Old 10-13-2005, 10:21 AM   #1
shinigami_85
Member#: 96741
Default beast
i want to build an unholy beast of a subaru engine, but the problem is that i havent worked with subaru's that much so i dont know too much about them, can anyone help me out with some ideas for a setup?
shinigami_85 is offline   Reply With Quote
Old 10-13-2005, 10:27 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
an idea would be a search, honestly though its all been covered, not sure of your goals. give us an idea.
an unholy beast of an engine would be a 2.5 liter with forged pistons and Cosworth heads IMO, that would be a setup good for 500+whp easy.
Ben
Old 10-13-2005, 12:23 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
you might also get new rods too if you want reliable power
i guess some peoples fininite <sp?> element analysis shows that the rods arent near as strong as everyone thinks, granted there are people making 700hp with them...but if a rod goes...the entire block goes...and thats a spendy fix
Old 10-13-2005, 03:11 PM   #4
shinigami_85
Member#: 96741
thanks, i'm thinking around 450 or 500, i want it to be streetable...
Old 10-13-2005, 03:49 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
wheel hp or crank hp
Old 10-13-2005, 04:14 PM   #6
shinigami_85
Member#: 96741
to the wheels brother... but i think the guys at crawford said that would be too much for the street...
Old 10-13-2005, 04:19 PM   #7
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Swap in an STi shortblock or just get an STI engine, then go with a 20g turbo setup with a nice aquamist WI setup and run that with 30% methanol 70% water, tune it and be happy,
But if your starting with an RS be ready to fix a bunch of other things after aquiring such power.
Sko is offline   Reply With Quote
Old 10-13-2005, 09:20 PM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
How much do you want to spend? $5k $10k? More?
Old 10-13-2005, 11:48 PM   #9
shinigami_85
Member#: 96741
i'll have about 15 thousand when i start.
Old 10-14-2005, 01:03 AM   #10
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
With the ease of finding OEM turbo engines now, anybody who embarks on an FI build of an NA engine is beyond foolish. Do a swap and be done with it.
no-coast-punk is offline   Reply With Quote
Old 10-14-2005, 08:31 AM   #11
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
MY BEAST LIST:
-EJ257 Shortblock
-Darton Wet Sleeves
-Forged Pistons (8.5:1)
-Forged Rods (w/ COBB coated bearings)
-Cosworth Heads (w/ oversized sodium filled exhaust valves, springs & titanium retainers)
-STI Cams (regrinded)
-Cometic gaskets
-ARP Head Studs
-850cc Injectors
-2006 Ported Intake Manifold (w/ larger custom mounted throttle)
-Pulleys (of your choice)
-GT35R
-STI: Crank, Oil Pump, Water Pump, Timing Belt, etc...
-FMIC
-Standalone ECU of your choice (AEM, Tec3, MicroTec, Wold 3d, etc...)
I might be forgetting a couple of things but basically you have a 600-700 WHP engine with this setup. Ad some NOS and you might see 800 WHP...
Of course you better throw in a 6M STI transmission and reinforced axels.
hope this helps.
pd.- I'm currently working on a "similar" setup for my RS
Mariano is offline   Reply With Quote
Old 10-14-2005, 09:22 AM   #12
shinigami_85
Member#: 96741
is cosworth a company? and what is a gt35r?
Old 10-14-2005, 11:04 AM   #13
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Originally Posted by Mariano
MY BEAST LIST:
-EJ257 Shortblock
-Darton Wet Sleeves
-Cometic gaskets
-ARP Head Studs
-850cc Injectors
-GT35R
-FMIC
hope this helps.
Everything else was right, except the injectors are too small for 600 hp. There slightly bigger than 400hp.
Old 10-14-2005, 02:01 PM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
youre very wrong
jesus everyone is so injector happy
342whp on a MUSTANG DYNO
i hit like 82% idcs on race
for my 319 i think i hit 90% or something, on 650s!! with stock fuel pressure!!
Old 10-17-2005, 11:42 AM   #15
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
1-Cosworth is a brand... for more info http://www.fastwrx.com/cocyhe2tu.html
2-A GT35R is a Garrett ball bearing turbo with nice top end power... although I would probably use a GT40R... more info http://forceinductionracing.com/gt40r.html
Just to clarify, 850cc's IS ENOUGH to get to 600-700 whp... Trust me I might not have a guru tittle under my name (cause I'm to lazy to post) but being member #56 gives me a little credibility
Old 10-20-2005, 05:29 PM   #16
shinigami_85
Member#: 96741
just an update, i have been researching and this is the setup that i have come up with.
ej20 (solid deck) bored to a 2.5l
sti version 8 heads
crawford 2.5 pistons (forged)
crawford 2.5 pauter forged rods
crawford 84mm billet crank
cp35r turbo kit
act hd 6puck clutch
act xact 10lb fly wheel
i also bought an apexi safc, turbo timer, and a sitc
i plan using an sti version 8 wiring harness and ecu...
what do yall think?
Old 10-20-2005, 06:37 PM   #17
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Just because you did a swap,dosnt mean anybody that doas somthing diffrent is foolish! Your foolish for thinking your smarter than others by putting a bone stock engine in your car over a pro built motor and paying about the same heck that gets two Take that SheeeeeeeeeeT back too the conversion forum...you get no love in the AFIP!
S.Pete
Sneeky Pete is offline   Reply With Quote
The blue beast is now the graphite beast !!! Im Back ! DannyGT Tri-State Area Forum 46 01-27-2004 02:55 PM
('93-'01) Goodbye sweet blue beast, goodby [email protected] Impreza Forum 8 06-20-2001 07:49 AM
KC: who has the spiffed up Sedona beast up North? ChosenWon Mid West Subaru Owners Club Forum -- MWSOC 5 03-22-2001 11:51 AM
Sighting: SD 163S Blue Ridge Beast Longitude Southern California Impreza Club Forum -- SCIC 10 02-04-2001 08:12 PM
Howdy! Just picked up my beast sat. night.... ChosenWon Mid West Subaru Owners Club Forum -- MWSOC 1 10-04-2000 08:56 AM
