Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 10-13-2005, 10:27 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default New Products! 6spd Synchro / Bearing Kit and JDM 5th and 6th Close Ratio Convesion!
Hey all,
We have a couple of new products for you.
1) Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood if a transmission rebuild is necessary these synchros and bearings also need to be replaced. These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
2) JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$419 Shipped for Synchro and Bearing Kit
$319 Shipped for 5/6th Gear Conversion
$719 Shipped for Synchro and Bearing kit, and 5/6th Spd. Conversion
$869 for rebuild w/ new Bearing and Synchro Kit
$769 for rebuild w/ 5/6th Gear Conversion
$1149 for rebuild w/ new Bearing and Synchro Kit, and 5/6th Spd. Conversion
Thanks,
Preston
510-783-5300
[email protected]
Gruppe-S is offline
Old 10-14-2005, 07:52 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Also, we have a few Quaife ATBs in stock.
For those of you that don't know, Quaife ATBs have long been a necessary ingredient for fast front wheel drive cars and sucessful auto-Xers. Unlike a clutch type LSD, Quaifes use gears so there is instantaneous response and there is never a complete loss of torque to a driving wheel. Additionally, Quaifes have less moving parts and more wear and tear than clutch type LSDs. A Quaife is one of the best and easiest ways to increase traction, acceleration, and even braking! The Quaife has been proven in everything from SCCA Rally to Formula 1. It provides autocrossers with such an advantage, it has become "required" equipment for a winning effort.
Quiafe ATB Differential - 02-05 WRX, REAR - $1239 Shipped!
Thanks,
Geoff
Gruppe-S is offline
Old 10-14-2005, 07:53 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) ACT HD Street Disc Kit and Steetlite Flywheel - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$675 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Geoff
[email protected]
510-783-5300
Gruppe-S is offline
Old 10-14-2005, 07:54 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
1) Exedy Organic Clutch Kit and Steetlite Flywheel - 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Hyper Single Clutch/Flywheel Kit - 04+ STi
4) Exedy Twin-Plate Clutch/Flywheel Kit - 04+ STi
-Clamp Load: 2205 lbs/ft.
Thanks,
Geoff
[email protected]
Gruppe-S is offline
Closed Thread
FS: (CO) 04 STi 6spd swap w/JDM 5th and 6th Scuba Steve RMIC Private Classifieds 6 03-03-2009 12:36 AM
1 STi 6 spd Tranny in Stock! JDM 5th/6th Close Ratio Conversion! Clutches! Gruppe-S Drivetrain 6 10-18-2005 05:58 PM
JDM Transmissions, 4.44, Close Ratio boxes, Clutches, RA/SE Gearsets!! Gruppe-S Drivetrain 12 08-08-2005 04:50 PM
Anyone run a 1/4mi with the JDM 5th and 6th in the 6MT?? plus coasting RPM? BigJ04STi Transmission (AT/MT) & Driveline 3 01-13-2005 01:26 PM
