Old 10-16-2005, 10:52 PM   #1
1/500yellowwrx
Member#: 53573
2005 STi Silver
Silver and fun
Default Will I allways get miss firing codes?
Well I just bought a 2000 RS-T and would like to know if I should expect to allways have miss firing codes. It is the gt-25 kit and is running the Link EM. I have replaced spark plugs and gapped them to .25. Is there anything I can do to get rid of this or not? Thanks for the help.
PS I have also replaced the o2 sensors.
1/500yellowwrx is offline   Reply With Quote
Old 10-17-2005, 11:00 AM   #2
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
plugs, wires, and coil all at once
darioc is offline   Reply With Quote
Old 10-17-2005, 09:55 PM   #3
1/500yellowwrx
Member#: 53573
2005 STi Silver
Silver and fun
I figured out the problem. It is the lightweight flywheel.
Old 10-17-2005, 10:13 PM   #4
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
All behold the power of the mighty search button
no-coast-punk is offline   Reply With Quote
Old 10-18-2005, 09:41 AM   #5
Tats
Member#: 5692
WTF? YES! I am
better than you!
Hmmm...I have a lightrnrd flywheel and pully and get codes all the time. But I didn't get them when I was NA. Only after the turbo. Anyone think I should ditch the pully?
Tats is offline   Reply With Quote
Old 10-18-2005, 09:49 PM   #6
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
I have GFP pullys and a JUN 13lb. I haven't got any.. weird
Hitokiri is offline   Reply With Quote
Old 10-18-2005, 10:40 PM   #7
darioc
Member#: 35695
02 RST
how does the car run? if it runs fine, screw it! i have cylinder misfires on all four cylinders because of my heads and cams. car idles good now though
Old 10-19-2005, 07:22 AM   #8
Tats
Member#: 5692
WTF? YES! I am
better than you!
Car runs fine but I can't pass OBDII inspection with the codes.
Old 10-19-2005, 06:20 PM   #9
darioc
Member#: 35695
02 RST
ohhhhh yeah. if you have a good dealership around you, they can hook up to the select monitor and figure out why the car misfiring. it could be many things. carbon build up, dropped valve, or secondary ignition things, etc. they can def figure it out if they are at all intelligent with the scan tool.
Old 10-19-2005, 06:25 PM   #10
Tats
Member#: 5692
WTF? YES! I am
better than you!
Well.....EJ257 Hybid is coming out, GT28R is going back in along with the Stock 2.5.
And I'm gonna try an e-manage for that. Think the stock injectors, FPR and a 255L pump will be able to handle 6-7 psi wtith it?
(And no....hybrid is not for sale...it's getting WRX heads and going into a 2003 WRX wagon.)
I miss auto-x. Will I ever get back into it? metoo Texas Impreza Club Forum -- TXIC 27 08-22-2005 03:46 PM
Miss fireing STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-22-2004 04:54 AM
Multiple Miss-Fires nhalterman Normally Aspirated Powertrain 29 05-11-2004 07:53 PM
miss fire wavecruzer79 Mid West Subaru Owners Club Forum -- MWSOC 0 05-13-2003 04:04 PM
Cyl. Miss-Fire racinready300ex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-05-2003 06:31 PM
