Welcome to the North American Subaru Impreza Owners Club Tuesday October 21, 2014
Old 10-13-2005, 02:26 AM   #1
woody77
Member#: 94498
2004 Impreza WRX
San Remo Red
Default Stock (?) MY04 WRX pulling 12psi+ in 1st gear.. that's not good, right?
We picked up our WRX used with 35K miles. Due to the pattern of missing plastic rivets, it's definitely been modified, and "placed back to stock" before sale.
In diagnosing some roughness in the way it builds boost (especially when hot), I hooked up a cheap vacuum/boost test gauge, and WOT in 1st I was pulling well over 10psi (hard to pay a lot of attention while driving).
I was informed that an MY04 limits boost to 7psi in 1st, 10psi in second, and 14? in the rest of the gears.
I did a couple test runs today with an OBD2 logger, and they confirmed the results of the test gauge:
1st: 12.6psi (~5200rpm)
2nd: 13.5psi (~5200rpm)
3rd: 13.9psi (~3000rpm) <- shortly aborted right after I my 2->3 shift as I ran out of even remotely straight road for the speed I'd hit.
And in case I've done the conversion from inHg absolute to psi relative, those are (obd software claims 0inHg is absolute vacuum, I converted from inHg to psi (*.4912), and then subtracted off an atmosphere (-14.695595)
55.7inHg
57.4inHg
58.3inHg
From this, either the "boost limits" aren't limits but "expected" values for level driving (this was an uphill run), or something's not right with the car.
I've also noticed that it seems to spike boost a bit on throttle tip-in, especially over 50% throttle in 3rd or 4th gear. Quickly running up to full boost, dropping to 10ish, and then with a hair more, back to full boost.
Logs agree with that, 65% throttle and 12+ psi built up, then dropping and back to 12+ again as the revs go up.
Idle appears to be 12.2% throttle, and WOT 78% throttle. With the logger in real-time display, I can hold the throttle at the 78% mark, and put the pedal another inch to the floor, and lift it again, and no change from the 78% mark. It's odd.
At this point, I'm trying to figure out if the car is stock or not. Either way is fine, so long as I know WHAT was done to it, so that when I get detonation again (like I did monday) I'll have a better idea as to the cause aside from assuming it's OL/CL delay.
Nothing in the engine bay LOOKS modified, but if it was a non-flashy part, I'd not be able to tell in the first place.
woody77 is offline   Reply With Quote
Old 10-13-2005, 02:33 AM   #2
eric94501
Member#: 61686
2004 WRX
The first gear seem alittle high but still in stock range to me.
eric94501 is offline   Reply With Quote
Old 10-13-2005, 02:56 AM   #3
hondaeater69
Member#: 60324
boost levels look fine to me
Old 10-13-2005, 06:32 AM   #4
ChrisWRB
Member#: 41945
2004 WRX Sport Wagon
Yeah they look fine to me, too.
ChrisWRB is offline   Reply With Quote
Old 10-13-2005, 06:36 AM   #5
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
My friends 03 wouldnt make more than 8 psi in first and the dealer said that was normal to help save the tranny from the 1-2 shift.
spoolinsuby is offline   Reply With Quote
Old 10-13-2005, 09:24 AM   #6
02subadrew
Member#: 63083
MBP
one thing you might want to look into is the 3/16s mod...he/she may have done that and left it in there. big long debates about that mod, but the general consensus is bad. i tried it a year ago and got spikey boost so im back to the stock restrictor.
http://forums.nasioc.com/forums/show...ght=3%2F16+mod
just something to check for
02subadrew is offline   Reply With Quote
Old 10-13-2005, 09:24 AM   #7
Celly
Member#: 48724
The boost numbers look normal for an 04. If there is a bit of jittery boost, or over boosting, check to see if the 3/16th mod was done to this car. [Search, there is TONS of info on this..] 3/16th + 04/05 = Bad. Bad. God forbid if they had a MBC on there before you bought it...
Lower boost in 1st is normal. if you look at any EM, one of their FIRST selling points is "Full Boost in 1st gear". IIRC 10-11 is normal on a stock 04.
Also, Make sure you read up on the 04/05 OL/CL [Openloop Closed Loop] Issues with the ECU. Ok, they are not issues, but make the car act a little "Funny" to where you think you have a problem.. i.e. There are 1000 posts in this forum that say "04 WRX! POWER SURGE @ 4500RPM!!!!!!"
