Old 10-18-2005, 06:21 PM   #1
TEKNOSYS
Member#: 79839
2004 WRX Sedan
Default Ignition Lead?
I'm hooking up a Bluetooth car kit in my WRX, and I need to find out where to hook up the ignition lead. I got the power and ground spliced off the radio, but I need to hook into the ignition so the unit powers on and off with the ignition. What's the easiest way to do this? The unit is a Sony Ericsson HCB-300
TEKNOSYS is offline   Reply With Quote
Old 10-19-2005, 01:31 PM   #2
i102spd
Member#: 92130
2002 2.5rs
i would assume the location of the ignition wires is pretty close to the same as in my 02... however i suspect you may be looking for the accessory wire rather than the ignition wire... i got both of these wires for my remote start right at the key cylinder... remove the lower panel of the steering column right behind the steering wheel... then you'll see a small cylindrical thing in line with where you put the key in... should have 4 or 5 thick wires coming off it... using a test light find the one that goes on and off w/ the key... to simplify you can also remove the cylinder so it's easier to work with and you can reach farther back on the wires; it pulls right out
i102spd is offline   Reply With Quote
Old 10-19-2005, 02:33 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
You're looking for a "switched" power or ACC wire. Just get it from the radio harness like you did the constant +12V and ground wires. Check out the forum sticky here or in the Car Audio, Video & Security forum for a link to a diagram showing the pinouts.
Old 10-19-2005, 02:41 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Also, you can use the cigarette lighter which is accessory power, or there is a yellow/red wire at the top/front of the under-dash fuse box which is another accessory source.
FS: Ignition Wires ( Leads ) Phase 2 440 Injectors ronin_hungary Engine/Power/Exhaust 9 12-23-2009 09:52 AM
T/C ignition leads (+6") subaru legacy turbo Subaru Conversions 0 01-14-2008 09:20 PM
Leak leads to water. Water leads to mold, and mold leads to suffering pilfflip Legacy Forum 10 06-15-2006 12:47 AM
Ignition switched lead, a little help makanai Car Audio, Video & Security 2 01-01-2006 08:00 PM
