #10
colombo140
Member#: 97790
2008 STi
Honestly I have no idea what the guy ran in her but I've put about 800 miles on it since I got it and the initial tank was 93. After that I was using the cheap stuff since it was almost $3 bucks a gallon even for the crap and I just didnt know any better. Thanks for your input and everyone elses too.
Old 10-13-2005, 12:36 PM   #11
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Originally Posted by colombo140
Larry,
I'm assuming he talking about water injection. Do a search, tons of info.
drivin blind is offline   Reply With Quote
Old 10-13-2005, 01:00 PM   #12
disque71
Member#: 57330
2008 WRX
91-93...i prefer 93
disque71 is offline   Reply With Quote
Old 10-13-2005, 01:07 PM   #13
BrentS
Member#: 96601
2004 WRX
I use 93. Some local Sunoco stations carry 100 at the pump. That will really get your car running!
BrentS is offline   Reply With Quote
Old 10-13-2005, 01:11 PM   #14
kcook
Member#: 78074
2005 STi
hey buddy when u go to fill up gas, look on the inside of the gas door. mine says premium only
kcook is offline   Reply With Quote
Old 10-13-2005, 01:16 PM   #15
AphexDouble
Member#: 96427
2010 Legacy 3.6R
Pearl White
where do you get 93? Anyone is SoCal?
AphexDouble is offline   Reply With Quote
Old 10-13-2005, 01:31 PM   #16
el_banano_wrx
Member#: 98428
2003 WRX EJ20T
dark yellow
If I used c16 (116 Oct) will be better or worst on my stock wrx??
el_banano_wrx is offline   Reply With Quote
Old 10-13-2005, 01:38 PM   #17
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Wont make a difference.....car is tuned for 91/93 only./
mcowger is offline   Reply With Quote
Old 10-13-2005, 01:47 PM   #18
dust12
Member#: 13417
In a different state
Old 10-13-2005, 02:38 PM   #19
StealthfishWRX
Member#: 57473
04' REX (RETIRED)
always use the best, TEH BEST! ALWAYS!
StealthfishWRX is offline   Reply With Quote
Old 10-13-2005, 05:07 PM   #20
colombo140
Member#: 97790
2008 STi
Awesome... Thanks.
Old 10-13-2005, 05:14 PM   #21
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
/87 FJ60 /Hewes Redfisher
in most cases the higher the octane the better
quadturbowrxgtr-s is offline   Reply With Quote
Old 10-13-2005, 05:15 PM   #22
Blackboxracing
Member#: 90106
If you use c16, (tuned for c16 of course) will you sacrifice the life of you stock motor??
How much more power could you expect to make on c16 (with tune) with an 18g, full exhaust, and supporting mods (including the present tune for 93)?
Blackboxracing is offline   Reply With Quote
Old 10-13-2005, 05:28 PM   #23
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Sacrafice the life of the motor? Not if well tuned for it.
As for your second question, the Proven Power forum would be better.
Old 10-13-2005, 11:47 PM   #24
hotrod
Member#: 14141
2002 Impreza WRX
Yes WI == water injection (see also alcohol injection) lots of posts in these forums.
Great way to increase effective octane.
You can get significantly more power out of C16 but it is a leaded fuel and hard on your O2 sensor (not to mention expensive).
The likes and will use higher octanes to a point. The performance difference expecially in hot weather and heavy load/boost between 91 octane and 93-94 octane is pretty noticable, mostly in midrange torque as the engine generally ends up pulling timing in that area first. I have used 100 octane unleaded in the summer with good results, the car loves it but my wallet does not.
I am now experimenting with E85. (search --- serveral threads here too)
Larry
Old 10-14-2005, 01:17 AM   #25
xplcitcustmz
Member#: 82935
1972 Ford pinto
Astro Turf
a tune from 94- 116 could yield 100+ horsepower. but thats on a tune, on just a standard car, their is not a huge difference, you will notice more low end power
xplcitcustmz is offline   Reply With Quote
2.0 WRX (2004 4EAT) to 2.5 WRX (2006 4EAT) - worth it? fuzzymemory Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-18-2007 11:44 AM
290-300 WHP 2003 2.0 WRX...What turbo? FastInMass Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 87 08-29-2006 05:04 PM
290-300 WHP on 2.0 WRX...What Turbo??? FastInMass Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-27-2006 08:43 PM
Now What Gas to use? worx Tri-State Area Forum 42 05-04-2006 08:14 PM
What gas to use in your STi? Sothoth STi Forum Archive 24 03-28-2003 09:09 AM
