Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 10-16-2005, 02:17 PM   #1
BIGDLM
Member#: 96539
2005 Turbo Baja
Question Oil psi sending unit install location on 2.5 Turbo engine?
Anyone know a good spot on engine to install an electrical oil psi sending unit? Only spot i found is underside of drivers side head, looks like an oil galley 1/8" plug? Not sure if this for oil though!
BIGDLM is offline   Reply With Quote
Old 10-16-2005, 03:10 PM   #2
Hawk296
Member#: 14555
1995 Impreza L
Baja
You could T off of the location for the factory oil pressure switch. Should be on the passenger side near the front of the block on top. put a T there and run both th factory pressur eswitch and your sending unit off of that signal.
Hawk296 is offline   Reply With Quote
Old 10-16-2005, 04:14 PM   #3
BIGDLM
Member#: 96539
2005 Turbo Baja
Thumbs up
Thanks Hawk! Was looking for it on the underside of block.
VIN location on 2.5 engine? Harv Normally Aspirated Powertrain 10 02-24-2010 03:06 PM
HELP: Advice on 2.5 Turbo engine blue05wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-23-2009 02:55 AM
Oil psi gauge install location on 2005 2.5 Turbo engine? BIGDLM Interior & Exterior Modification 2 10-16-2005 11:04 PM
Oil pressure sending unit install...HELP Porkchop-WRX Electrical & Lighting 6 08-07-2003 04:18 PM
Autometer elec. oil pressure sending unit tap location instructions joostin420 General Forum Archive 1 02-08-2001 09:39 AM
