Old 10-17-2005, 12:44 PM   #1
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
Default Power source for dash pod gauges? Needle dropping.
I just hooked up 52mm GReddy gauges in the clock location; EGT and oil pressure; oil pressure sensor isn't connected yet.
I connected both gauge's power sources to the clock's power source wire, I was skeptical about doing this and it looks as though my feeling was right. When my car is sitting idle the EGT gauge will be reading fine, if I hit the turn signal the needle will fluctuate a couple hundred degrees (Celcius), when I hit the brakes the needle drops the same amount and when I roll up/down the windows the needle really drops, heheh.
I think it's safe to say that I need a better power source for the gauges. Where have you all tapped to get a good steady flow to your gauges? Do I need to go buy a 4 gauge amplifier wiring kit to power these things?
djoye is offline   Reply With Quote
Old 10-17-2005, 01:49 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Erm, that location works fine for everyone.
if it doesn't work for you, you did something wrong with the wiring.
mcowger is offline   Reply With Quote
Old 10-17-2005, 02:09 PM   #3
djoye
Member#: 50072
2003 WRX
I used the wire tap clamps that came with the gauges, I don't like those but I wanted to keep it clean. Maybe I'll take them off and strip some shielding from the clock power wire and just go straight to it.
Old 10-18-2005, 01:28 PM   #4
djoye
Member#: 50072
2003 WRX
Posting this info in case someone searches for it:
I relocated the gauge grounds to the bolt near the ECU and the problem went away, well at least like 99% away. The needle will still BARELY drop when I simultaneously roll down the windows, have the lights on, press the brakes, and turn on the hazards (I'd like to be a person that tests tolerances for a living ). When I pulled the wire tap from the clock's ground wire it was touching just a SMALL amount of the wire; I just don't like those taps. I might remove the tap from the power wire and just splice directly into it to see if that doesn't solve the issue 100%.
For now it's doing very well. Wire taps SUCK.
Electrical power source for gauges/LC-1 Desibabu345 Electrical & Lighting 16 11-12-2008 05:17 PM
Need help with 3rd gauge for dash pod aakrusen Interior & Exterior Modification 6 01-12-2007 12:46 PM
Power Source for Gauge ILSMKU2 Electrical & Lighting 7 09-19-2006 06:09 AM
WTB three gauges for dash pod vortectoy Private 'Wanted' Classifieds 2 06-01-2005 11:33 PM
Power source for gauges? t_wrexxx Electrical & Lighting 1 11-02-2004 02:41 AM
