Old 10-19-2005, 07:44 AM   #1
legtune
Member#: 98930
Default map sensor codes
on my 98 legacy I have installed a wrx turbo and front mounted intercooller.
I am looking for a way to get rid of the map sensor code, wich is set everytime the car goes into boost. Are there any aftermarket computer enhancements that can change the stock settings.
legtune is offline   Reply With Quote
Old 10-19-2005, 06:17 PM   #2
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
yeah you can get a voltage clamp. rallitek sold me an avo voltage clamp awhile ago and i dont need it. pm me and ill sell it to you for $20. i would double check that it will work on your car though. its an a.v.o. voltage clamp. let me know. it will clamp the voltage so that boost does not cause a CEL.
darioc is offline   Reply With Quote
Old 10-19-2005, 07:03 PM   #3
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
You bolted on a turbo to a MAP-based EJ25 and didn't know to use a voltage clamp? It's not just a CEL. Without a clamp, your ECU is going to cut fuel if it sees too much boost.
E-Manage has a voltage clamp built in.
-Brett
ExecNav is offline   Reply With Quote
Old 10-19-2005, 08:30 PM   #4
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
As far as i know the 98 legacies are all MAF based- maybe it's throwing a different code?
Drac9 is offline   Reply With Quote
Old 10-19-2005, 08:43 PM   #5
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
nope - I can tell you for sure that my 99RS throws map sensor codes. There is a map sensor - and I have seen accurate reads up to 9psi on it through SSM logging of the ECU.
Hitokiri is offline   Reply With Quote
Old 10-19-2005, 09:06 PM   #6
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
What I was wondering.
Tod
todnar is offline   Reply With Quote
Old 10-19-2005, 10:18 PM   #7
Drac9
Member#: 9861
Weird- where is the map sensor? my 99RS does not have one. It had a barometric pressure sensor on the shock tower, but no map sensor.
Old 10-24-2005, 10:14 AM   #8
legtune
Member#: 98930
my legacy has both a maf and a map. I am running 9.5psi. everything runs fine. I installed a sti fuel pump. I rigged the fuel so when I hit 4 psi the pump runs at 80 psi.
The check engine light comming on is what is driving me nuts.
Old 10-24-2005, 10:46 AM   #9
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Here's Proof. Manifold Reletive Pressure is the far right columb. This is off my 99RS with a ~11.0 AFR tune at ~5psi - keep in mind that the IDC on boost is alittle less than what you see due to the Emanage ultimate, and the timing is about -5 under boost. I was surprised to see how much timing my stock ecu runs.
Code:
(RPM) AFRlearn1(%) AFRCorr1 (%)	MAF(g/s) IGN(BTDC) Knk(BTDC) injduty (%) MAF(V) MRP (PSI)
