Old 10-16-2005, 09:49 PM   #1
zmaster
Member#: 88995
11 WRX Premium
True Subaru color WRB
Default 05 Rs to sti conversion??
Guys is it possible to convert the 05 RS to a Sti?
what would you have to do? engine swap...and transmission swap? anything else and what would i be looking at money wise?
Thanks guys!
zmaster is offline   Reply With Quote
Old 10-16-2005, 10:14 PM   #2
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
I think it can be done - haven't read about anybody on an 05 doing it though
maybe it best be served to post in the conversions forum
here in Ontario I believe Planet Motorsport (http://planetmotorsport.com/index.html) does conversions for the die-hard subie lover
dmatthew is offline   Reply With Quote
Old 10-16-2005, 10:15 PM   #3
05rswagon
Member#: 75371
2011 WRX Prem Hatch
Why not have just bought a sti do you have a wagon?
05rswagon is offline   Reply With Quote
Old 10-16-2005, 11:52 PM   #4
piker28
Member#: 22664
in the end it will cost more to do than just buying an sti, this is of course if you do it CORRECTLY
that means engine, trans, brakes, etc etc
youd need the full engine, intake, radiator, etc, wiring harness, ecu, then fgure out how to wire it all together
for the tranny youd need that shifter linkage, shifter, console, driveshaft, crossmember, rearend, axles, brembos yada yada
more or less if you WANT to do it, just buy a totalled sti and rip out everything and plant it in your car, full wiring harness headlights back to the taillights and no splicing required then
piker28 is offline   Reply With Quote
Old 10-17-2005, 12:29 AM   #5
AlpoRS
Member#: 81338
2005 2.5 RS Wagon
actually, i think the engine swap could smoother than people think. It would still cost you an arm and a leg, but it would be sweet. The reason the engine swap wouldnt be as bad is because the wiring harness for the 05 rs is almost identical to that of the 04 usdm sti. So it would take a ton of work out of it. I looked into this a while ago and still would love to do it, i just dont have the money.
everything else on the other hand, that is transmission, etc. that is a different story
AlpoRS is offline   Reply With Quote
Old 10-17-2005, 12:32 AM   #6
piker28
Member#: 22664
how did you figure out the wiring harnesses are nearly identical? I dont really see how that is but who knows you may be right
Old 10-17-2005, 12:57 AM   #7
909 STI
Member#: 97890
05 STi OBP R.I.P.
My Adidas
i'll help you out, i'll trade my hood and trunk for yours. bump
909 STI is offline   Reply With Quote
Old 10-17-2005, 01:02 AM   #8
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
lol best bet is a wrecked sti, get all the parts you need for a swap! im looking to do this in the upcomming summer!
vwown3d is offline   Reply With Quote
Old 10-17-2005, 01:04 AM   #9
WRX-pilot
Member#: 31162
2005 STi
The shop near me does STi swaps for $13K, might as well just sell the car and get a brand new warrantied STi
http://forums.nasioc.com/forums/showthread.php?t=688092
WRX-pilot is offline   Reply With Quote
Old 10-17-2005, 09:42 PM   #10
zmaster
Member#: 88995
11 WRX Premium
wrx-pilot...thats 13K with the engine and transmission included or just labour???? it still saves me money than to spend 32K on a sti..cos i got my car for like 15K
Old 10-17-2005, 10:29 PM   #11
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
15+13k= 28k So for nearly the same price as a new STi, you'll have minimum 2 weeks of no car...Potential for CEL's, Mechanical and Electircal problems, and no warrenty on any working part of the car (assuming you swap everything)...
doesnt seem like that much of a bargin to me...
saar is offline   Reply With Quote
Old 10-18-2005, 12:44 AM   #12
AlpoRS
Member#: 81338
2005 2.5 RS Wagon
the reason i say that the wiring harness for a usdm sti engine is almost exactly the same as the 05 rs is because when i got my engine management (perfect power) put on to my 05 rs, it was before rallitek had the schematics or layout for the 05 rs ecu plugs. They noticed that the new engine used some of the same parts as the 04 sti and looked at the ecu plug layout and it was almost if not exactly the same, maybe a wire or two different here or there. One way or another, they were able to successfully set up engine management for an 05 rs with the layout from an 04 sti...this is how i know.
I am not sure if they are 100% identical, but i think you could cross out one major pain and labor intensive burden from your swap.
Old 10-18-2005, 01:17 AM   #13
WRX-pilot
Member#: 31162
2005 STi
Yeah but your not getting a new STi with an STi swap. You get whats left of a salvaged STi and yes that does include labor in the price. Try comparing $15K+$13K to a used STi that will go for about $28K.
What happens if 5K miles later and the tranny goes out? What if... people stopped trying to save a couple bucks trying to mimic a $30,000 car?
