Old 10-16-2005, 06:27 PM   #1
1wiwrx
Member#: 75988
2002 wrx
98 Green legacy outback
Default Idle Control System Malfunction? Help Please!
I took insurance off of my wrx and I washed it up nice before I put it in the garage for the winter. I pulled it out of the garage and turned it off so that I could wash it. No problems. I washed the car and did nothing out of the ordinary. I start the car up and it starts up fine. I pulled the car into the garage and got out. The car was not idling for more than two minutes when I noticed the idle change and heard rpm drop. It then sounded a bit rougher than normal.
I didn't think much of it and kept doing what I was doing. At about three minutes I climbed in and gave it a few slow revs up to about 2-3k. It didn't seem right, very steppy not smooth.
when I let it come back down to idle it would not settle. The rpms were extremely low then raised up above 2k and back down. This is when I relized The cel was on... great.
I plugged in the AP and got a 1507 code "Idle control system malfunction (fail-safe)" Awesome!
So, I searched a little and I ran accross a free data logging program for our cars.
http://www.tari.co.za/cgi-bin/yabb2/YaBB.pl
I don't know how to log anything yet but using the live function I could see that the maf is fully functioning, af ratios are correct, and a few other things.
I think it is the idle air control valve. Someone on nasioc had extremely similar symptoms on a NA subaru. He found his iac valve all gunked up so he cleaned it out and his problems were gone.
Could this be my problem? Where is the idle air control valve on a ej20t? What other things could cause my problems?
Thanks for the help,
Shawn
1wiwrx is offline   Reply With Quote
Old 10-16-2005, 07:26 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Old 10-16-2005, 08:48 PM   #3
1wiwrx
Member#: 75988
2002 wrx
Now why couldn't I find that before? Thank you.
-Shawn
Old 10-21-2005, 03:52 PM   #4
1wiwrx
Member#: 75988
2002 wrx
Well,
I cleaned the iacv and everything according to that link and my problem is still here. I cleared all codes and reset the ecu also.
Any other ideas?
-shawn
Old 10-21-2005, 05:12 PM   #5
pdippel
Member#: 20611
2003 WRX
World Rally Blue
I have been to the dealer 3 times and I still and a bad idle problem. I'll let you know what they fix next.
pdippel is offline   Reply With Quote
Old 10-22-2005, 06:43 PM   #6
1wiwrx
Member#: 75988
2002 wrx
Does your problem sound anything like mine? What have they replaced so far?
Anyone with any input, please help.
-shawn
Old 10-24-2005, 10:06 AM   #7
pdippel
Member#: 20611
2003 WRX
World Rally Blue
mine would only happen when the car was hot and in stop and go traffic. They replaced the IAC, then repaired a wire that was intermitent. It got worse before it got better; after first repair it would idle high after a short 5 minute ride and a 10 minute sit in the parking lot.
Old 10-24-2005, 03:14 PM   #8
legacy2003
Member#: 38338
2003 Outback Sdn H6
this thread worries me. i too am getting rough idle right now (you can hear it sputtering and stuff, and it can idle anywhere from 500-1400 rpms, and sometimes bounces around). i havent tried to clean my iac but i do throw the code every now and then. do you also find hesitation under throttle and occasional cuts in power (maybe because its in fail-safe mode?)?
i planned on just replacing the iac valve completely, because i've heard that cleaning it doesn't always get the job done. 35k on my motor right now roughly.
what other things has the dealer replaced and/or fixed for you? anyone had success?
-mike
legacy2003 is offline   Reply With Quote
Old 10-30-2005, 05:17 PM   #9
1wiwrx
Member#: 75988
2002 wrx
I have 86K on mine and the iacv was extremely dirty. Is it true that it may take a period of driving before the iacvs works correctly again? I wouldn't think so since I cleared and reset the ecu. Whatever...
I still have the problem.
-shawn
Old 11-06-2005, 05:58 PM   #10
1wiwrx
Member#: 75988
2002 wrx
I still have not found or fixed my p1507 code. While in the process of troubleshooting I recieved three more codes! P0103 Mass or Volume Air Flow Circuit High Input,P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input, and P0112 Intake Air Temperature Circuit Low Input. All of this is on top of my original P1507 Idle control system malfunction (fail-safe).
What the hell is going on? I'm currently driving a 91 camry that has had less problems through out its entire life than my 02 wrx has had in a month. My "Subaru's are reliable" idea is starting to fade.
-shawn
Old 11-09-2005, 01:32 AM   #11
gpatmac
Member#: 18446
2002 WRX wagon
psm
I 'think' I've just gotten rid of my P1507, but I haven't tested extensively. However, my overarching problem still persists. My idle is fluctuating.
I just reinstalled my engine and it initially idled terribly. I found one major intake leak which I fixed and also realized that I throttle cable was well out of adjustment; fixed that as well. So for now, code has gone away. I'll check again tomorrow. Unfortunately, weird idle hasn't.
I've ordered the gasket and plan to clean my IACV iaw this thread: http://forums.nasioc.com/forums/showthread.php?t=781242
We'll see how it goes.
gpatmac is offline   Reply With Quote
Old 08-20-2007, 10:52 PM   #12
M.R.blue
Member#: 89589
did u fix it?
M.R.blue is offline   Reply With Quote
P1507 Idle Control System Malfunction (Fail Safe) Soulofdarkness Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-14-2011 09:38 AM
P1507 Idle Control System Malfunction (Fail Safe) subydude02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-11-2009 11:21 PM
Security System malfunction!!! help!! mike314 Rocky Mountains Impreza Club Forum -- RMIC 5 09-02-2009 05:23 PM
P0505-Idle Control System malfunction-help! SRuzhyo Legacy Forum 0 09-01-2004 05:16 PM
Idle Control System Malfunction PoogieLayne Normally Aspirated with bolt-on Forced Induction Powertrain 8 01-19-2004 08:53 PM
