10-19-2005, 03:31 AM | #1 |
Member#: 24358
SCIC
Vehicle:I miss boost... |
Another AP question...can u help?
(Just for the record my flame suit is already on...)
I finally got my ap today and like a kid, i had to do it right when i got off of work. Anyway, the install went fine, and everything seems ok. I'm just about to go out for a test drive but i'm confused between the two kinds of maps...can someone put it into AP UBER-NoOB terminology? Basically, i know there are two kinds of maps...i just don't see the difference? I'm looking to run stage 2 all the time, so would i have the stage 2 map set as my "default" and maps like "economy" and "anti-theft" are the temporary maps? Thanks guys ahead of time...i know the answers are out there, and i'm hoping someone can be a pal and lend a hand.
10-19-2005, 04:12 AM | #2 |
Member#: 75122
SCIC
Vehicle:2005 Impreza WRX Wag White |
There are Base Maps and Realtime Maps. The base map is just that, the base. It is the "Default map" and you should use the proper base map for what modifications you have. The other maps such as "anti-theft" and "econo" are used as realtime maps. Realtime maps are maps that you can switch back and forth. They will remain on your ecu even if you turn off the car. The only way to change or get rid of what a realtime map changes is if you choose another realtime map to replace it or reset the ECU. When you reset the ECU, it will go back to the Basemap you put on.
In each Base map, there are sub-maps. Sub-maps that control timing, fuel, boost, Wastegate, etc. Base maps have both on the fly sub-maps and static sub-maps. When you use your accessport and change a realtime map, it will alter only the "on the fly" sub-maps of the base map. Those are the differences between realtime and base. Hope that isnt too confusing. Peter |
10-19-2005, 06:18 PM | #3 |
Member#: 58926
SWIC
Vehicle:2013 WRX 5dr ISM 2011 Infiniti EX35 |
G-d d-mn it. I'm a Radioplogic Technologist, CT, MRI, all that stuff, no dummy, but I still don't get it.
I can load Stage 1 as a base OR real time map? What would the difference be? |
10-19-2005, 06:49 PM | #4 |
Member#: 1871
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
Basemaps are "flashed" or loaded into the ECU permanently. Flashing is a slow process. The advantage is that anything the ECU does can potentially be altered with a basemap. What is actually altered depends on the particular map.
Realtime maps are loaded into the ECU and this happens very quickly. Many of the important tables(or sub-maps as previously refered to) can be altered in realtime. So a particular stage can be loaded as either a realtime map or a base map, assuming the tuner provides the map in both formats. There are items, such as CEL's, that are not altered in realtime, but these things tend to be less urgent. The direct advantage for AP users is that realtime maps can be changed infinitely and quickly. Another advantage that the Realtime technology allows is that a tuner can quickly dial in their tunes w/o having to continually stop the dyno(or the car, if tuning on the street), turn the car off, hook up the init connectors, flash the changes(which can be slow), disconnect the init connectors, restart the car, and test the changes. Realtime allows the tuners changes to be instant and ultimately the tunes become more precise. |
10-19-2005, 09:22 PM | #5 |
Member#: 75122
SCIC
Ill put it this way. Each map, base or realtime, consists of submaps that control specific things. If you have a "stage 1" car, load the "stage 1" basemap. The basemap can control more functions of your ECU than the realtime map.
Lets say you have a stock base map on your car and the stock map has 20 functions, controling things like A/F, timing, boost, etc. when you load a realtime "stage 1" map, it will only alter 10 of the 20 maps. When you change base maps from stock to "stage 1", you alter 20 of the 20 maps. Some maps can only be altered through changing base maps. It does get confusing. |
10-19-2005, 10:28 PM | #6 | |
Member#: 58926
SWIC
10-19-2005, 10:35 PM | #7 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
You've got it.
the '100 reflash' thing only related to basemaps. So you have 50 chances to bring in your car to the dealer . |
10-20-2005, 08:45 AM | #8 |
Member#: 67080
The 100 flash limit is a spec limit by the ecu manufacturer. It basically states that they will guarantee the ecu can be flashed 100 times and still work properly. After 100 they do not guarantee anything. That being said, there are people out there with over 100 flashes.
10-20-2005, 11:42 AM | #9 | |
Member#: 39937
Vehicle:2011 328i 6MT LMB |
I run stage 1, and I leave my base map alone. Reflashing ecu is not as fail safe as it should be, and I've seen some people that had technical glitches during the reflash that caused the car to not start, etc. Better not mess with it too often. |
10-20-2005, 12:48 PM | #10 |
Member#: 80204
Vehicle:2017 WRX Limited Ice Silver |
I run stg 2, and I've had my car in to the dealer 2 or 3 times for various things (oil change, scheduled maintenance, inspection) and no one has checked if I flashed my ECU.
