Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 10-13-2005, 03:16 PM   #1
jim1969
Member#: 34877
2005 Legacy GT sedan
Default Anyone using DTEC as gauges?
Anyone?
jim1969 is offline   Reply With Quote
Old 10-14-2005, 12:24 AM   #2
Mach V Dan
Member#: 12029
Default I do.
I use a DTEC in my Evo for wideband air/fuel and boost displays. I love it! Plus, it's a major conversation starter at any car event. And I need more friends, so that's a plus.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 10-14-2005, 09:57 AM   #3
vwown3d
Member#: 69991
Leh Keen
Approved
lol looks good, id rock it!
vwown3d is offline   Reply With Quote
Old 10-15-2005, 11:59 PM   #4
jim1969
Member#: 34877
no alarms or peak values and the only gauges available are boost and EGT.
Old 10-16-2005, 11:27 AM   #5
WR^2X
Member#: 37617
Boost, EGT, Wideband A/F, Intake temp, and tachometer are all available with the current DTEC.
WR^2X is offline   Reply With Quote
Old 10-16-2005, 12:46 PM   #6
jim1969
Member#: 34877
how do you hook up wideband. unless you mean using the Tuner Pro. Can't use tach since the 05 uses CAN. Come to think of it, I think I saw a Intake temp sensor somewhere. I'd like oil pressure. There is no alarm. You cannot set a value and get a flashing light or buzzer (GB does have a speaker) at this time.
Old 10-16-2005, 09:11 PM   #7
Mach V Dan
Member#: 12029
The DTEC is universal. I use mine with a PLX wideband system, but it will work with any other.
You can hook up any five-volt analog input you want. If you have a sensor and it's a five-volt signal, you can input it. The DTEC can be customized to input and display ANY gauge you want, whether it's oil pressure, fuel pressure, EGT, or whatever else you can think of. You just need a five-volt input, and the tech specs of your input signal.
And if the car has a crank angle sensor or fuel injectors (most cars do ) then you can use the DTEC as a tach.
--Dan
Mach V
FastWRX.com
Old 10-16-2005, 09:18 PM   #8
jim1969
Member#: 34877
thanks Dan. I guess it can do more than I gave it credit for.
Old 10-20-2005, 08:15 PM   #9
Okita Souji
Member#: 41097
2005 WRX
I'm considering getting this to use for my gauges but I wonder if Turbo XS will eventually come out with a sensor to monitor Oil Temp or Pressure.
Okita Souji is offline   Reply With Quote
Anyone use Casper Knock gauge?? Paul Electrical & Lighting 6 08-17-2009 09:18 AM
anyone use a scan gauge 2 ? IllNastyImpreza Service & Maintenance 3 11-02-2007 01:17 PM
Anyone using MAPEcu as a fuel controller? nexxus_01 Engine Management & Tuning 2 06-30-2006 10:59 AM
anyone use this sti gauge cluster? vipernj Interior & Exterior Modification 8 12-12-2005 03:03 AM
Message Board Statistics All times are GMT -4. The time now is 01:35 AM.
