Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 10-17-2005, 04:54 PM   #1
Member#: 66997
Default Brake fluid capacity
What is the brake fluid capacity for the 02 WRX.
I'm getting it changed at the dealership, but I'm supplying it...How much should I buy?
I'm thinking of Val. Synpower Dot 4...what do you think.
matty2.5 is offline   Reply With Quote
Old 10-17-2005, 09:35 PM   #2
Member#: 85805
... Shiny & Chrome
Witness Me!
motul 600 for the win
TarmacRally is offline   Reply With Quote
Old 10-17-2005, 09:55 PM   #3
Member#: 31002
I don't know the capacity. I usually buy a couple of quarts and bleed the system till the fluid comes out clean. I really doubt the dealership will go to all that trouble though. Most of the time, they might crack the bleeders open and gravity or vacume bleed the sytem for about 5 seconds and call it good. My suggestion would be to find someone whose done this befor and do it yourself.
BillJC is offline   Reply With Quote
Old 10-17-2005, 10:10 PM   #4
Member#: 21808
02 GroceryGettAr
Nonemore Black
It depends a bit how much they flush through... the actual system capacity is only about 0.5 liter (roughly 0.5 US qt)... a 1qt should be enough (I've done it with less) but I've heard of people using more. The Synpower DOT4 is fine. No need to go fancier unless you're boiling it.
UkNuck is offline   Reply With Quote
Old 10-17-2005, 10:47 PM   #5
Member#: 44168
2003 Yellow WRX
with too many lights...
ATE Super Blue is also a good choice.
brake fluid capacity? jooboy Service & Maintenance 1 06-23-2009 03:59 AM
Brake Fluid Capacity Gunner Service & Maintenance 2 12-27-2004 05:49 PM
sti brake fluid capacity lukerussell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-10-2004 10:33 PM
Minimum Rotor Thickness and Brake Fluid capacity? - MY98 RS glyphic Brakes, Steering & Suspension 2 07-19-2002 10:39 PM
Anyone know the full fluid capacity of the RS braking system? North Ursalia Brakes, Steering & Suspension 3 02-11-2001 06:46 PM
