Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-14-2005, 01:41 PM   #1
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Default Element Hydra: '05STi ALS/DCCD ?'s
Does the element for the '05 STi's provide Anti-lag with the DBW while maintaining the stock DCCD mapping/function. I think it does, but i wanted to confirm it. I've tried emailing phil without much success. Thanks all
Louis
Soon2Bgreat is offline   Reply With Quote
Old 10-14-2005, 10:13 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The Anti-lag option available for the Element Hydra EMS via one of our accessory harnesses is a drag race only anti-lag system. This only works when vehicle is not in motion to build boost.
If you want a true rally style anti-lag system you will need some sort of solenoid controlled air valve in your manifold (I have a customer running this on his Hydra). This could then be controlled via the Element Hydra which would also trigger the anti-lag mapping.
The DCCD would still be functional but possibly confused
By the way If you're Louis from Dentsport I replied to a Nasioc email on 10/11. Check your PMs if this is the same Louis but I'll be happy to send the email again if you didn't receive it.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 10-15-2005, 10:53 AM   #3
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Phil yes i am, i guess the email must have been lost in the shuffle, terribly sorry. That is good to know. I will try and give you a call on monday and talk to you about availability.
The anti-lag is the key feature if the dccd can't be kept or is 'confused' then that's fine we can run an aftermarket dccd controller seperate from the setup. I just don't want to have to switch over to throttle cable/different ecu's/harness etc.
Thanks for your time phil. I'll be in touch.
Louis
'05STi TBE+CAI+ECUtek tune+fuel pump= '05STi Proven Power Bragging 6 02-24-2006 09:34 PM
Intercooler and DCCD ?'s beatbyagirl Newbies & FAQs 8 02-19-2006 12:01 AM
WTT: my '05sti trunk for your wingless trunk USC_STI Private 'For Sale' Classifieds 9 04-07-2005 07:01 PM
'05STi Steering Wheel Lock? junnel20 Car Audio, Video & Security 1 10-03-2004 10:48 PM
turbo ?'s, oil ?'s, trans. ?'s, etc... the spacecowboy Technical Forum Archive 4 08-08-2000 07:28 PM
