Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 10-18-2005, 11:50 AM   #1
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
Default Heated seats stopped working
I have an 05 wrx, and a few days ago (first time used since summer) i noticed that my heated seats were no longer working. I tried the obvious and switched the heated seats 20A fuse with another 20A fuse, but it didn't do anything. Is there anything else I should try before bringing it in for some warranty work?
Also, I did a radar hardwire mod and hardwired my radar power line into the fusebox to turn on and off with the car. Would they give me a hard time about warranty work like this because of that mod?
CletusTheDwarf is offline   Reply With Quote
Old 10-18-2005, 02:22 PM   #2
rebos123
Member#: 67669
2005 2.5 Hybrid WRX
evoIII 16G
Do the lights on the heated switches work?(the little yellow/orange bars on the rocker switch). Also, have you ever removed your seats from the vehicle? If so, did you reconnect the harnesses for the heaters?
rebos123 is offline   Reply With Quote
Old 10-18-2005, 04:18 PM   #3
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
no, the lights don't light for either seat. and i never took the seats out.
Old 10-18-2005, 05:26 PM   #4
BrentS
Member#: 96601
2004 WRX
There is a plug under the switch. Could it have came un-plugged? Did you install a short throw shifter or anything that would cause you to remove the console? It is easy to check. Open the storage lid, pop up the console.
BrentS is offline   Reply With Quote
Old 10-18-2005, 06:40 PM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Only if it caused the problem with the seat-heater circuit.
Heated Seat Issue?!? maxpower_454 Interior & Exterior Modification 11 06-05-2010 09:05 AM
Both heat seats stopped working blah0r Interior & Exterior Modification 5 02-22-2010 10:56 PM
heat stopped working 3rdgearpinned Service & Maintenance 7 12-25-2008 06:05 PM
Passenger heated seat doesn't work...anyone? Mikeye Legacy Forum 6 03-11-2008 08:25 PM
heat stops working sometimes hondaeater69 Service & Maintenance 11 12-18-2005 11:26 PM