You're almost there anyways, why not just get the right car with a warranty and no complications. You'll have a little more piece from your car and you don't know if a swap leave out some things... the car it comes from was parted out for a reason.
Old 10-18-2005, 05:33 AM   #14
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Doing an STi swap into any 04+ RS is just stupid. Really, just buy an STi and save yourself a lot of headaches.
X4 SRT is offline   Reply With Quote
Old 10-18-2005, 11:08 AM   #15
piker28
Member#: 22664
not really^^
buy a salvage, get the full wiring harness and motor and drivetrain..
just plop it all into your car shold mainly be plug and play...sell off rest of the parts from the sti = profit and it wouldnt be to bad
this is my plan in the future
Old 10-18-2005, 03:04 PM   #16
zmaster
Member#: 88995
11 WRX Premium
ok ...just buy an sti..and swap the damn trunks out...makes more sense..
Old 10-18-2005, 03:32 PM   #17
EarlQHan
Member#: 90215
I'll trade you my trunk for yours if you get it painted. then you can sort of look like a sti...
EarlQHan is offline   Reply With Quote
Old 10-18-2005, 03:57 PM   #18
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Just buy this car and then you'll be set...
http://portland.craigslist.org/car/103455874.html
Seriously, for $28,000 you can get an 04 STi. That is basically the same money as a swap, plus you will have full STi. Meaning suspension, seats, brakes, cluster, wheels, everything.
Unless you can do the labor yourself (or have gobs of moeny) projects like this seem absolutely asinine.
.02
Jared
gtwagon941 is offline   Reply With Quote
Old 10-18-2005, 06:52 PM   #19
resident1155
Member#: 92659
2002 Impreza RS
Don't waste your money thats crazy. In my opinion anyway
resident1155 is offline   Reply With Quote
Old 10-19-2005, 05:59 AM   #20
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Originally Posted by piker28
not really^^
Price of new 04+ RS 19k
Price of salvage STi 15k
Total: 34K (plus any labor you will have to pay to swap everything over)
Price of new STi 33K
Get a new STi. Then you will be all done. The car will run, it will have a warranty, and people won't laugh at you for first buying an RS then swaping in an STi motor.
Oh, and sell the rest of the parts off the STi that you don't use to make a profit? Right, like the motor? No. Thats in the car. how about the tranny? No. You used that too. The brembos? Used. I know...the seats. Used. Any parts you didn't use would not really be worth selling. You would use all the good parts that are needed for the swap, and be left with a pile of parts that you can't sell. Plus you just bought a car with a salvaged title, so who knows what the hell is wrong with it. Good luck with that swap into an 04+RS. Again, IMHO a total complete and utter waste of time and money.
Old 10-19-2005, 12:10 PM   #21
piker28
Member#: 22664
no offense you dont need to use the seats i know i dont like them so i would not use them
headlights, fenders, hood, trunk, rims etc all make money for you
im not telling the guy to do it just thats how id do it
dont know whats wrong with it? if theres a hit in the back then it wsa rearended, DUH
Old 10-19-2005, 12:26 PM   #22
kastkc
Member#: 51141
2013 WRX
PBP
Insurance would be ALOT cheaper in a swapped RS than in a STi.
kastkc is offline   Reply With Quote
Old 10-19-2005, 12:31 PM   #23
MBREX02
Member#: 82733
2004 WRX STi
Trying to turn an RS into and STI is a complete waste of time and money..unless you are doing it to a 98-2001 RS!!!! That is teh sexiest!
MBREX02 is offline   Reply With Quote
Old 10-19-2005, 01:25 PM   #24
imprezar25
Member#: 89446
04 rs
psm
usualy if u get into a accident with all the sti stuff in it they wont cover it or they will and your rates will go up alot more then if it was a stock rs
imprezar25 is offline   Reply With Quote
Old 10-19-2005, 03:54 PM   #25
jeisen
Member#: 27258
who dat be dat was?
if you were starting with an older car and doing a swap i could understand it. Or even if you were swapping it into a wagon. But to take a basically identical looking (and new) car and spend that much money on a better drivetrain, etc. doesnt seem worth it.
jeisen is online now   Reply With Quote
04 rs to STI conversion. akstud1983 Subaru Conversions 0 08-19-2008 02:02 AM
01 RS to STi 6 speed conversion question/info needed Texas25RS Transmission (AT/MT) & Driveline 2 05-17-2005 01:43 PM
RS to WRX conversion Impreza.STI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-16-2002 12:40 PM
RS to WRX conversion (Update) EddyRS Bay Area Impreza Club Forum -- BAIC 3 03-06-2002 03:24 PM
RS to WRX Conversion Project (Update) EddyRS Bay Area Impreza Club Forum -- BAIC 27 12-08-2001 02:38 AM
