Old 10-13-2005, 12:14 PM   #1
WRX_Mike
Member#: 97161
2005 STI
Aspen white
Default Will this work on my car?
I have a fmic up and down pipe exgaust and coldair intake i was wondering if this turbo would work in my car please let me know.
WRX_Mike is offline   Reply With Quote
Old 10-13-2005, 12:14 PM   #2
WRX_Mike
Member#: 97161
2005 STI
Aspen white
Old 10-13-2005, 12:15 PM   #3
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
Originally Posted by WRX_Mike
I have a fmic up and down pipe exgaust and coldair intake i was wonder if this turbo would work in my car please let me know.
what turbo?
hockeygm is offline   Reply With Quote
Old 10-13-2005, 12:18 PM   #4
WRX_Mike
Member#: 97161
2005 STI
Aspen white
look at the link under the post
Old 10-13-2005, 12:25 PM   #5
bsp
Vendor
Member#: 92939
WRX_Mike: This is not a bolt-in turbocharger for Subaru's. There are plenty of good turbochargers that you should be able to find in the Vendor for Sale section. Look into the following if you have a 2.0L
IHI Series Turbos (Probably a VF30 or 34 would be best)
There are also some larger options out there that still work well with the 2.0L, like the SR40 for example. You can also look into FP.
Look around here for advice though, and use the search. There is a great deal of good info.
bsp is offline   Reply With Quote
Old 10-13-2005, 12:34 PM   #6
el_banano_wrx
Member#: 98428
2003 WRX EJ20T
dark yellow
What about VF39?? Are they good upgrades for a wrx??
el_banano_wrx is offline   Reply With Quote
Old 10-13-2005, 01:33 PM   #7
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Anything larger then a TD04 is a good upgrade. The vf39 is very close to the vf34. Nearly sister turbos.
WRX-ERROR is offline   Reply With Quote
Old 10-13-2005, 01:37 PM   #8
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
VF34 is ball bearing and the VF39 cracks at the wastegate....take your pick!
YourMother'sLover is offline   Reply With Quote
Old 10-13-2005, 02:09 PM   #9
el_banano_wrx
Member#: 98428
2003 WRX EJ20T
dark yellow
I have a Vf39 with EWG (Tial 38mm) i'll have the same problem of craking??
Old 10-13-2005, 02:50 PM   #10
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
Not sure. It's due to the thin wall casting on the wastegate portion. I've got a VF39 with no cracks either, but.....
Old 10-13-2005, 03:32 PM   #11
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Of course, while the VF39's do have a history of hailine cracks, they seem to run just fine WITH those cracks...
mcowger is offline   Reply With Quote
Old 10-13-2005, 03:39 PM   #12
el_banano_wrx
Member#: 98428
2003 WRX EJ20T
dark yellow
Is there any product to prevent this cracks?
wonder if this will work on my car bender Vancouver Impreza Club Forum -- VIC 11 05-07-2010 03:50 AM
Will this work on my RSK EJ20k Mr. Simplisto Subaru Conversions 4 02-23-2009 10:51 PM
i have a mits 20G turbo will it work on my car?? 01G_WRX_02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-26-2005 10:49 AM
Will this work on my car!! Sharmin7 Normally Aspirated Powertrain 5 04-01-2005 07:07 PM
will this work on NA engines bruno Normally Aspirated Powertrain 3 01-08-2001 10:36 AM