It's been discussed ad nauseum on here, but unless they are really looking for specific data on your ECU (i.e. checksum) or you didn't set the right ECU identifier (5MT vs. 5AT) in the AccessPort, you should be fine. |
10-20-2005, 01:24 PM | #11 | |
Member#: 79394
Vehicle:02 gda wrb |
as long as you don't do some stupid s**t like turn the car off or pull the chord out while it's flashing the ecu won't be damaged... don't worry about killing your ecu just follow the directions and you will be straight |
10-20-2005, 03:34 PM | #12 |
Member#: 75122
SCIC
I play around with tuning often and reflash the ECU almost once a week. People that have technical glitches just use that as an excuse. the majority of glitches are not technical, its human. But of course, there are technical glitches once in a while.
10-22-2005, 04:27 PM | #13 |
Member#: 74034
South East
Vehicle:2004 426whp 403wtq Top Speed Tuned STi! |
I have a question on my new AP, I am running normal Stage 2 93 oct, would hwg, or lwg offer me more boost or hp? Also can you get a Stage 2 map with race gas, with out paying a tunner for it?
10-22-2005, 07:06 PM | #14 |
Member#: 77483
NWIC
1) Are you hitting target boost for that map (16psi +/- .5psi)? If so, no need for the HWG map - it wont do anything for you.
2) No. |
10-22-2005, 07:56 PM | #15 | |
Member#: 74034
South East
10-22-2005, 09:05 PM | #16 |
Member#: 54203
NESIC
google says (you ppl really need to learn how to use the interweb... :-) )
1.15 bar = 16.6793398 pounds per square inch |
10-22-2005, 09:18 PM | #17 |
Member#: 74034
South East
I hooked up the AP to read live boost and I am getting 18 psi wow??? It did taper down some around 5k or 6k though. Is something wrong or will it running higher hurt any thing, really?
10-22-2005, 10:09 PM | #18 | |
Member#: 77483
NWIC
See all these questions are valid, but useless without anykind of useful datalogging about the car is ACTUALLY doing. 1.15bar is perfect. |
10-23-2005, 12:10 AM | #19 | |
Member#: 79498
SWIC
Vehicle:2020 XV |
10-23-2005, 06:30 AM | #20 |
Member#: 24358
SCIC
...also, i have a friend w/ an sti that's running a fmic on a stage 2...is this a good idea? I'm looking to be the most effecient i can be and i'm debating if i shouldn't just sell the sti tmic i bought and buy a fmic instead...i just don't wanna have to lose my jdm fogs.
10-23-2005, 01:07 PM | #21 |
Member#: 75122
SCIC
Stage 2 has no need for a FMIC and is not efficient with one. Keep the STi TMIC for its a pretty good one and still ok to use with the AP. You shouldnt need to go Front mount unless you get a bigger turbo. And your friend with the front mount on stage 2 is going to loose a bit of boost.
10-23-2005, 02:01 PM | #22 | |
Member#: 74034
South East
10-24-2005, 01:29 AM | #23 | |
Member#: 79498
SWIC
Vehicle:2020 XV |
What mods do you have? What adjustments have you made? Did you buy it used? Personally, I'd worry about overboosting like that, or at least I'd like to know what's causing it. If you're running a stock turbo Stg. 2 map and you get on it, watching the AP boost reading, and it goes over 17....well, that's just not right and it's probably mechanical, maybe the wastegate actuator is TOO tight, but it's definately something. |
10-24-2005, 04:37 AM | #24 |
Member#: 24358
SCIC
after my gauges and ap stage 2 went in, i took her out to pop her cherry...only problem is, i can't get it to boost higher than 0.8 kg/cm^2.
...and if my math is correct, that equates to a measily 11.3784 psi. I don't know what the deal is, but my car felt faster before the ap. Is there a specific time it needs to "learn" the new settings? Thanks in advance...i'm new to the world of ap. Oh, does this mean i'll need to go to the riskier map that cobb has??? BTW, i'm in cali so gas is piss-poor. |
10-24-2005, 10:57 AM | #25 | |
Member#: 74034
South East
-UniFilter Rampod Intake -Full 3" TBE (catless) -Eng. Ground kit (not really a mod though) -AP Stage 2 93oct base map Adjustments none really to date, did clear out ECU codes and raised the oct to 99oct, to prevent knock. Did some more driving and hasn't yet happened again. I am thinking it's the intake flowing too much air, just a guess though? I bought the AP brand new 4 days ago. I do have a 1/4 mile race with a co-worker on Friday, do you think with the present set-up (high boosting) I am getting now; and if the eng. doesn't cut out on me, I will have a better 1/4 time??? |
Another AP question | JayPope | Newbies & FAQs | 2 | 01-17-2010 09:30 PM |
another ap question | SEEK | AccessPort | 14 | 11-18-2008 05:23 PM |
And yet..... ANOTHER AP question :) | Skin Irritant | Newbies & FAQs | 27 | 01-25-2008 12:59 PM |
Another AP question. | G3Red04WRX | Engine Management & Tuning | 4 | 11-09-2005 10:44 PM |
gawd,,,another AP question,,, | mistaare | Engine Management & Tuning | 2 | 06-09-2005 12:02 PM |
