Old 10-16-2005, 11:10 PM   #1
resident1155
Member#: 92659
2002 Impreza RS
Unhappy Interior lights dim+bad idle= ...headlights?!
The first thing I noticed when I got my 2002 Impreza 2.5RS was the interior lights would dim when I turned on the headlights. Specifically, the clock almost becomes unreadable if I put the headlights on during the day. Also, when I turn on the lights, the idle drops from 500rpms to about 400rpms. At this point the idle becomes rougher, as anything below 400rpms and it would probably stall. I just had a 60,000 mile tune up so...ya I don't know why this is happening.
One of my theories is that they used to thin gauge of wire for the ground/power that run from the fog lights, but I can't be sure. As far as the idle dropping...that makes me think the alternator is on its way out or maybe the "magic 3" wires need to be upgraded.
I really hate taking my car to the dealership because they waste too much time. I do remember reading something about this in a thread but it didn't really explain my specific problem. Any help is appreciated. Thanks
resident1155 is offline   Reply With Quote
Old 10-16-2005, 11:12 PM   #2
WR^2X
Member#: 37617
I have nothing to offer, other than you'll get a lot more help by posting in the Electrical and Lighting forum. But don't worry, one of the mods for this forum is really good about moving threads to the appropriate forums.
WR^2X is offline   Reply With Quote
Old 10-16-2005, 11:13 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Could be a bad battery -- take it in to Autozone or similar to have them do a "load" test on the battery.
Old 10-16-2005, 11:15 PM   #4
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
the clock is supposed to dim when the lights are on
adeliciouspizza is offline   Reply With Quote
Old 10-16-2005, 11:18 PM   #5
njskatchmo
Member#: 94618
2002 Bugeye
This may be stupid, but did you try spinning the little dial that increases the intensity of the interior lights?
njskatchmo is offline   Reply With Quote
Old 10-16-2005, 11:22 PM   #6
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
bad alternator?? get a multimeter and see if you have enough voltage going thru your alternator...
scooby_wooby is offline   Reply With Quote
Old 10-16-2005, 11:38 PM   #7
rice h8r
Member#: 94524
I also think it could be a bad battery. Happened to my dad's LS400. The car wouldn't start and when I turned on the headlights, the inside lights would go very dark. Also the VSC warning light came on. We put in a brand new battery and all the problems went away including the VSC warning. We were lucky that it wasn't a major problem with the VSC. lol.
rice h8r is offline   Reply With Quote
Old 10-17-2005, 12:29 AM   #8
resident1155
Member#: 92659
2002 Impreza RS
I don't think the clock is supposed to dim when the lights come on. I have a digital voltmeter and I'm going to test the line tomorrow. And yes, I tried spinning that dial to increase intensity. Also, I've been in a car before when the alternator is crapping out, and this is not the case for my car. Going to go post now in the electrical forum. Thanks for the help everyone.
Old 10-17-2005, 07:49 AM   #9
MDRex
Member#: 38477
2015 Crosstrek
Orange
The clock does dim when you turn the headlights on. There is a mod to make it stop dimming. Just pull the clock out and there is a connector pin on the back you can bend over and the clock never dims again.
Also check the dimmer dial first, it's one the left headlight stalk.
Also, the idle should be around 750, not 500. Try a home made grounding kit, helped my idle smooth out a little.
Go to scoobymods.com and look up grounding kit and clock dimmer mods.
MDRex is offline   Reply With Quote
Old 10-17-2005, 08:56 AM   #10
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Bad: battery, alternator, ground
Start with cleaning the grounds.. then have the charging system load tested by an experienced mechanic (not at autozone) and then decide if you need an alternator or battery or both.
Old 10-17-2005, 10:43 PM   #11
resident1155
Member#: 92659
2002 Impreza RS
I bought the grounding kit on ebay and put it in today...noticed less hesitation but the idle still drops when I turn the headlights/fog lights on (especially the fog lights). I'm going to test the line tomorrow when I have more time..
Old 10-19-2005, 06:01 PM   #12
resident1155
Member#: 92659
2002 Impreza RS
ok I tested the battery and alternator with my voltmeter. Both read 14 volts at idle with the lights OFF. I had a friend turn the lights on while I was doing the testing. I found a 1 volt drop from the battery when I turned the lights on, but the volts did return to normal (14v). From the alternator I found a 4.5 volt drop but, there too, the volts returned to normal.
I am assuming this means the alternator has low amp output, but is still usable and working properly? I am curious to know if upgrading the power wire to the battery would help with this problem or if the alternator/battery combo should just be upgraded. Anybody have input on this??
Old 10-19-2005, 06:48 PM   #13
rexxer
Member#: 27624
2014 WRX
Don't use the clock as a judgement point. It will dim as stated before. As for the rest, search for "grounding mod". That should help.
rexxer is offline   Reply With Quote
Old 10-19-2005, 08:01 PM   #14
resident1155
Member#: 92659
2002 Impreza RS
I did the grounding mod...it didn't help this specific problem.
Headlights, and interior lights dimming MaLiCiOuS Electrical & Lighting 2 11-10-2008 07:27 PM
RPM dips and headlight dimming at idle Dramabomb Service & Maintenance 7 12-03-2007 12:56 AM
Interior Lights dimming-HELp tm999xxx Electrical & Lighting 2 10-10-2003 06:52 PM
Dimming interior lights? redwagon Technical Forum Archive 48 12-10-2000 12:04 AM
