Old 10-13-2005, 01:10 PM   #1
soccrstar
Member#: 94304
Default how to mount hella 500s to impreza?
hello,
i am havin' hella trouble tryin' to mount these hella 500s onto my '02 impreza... its rainin' like a mad man lately and really could use the extra lightin'.
it came with impreza brackets. i understand that part but how the hell do you put the fog lights onto the bracket??
also, i didn't see any wires back there. someone said it comes pre wired for fogs??..... just need switch and relay.....
thanks
soccrstar is offline   Reply With Quote
Old 10-13-2005, 04:35 PM   #2
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
As far as wiring goes, use the hella harness that came with the hellas, the stock harness is not going to do as well. As for mounting them to the brackets, I cant help you on that one. I made my own mounts out of aluminum.
tooocool49723 is offline   Reply With Quote
Old 10-13-2005, 05:13 PM   #3
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
you are better off wiring in the harness that the hellas came with. if not there is a lot of splicing to be done.
ATX25RS is offline   Reply With Quote
Old 10-14-2005, 12:56 PM   #4
soccrstar
Member#: 94304
wirin' is not a problem, is gettin' them on.
i have no idea how
any help will be appreciated
thanks for the replies though
Old 10-14-2005, 01:02 PM   #5
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Got a pic? When I mounted my FF1000's I had to put the light onto the bracket then screw the bracket to the car. What do the brackets look like and are the light bolts on the bottom or back?
bushflyr is offline   Reply With Quote
Old 10-14-2005, 01:32 PM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
To mount the lights to the bracket all you have to do is point the mounting bolt straight back and bolt it to the "slot" on the bracket. To mount the lamp to the car after it's been attached to the bracket though you'll need to drill a hole through the bumper skin/backing plate so that the lamps mounting bolt can have room to stick through. I actually just cut out an opening with a saw and some tin snips for the mounting bolt to go.
Old 10-16-2005, 11:26 AM   #7
outback_97
Member#: 30874
0897 OUTBACKS
and 2003 TS wagon
outback_97 is offline   Reply With Quote
do i need kartboy bracket to mount hella 500s? quest Electrical & Lighting 28 01-21-2004 10:57 AM
How to mount hella 500's on Gc8? jotarou1 Interior & Exterior Modification 16 11-07-2002 10:19 PM
What to use to connect Hella 500 fullvision Interior & Exterior Modification 1 08-08-2002 12:34 PM
how to mount hella 500 fog in stock hole? PARAMEDIC Interior & Exterior Modification 6 01-20-2002 12:42 AM
Any center mounted Hella 500 pics? tmat3 Interior & Exterior Modification 4 03-17-2001 07:27 AM
