Old 10-14-2005, 12:21 PM   #1
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
Default Max rpm?
Hey, I have a built motor, but I don't know whats been exactly done. Whats the highest I can rev a stock EJ25? Im hopeing I can bump up the rev limiter to 7k or possible higher. this is in a 98 impreza 2.5 rs.
PSI87 is offline   Reply With Quote
Old 10-14-2005, 01:13 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Unless there has been some valvetrain work i wouldn't suggest more than the stock rev limit of 6500. You could probably take it up to 7000, but since you don't know whats been done to the motor that could be a very bad idea.
Old 10-14-2005, 08:21 PM   #3
PSI87
Member#: 97120
1998 Impreza 2.5RS
Blue/Black
yeah, its currently at 6800, but id like to bump it up some so i can trap higher. i wish i knew what was done to the motor.
raising max rpms LttLDGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-30-2004 09:16 PM
What is Max RPM for STI? No Go STi Forum Archive 7 06-30-2003 09:03 PM
stock bottom end.. max RPM? wistful Normally Aspirated Powertrain 2 03-19-2003 04:23 PM
What max RPM do you hit fuel cut in your wrx? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-24-2002 03:50 PM
max rpm for oem valvetrain? wistful Normally Aspirated Powertrain 9 02-22-2002 12:26 AM
