Old 10-18-2005, 09:10 AM   #1
bluesubie
Member#: 767
04 FXT
Thumbs up Used oil analysis FXT 6,144 miles German Castrol Syntec 0W30
This oil change interval saw all sorts of driving conditions and heat. Weekday commute is 5 miles each way, off-roading at the beach, trips to SC and MD with 100+F temps, and lots of stop and go driving. And of course, the mandatory spirited driving that one must do with a turbo (WOT, redlining). No engine mods.
Warning! Don't try this with just any 30 weight. Even with the fuel dilution (probably due to the short trips), this oil is still very close to a 40 weight after over 6k miles. Silicon stayed the same after I switched back to an OEM air filter (from Amsoil). I expected a drop in Si so I'll have to keep an eye on that and check out my intake. Copper went up for some reason as well. High copper readings are usually a normal part of break-in. Switched to synth blend at 3,750 and full synth at 7,500 miles (too early in hindsight).
First column is current, second column is German Castrol with 5,930 on the oil and third is M1 5W30 w/5,774. UOA by Blackstone.
Equipment make: Subaru
Equipment model: 2.5L Turbo
Oil use interval: 6,144
Oil type & Grade: Castrol Syntec 0W30
Make-up oil added: 0
Miles on unit: 28,644
Air filter: OEM
Oil filter: OEM
Aluminum 4 4 6
Chromium 1 1 1
Iron 11 10 15
Copper 10 6 20
Lead 3 2 2
Tin 1 0 0
Molybdenum 4 12 63
Nickel 0 1 0
Maganese 0 0 0
Silver 0 0 0
Titanium 0 0 0
Potassium 0 0 3
Boron 1 14 115
Silicon 15 15 18
Sodium 6 2 6
Calcium 1689 2582 3394
Magnesium 398 106 10
Phosphorous 754 680 764
Zinc 909 818 904
Barium 0 0 1
Properties:
SUS Viscosity @ 210F: 64.4 [should be 58-65]
Flashpoint: 385F [>385]
Fuel %: .5 [<2.0]
Antifreeze: 0 [0]
Water: 0 [<0.1]
Insolubules: .4 [<.6]
Dennis: The small amount of gas was still there in this third sample so it may be an operational hazard you will have to live with. It has not hurt the oilís viscosity any and we donít see any harm being done to wear. Unless the fuel amount in the oil gets much above 2.0%, we doubt we will see any harm from its presence. Copper made a little unexpected uptick in this sample and we have no idea why. It comes from bronze parts. It should read at about 5-ppm in this sample. We will watch it for you next time, but we would bet it will drop. The TBN was 3.6 okay.
Post on bitog
-Dennis
Old 11-18-2005, 07:06 AM   #2
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Impressive, Thankyou.
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 11-18-2005, 04:32 PM   #3
hondaeater69
Member#: 60324
even it being a break in thing. . .it (copper) should be slowly going down, no?
and that Si is kind of high, should have seen a drop in it, unless you did a lot of off road driving this interval which would offset the use of a better filter. I would def check the systems for leaks, do you have EGT?
Old 11-18-2005, 08:42 PM   #4
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
I like the fact that no make-up oil is needed. Anyone else uses GC in the WRX and has similar experience?
Gunner is offline   Reply With Quote
Old 11-19-2005, 08:21 AM   #5
bluesubie
Member#: 767
04 FXT
Yeah, copper going up slightly was a little strange and as for the Si, yes I was driving on the beach almost every weekend over the summer. I thought it would drop since I switched back to OEM. It'll probably go down next sample.
I actually did think that I had an exhaust leak when I was running the Amsoil filter, but the dealer said it was just noisy from the filter. No EGT.
I only checked my oil about three times during the interval. There are a couple of STi UOA's on bitog. One very good one even included 45 passes at the drag strip.
-Dennis
German Castrol Syntec 0W30 stiskeet Service & Maintenance 17 08-24-2009 09:50 PM
German Castrol Syntec 0W30 Jon Bogert Engine/Power/Exhaust 4 08-19-2007 07:28 PM
German Castrol 0W30 used oil analysis, 7,478 miles, '04 FXT bluesubie Service & Maintenance 0 06-11-2006 08:09 AM
Oil analysis after 6,000 miles of alky injection scooterforever Water/Methanol Injection, Nitrous & Intercooler Cooling 10 10-12-2005 09:07 PM
Oil analysis on German Castrol Syntec 0W30, 5,930 miles, FXT bluesubie Service & Maintenance 8 03-26-2005 10:06 AM
