#1 |
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
Vehicle:2002 Impreza WRX |
We are doing a special on stainless steel brake lines and Motul brake fluid. The packaged including Techna-Fit DOT approved stainless steel brake lines and 1 x Motul RBF600 Brake Fluid.
Price - $115 shipped ![]() Techna Fit stainless steel brake lines are made right here in the USA. These brake lines has been tested on various race cars and street machines. Each application is designed to replace your stock OEM rubber brake lines for easy installation, and Techna Fit brake lines are DOT approved!! Application: 02~05 OE Caliper and 04+ WRX/STI Brembo Calipers ![]() Motul RB600 Factory Line Brake Fluid Motul RB600 Factory Line Brake Fluid 100% synthetic fluid for hydraulic-actuated brake and clutch systems. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. Designed for high perfromance. High boiling points prevent brake fade caused by vapor lock. Suitable for street use in systems requiring DOT 3 or DOT 4. Typical Dry Boiling Point: 594 F (312 C) Typical Wet Boiling Point: 421 F (216 C) Volume: 500ml (1.05 US pint)
