Old 08-27-2001, 11:43 PM   #1
WagonMaster
Member#: 6445
2002 WRX Wagon
WR Blue
Question Why would a body shop disconnect my battery?
Finally got my wagon back from the body shop (see linkBump, scrape )
My friend (who did the damage ) picked it up from the shop, but when I picked it up from her place today, i noticed that the radio presets had been wiped. The security light is flashing twice too...
So, I figure out the body shop must have disconnected the battery at some point during the repair job. They had the car for a week and there's a few extra miles on it than I think there should be (prolly nothing I can do on this ).
I'll call them tomorrow to find out about the battery, but any of you know why they might have done this? It was just a door scrape!!
WagonMaster is offline   Reply With Quote
Old 08-28-2001, 12:17 AM   #2
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
for safety, paint vapor is explosive and your car body is the ground a little static charge and by by car
milkman is offline   Reply With Quote
Old 08-28-2001, 12:18 AM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Precautionary- paint in aerosol form (especially in such fine sprays as quality auto paint guns can have) is HIGHLY flammable. Disconnecting the battery ensures no grounding sparks that could set things ablaze .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
IClub: Now with 20% more caffeine!
Old 08-28-2001, 12:20 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
They beat me to it...
Also, haven;t all of us Scooby owners learned to take down the exact miles our car has when we drop it off somewhere and inform the people that we know EXACTLY how many miles the car has on it It is one of the first things you will learn to do if you have yet
Eric
Eric SS is offline   Reply With Quote
Old 08-28-2001, 10:48 AM   #5
Shib
Member#: 1724
Make sure they tightened the bolts when you get it back. After my car came back from the shop, it wouldn't start one morning at all. It took me about half an hour to figure out they just hand-tightened the battery connectors and they finally came loose. Way to double check there guys.
Be grateful all they did was drive it around, last time my car was in the shop I had stuff stolen (Canadian Tire money, for the Canucks), lost (my mud flaps mysteriously dissappered) and poorly repaired (a good drop of solder/metal on a wheel bolt/nut -which was put in the glove-box since it couldn't be screwed back on).
Shib is offline   Reply With Quote
Old 08-28-2001, 12:40 PM   #6
Silver2000RS
Member#: 857
Did the body shop do any wielding on your car? They may have disconnected the battery to prevent the ECU from getting fried by the wielding. I don't know much about wielding but don't they use electricity when they spot/arc/tig wield?
Silver2000RS is offline   Reply With Quote
Old 08-28-2001, 10:16 PM   #7
WagonMaster
Member#: 6445
2002 WRX Wagon
WR Blue
They didn't do any welding! It was just a scrape, but you do raise a good point about the ECU. Somehow the car feels different - they prolly reset the ECU.
I'm off to do some searches on ECU resets....
Old 08-29-2001, 12:46 PM   #8
superwagon woman
Member#: 9748
2002 impreza wagon
heliski white
I think everytime you disconnect the battery the ECU resets. This is what I was always told to do after installing an intake/exhaust on a car so your car could "learn" to drive with it's new lungs. But some techie site somewhere probably has the facts for you. Actually, your dealer service dudes probably know if the ECU resets.
superwagon woman is offline   Reply With Quote
Old 08-29-2001, 03:34 PM   #9
Silver2000RS
Member#: 857
Smile
Did the body shop do any painting on your car? They may have disconnected the battery to prevent the ECU from getting fried by the painting. I don't know much about painting but don't they put a positive charge on the paint and a negative charge on the car body to get the paint to stick better?
Old 08-29-2001, 05:54 PM   #10
theGrideimpreza4u
Member#: 3594
1997 impreza L green
87 buick grand national
i work at a body shop and the reason why we disconnect the battery is so that when doing any work we dont get shocked or mess up your computer if we accidently cross 2 wires.,or die out your battery so then we have to recharge it.and in any way the paint is not dangerous to your battery in any way to create a spark we keep the batterys hooked up when we paint them in a dowdraft paint booth and then bake the paint on at 120 degrees also and wit the miles being on your call we are always moving cars constently and our storage garage and our detail shop is up the road a little so when we drive them back and forth a couple times the miles add up and when your car needs road tested for any funny noises!
theGrideimpreza4u is offline   Reply With Quote
Old 08-29-2001, 06:11 PM   #11
Poseidon
Member#: 4864
2004 WRX
This is just a guess, but maybe they took the doors off the car, and in so doing had to disconnect the wiring. When doing this, it is always a good idea to disconnect the battery.
Jordan
Poseidon is offline   Reply With Quote
will disconnecting my battery affect accessport map? hatrick32000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-12-2008 09:11 PM
I have ecutek can i disconnect my battery without it messing ECU up? Silver on Blacks Engine Management & Tuning 2 10-05-2005 05:59 PM
Help! I disconnected my battery and now the hazard lights keep blinking! Pleasehelp Electrical & Lighting 6 09-25-2004 05:03 AM
Why Do You Have To Disconnect The Battery After A Cat-Back Exhaust Install? Tek Newbies & FAQs 36 06-18-2004 12:44 AM
Did my body shop paint my hood bad? AlanTheWoo Interior & Exterior Modification 9 11-13-2002 03:06 AM
