Old 10-13-2005, 01:39 PM   #1
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Default Speedo/Tach/tripo with out power
2004 forester XS
Battery was jumped this morning.
The speedometer, tach, trip and odemeters get no power. Everything esle seems to be OK.
Temp and Gas guages seem to be working. The gear selector lights (park/r/D), oil, airbag, etc... light up OK. All other function on the car seem to work OK(windows, radio, lights, blinkers)
Checked all underhood and in dash fuses, all seem fine.
Any ideas of what to look for?
moogoob is offline   Reply With Quote
Old 11-25-2006, 12:17 AM   #2
trd6209
Member#: 114394
2003 WRX
Whatever happened to your car? I am having the same problem. My ABS light comes on, my tripometer and my speedometer stop working when I turn my headlights to the on position. My headlights do not work either. I am really curious to see what the deal is here.
trd6209 is offline   Reply With Quote
Old 11-25-2006, 12:21 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...BAD BATTERY and/or bad connections to it or both
it you are on the stock battery GET RID OF THAT POS
Old 11-25-2006, 12:41 AM   #4
trd6209
Member#: 114394
2003 WRX
Unhappy My Nightmare
It's not the battery. Here's the deal. I put a new head unit with amp connections in it last weekend and everything has been fine. I connected a second amp to the existing connections today and and everything was fine as well until tonight when I was driving my car. I noticed that the headlights were dim, my speedometer wasn't working and my tripometer was blanked out and my ABS light stayed on. My running lighst worked thee entire time and my instrument bezel lights worked the whole time. I got to where I could pull over and my check engine light came on. I had to drive it home so I did a little troubleshooting on the way back. When I turned my headlight switch back one notch to parking lights only, the speedometer started and tripometer started working. The ABS light went out. When I turned the lights back on everything went dead. My lights don't work in both low and high beam. I came home and disconnected the new amp and all of its wiring (power from the battery, remote from the headunit and ground and I still have the same problem. I can't figure this out. Someone please help!!!
Old 11-25-2006, 01:10 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
...yet another FINE EXAMPLE of a kiddiestupidity hack job that goes awry.....dear god will these kiddies EVER learn
Old 11-25-2006, 02:46 AM   #6
trd6209
Member#: 114394
2003 WRX
I am a huge idiot!!! For future reference when you reinstall seat bolts, make sure that you don't pinch any wires under the mounts!!!
Smoked speedo/tach cluster faceplate DIY satrya Interior & Exterior Modification 27 01-20-2005 09:47 PM
V7 STI speedo/tach cluster wkw Private 'For Sale' Classifieds 12 12-11-2004 10:12 PM
Defi Heads up speedo/tach install ? WS6toWRX Electrical & Lighting 2 05-07-2004 04:07 PM
JDM/STI speedo-tach Cluster Matty Private 'Wanted' Classifieds 1 08-09-2003 10:24 PM
speedo, tach recaliberation silvscorp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-09-2003 10:09 PM