Good Luck, Enjoy!
Celly is offline   Reply With Quote
Old 10-13-2005, 09:29 AM   #8
TurbojonLS
Member#: 38772
2 Cars, No Bling
I made full boost in 1st when I was stock, as did other people I know w/ 04s. Nothing to worry about.
TurbojonLS is offline   Reply With Quote
Old 10-13-2005, 12:40 PM   #9
el_banano_wrx
Member#: 98428
2003 WRX EJ20T
dark yellow
the boost is secuencial you will reach full boost in 4th gear
thats where the car needs the most tork
thats wy you should set your boost control in that gear
el_banano_wrx is offline   Reply With Quote
Old 10-13-2005, 01:38 PM   #10
StealthfishWRX
Member#: 57473
04' REX (RETIRED)
i get the same when it was stock.
StealthfishWRX is offline   Reply With Quote
Old 10-13-2005, 01:39 PM   #11
timmah
Member#: 54203
2011 WRX
umm..
you are dead wrong.
that is all.
timmah is offline   Reply With Quote
Old 10-13-2005, 01:51 PM   #12
woody77
Member#: 94498
2004 Impreza WRX
San Remo Red
Thanks for the replies.
I'll check the hose for the 3/16th mod (I know where to go looking for it), and am also familiar with the OL/CL issue (spotted that in some of the logging as well), and am currently thinking that the det issue is OL/CL delay (I was romping on it from a light, and pulling hard in 2nd, heard the gravel..
This is good, I'll not be worrying about it much then, and continue to save up for the EM that I plan on putting in soon (if nothing else than to smoothen out the power).
So the boost limits in 1st/2nd aren't super hard, but can spike over those levels due to lag in the control loop for the wastegate? Or is it supposed to be a hard line somewhere? 1st goes by in a mighty hurry...
Old 10-13-2005, 06:53 PM   #13
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
my 05 has no differential in boost from certain gears, it hits almost 14 in each gear, obviously in 1st, not as long but mine is an 05 with only a TBE.
EagleRockWrex is offline   Reply With Quote
Old 10-13-2005, 07:24 PM   #14
waktasz
Member#: 86356
Maybe I'm way off but I don't think they are limited. It is just a by product of engine load and the amount of time you are in 1st gear...not enough time to build full boost...the car isn't holding back in boost on purpose.
waktasz is offline   Reply With Quote
Old 10-13-2005, 07:31 PM   #15
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
Exactly. The car isn't limited to any boost by gear. Find a steep hill and you can get full boost easily in first.
My suspicion is that he adjusted the wastgate actuator to hold tighter, which helps in lower gears.
Tom
SlideWRX is offline   Reply With Quote
Old 10-13-2005, 07:32 PM   #16
woody77
Member#: 94498
2004 Impreza WRX
San Remo Red
That makes sense, I just thought that part of what the Cobb AP did was remove the low gear limits on boost... maybe just the retune from the flash makes it hit higher boost in the low gears due to a faster spool-up...?
Old 10-13-2005, 07:33 PM   #17
woody77
Member#: 94498
2004 Impreza WRX
San Remo Red
Tom
0 wiggle on that when the engine's off. Tight enough that I can't move it with fingers...
Old 10-14-2005, 09:15 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Tom
^^^ 2nded.
ride5000 is online now   Reply With Quote
Old 10-21-2005, 09:47 PM   #19
woody77
Member#: 94498
2004 Impreza WRX
San Remo Red
Originally Posted by ride5000
^^^ 2nded.
This going to cause any problems, or is ok?
Old 10-22-2005, 08:42 AM   #20
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it's fine, woody. enjoy the extra torque in the lower gears.
just be sure to shift out of 1st quick enough so that you don't hit the revlimit!
Throttle not releasing in 1st gear after WOT, AP STG2 93oct 06 WRX ShagnRS AccessPort 50 11-25-2006 05:50 PM
Stage 4 hitting just 12psi in 4th gear... gopsu AccessPort 3 06-16-2006 01:47 AM
That's not good MGXsport North West Impreza Club Forum -- NWIC 28 03-27-2006 12:02 PM
Not much torque in 1st gear on 2005 RS driver Transmission (AT/MT) & Driveline 6 12-14-2005 11:05 PM
How much PSI on stock turbo in 1st gear? Roswellj07 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-13-2003 08:05 PM