2816	3.13	0.78	57.23	39	0	9.01	2.16	-9.431
2814	3.13	3.13	59.38	39	0	9.61	2.2	-9.286
2821	1.56	5.47	61.16	39	0	9.63	2.22	-9.141
2840	1.56	1.56	65.25	38	0	10.3	2.26	-8.996
2845	1.56	3.91	68.42	38	0	10.92	2.34	-8.561
2844	2.34	6.25	72.16	38	0	12.13	2.36	-8.271
2871	2.34	5.47	76.11	37	0	12.86	2.42	-8.125
2885	2.34	4.69	78.97	37	0	12.92	2.44	-7.835
2908	1.56	3.13	92.97	35	0	14.89	2.68	-7.4
2933	-1.56	7.81	110.08	32	0	17.52	2.72	-6.529
2955	-1.56	6.25	114.17	32	0	17.65	2.76	-5.949
2993	-1.56	4.69	113.39	32	0	17.24	2.72	-5.659
3005	-0.78	3.13	108.67	33	0	16.03	2.58	-5.804
3034	1.56	2.34	81.89	36	0	12.3	2.34	-6.82
3039	3.13	0.78	68.27	38	0	10.37	2.3	-7.835
3060	3.13	-0.78	68.42	39	0	10.44	2.3	-8.416
3061	3.13	-2.34	68.81	39	0	10.45	2.28	-8.561
3079	3.13	-3.91	70.54	38	0	10.51	2.32	-8.561
3085	3.13	-4.69	71.66	38	0	10.53	2.34	-8.561
3109	1.56	0.78	115.36	35	0	17.91	2.94	-7.98
3158	-3.13	3.13	176.22	27	0	27.62	3.3	-5.804
3208	0	0	230.99	22	0	34.9	3.46	-2.612
3274	0	0	255.94	20	0	43.3	3.54	0
3356	0	0	291.72	20	0	50.82	3.68	1.886
3436	0	0	324.06	19	0	56.43	3.84	3.337
3524	0	0	341.82	19	0	59.4	3.84	4.788
3632	0	0	348.41	20	0	60.43	3.88	5.224
3715	0	0	352.1	21	0	61.02	3.88	5.224
3830	0	0	369.1	22	0	63.74	3.92	5.224
3923	0	0	373.15	23	0	64.43	3.96	5.224
4021	0	0	387.72	24	0	66.91	3.98	5.224
4121	0	0	390.86	23	-1	67.69	4.02	5.224
4204	0	0	402.75	24	-1	69.95	4.06	5.224
4300	0	0	416.56	25	-1	72.47	4.1	5.224
4396	0	0	429.6	25	-1	74.09	4.1	5.224
4510	0	0	443.82	27	-1	77.93	4.16	5.224
4607	0	0	451.3	29	-1	78.62	4.18	5.224
4711	0	0	453.17	30	-1	79.4	4.18	5.224
4792	0	0	451.99	31	-1	79.74	4.18	5.224
4902	0	0	453.18	32	0	80.52	4.2	5.224
4993	0	0	452.81	31	0	80.96	4.18	5.224
5092	0	0	453.9	31	0	81.46	4.16	5.224
5187	0	0	454.03	31	0	80.77	4.18	5.224
5285	0	0	452.74	32	0	81.18	4.18	5.224
5372	0	0	453.24	32	0	82.52	4.2	5.224
5435	0	0	377.77	32	0	68.41	2.42	4.063
4915	0	-2.34	91.64	20	0	1.05	1.88	-1.161
4690	0	-2.34	61.99	20	0	1	1.9	-5.224
4363	0	0	96.61	42	0	16.75	2.96	-7.69
4101	0	0	192.59	32	0	30.62	3.24	-6.675
4101	0	0	202.8	31	0	31.49	3.3	-5.078
4092	0	0	203.87	31	0	31.42	3.3	-4.498
4119	0	0	201.9	31	0	30.75	3.3	-4.353
4160	0	0	233.5	29	0	36.38	3.6	-3.918
4188	0	0	361.31	24	0	63.43	4	-1.161
4228	0	0	397.55	24	0	71.25	4.06	2.467
4293	0	0	418.1	24	0	74.18	4.1	4.643
4358	0	0	424.73	24	0	74.37	4.08	5.224
4381	0	0	426.61	24	0	74.76	4.1	5.224
4435	0	0	424.79	25	0	73.8	4.12	5.224
4513	0	0	436.86	27	0	77.01	4.16	5.078
4529	0	0	439.22	27	0	77.29	4.16	4.933
4596	0	0	451.41	28	0	79.41	4.2	5.078
4653	0	0	451.61	29	0	79.4	4.2	5.224
4699	0	0	453.66	30	0	79.19	4.18	5.224
4765	0	0	451.27	31	0	79.29	4.2	5.224
4805	0	0	453.29	32	0	79.95	4.18	5.078
4870	0	0	452.54	32	0	80	4.2	5.224
4902	0	0	449.88	32	0	79.47	4.2	5.224
4960	0	0	453.85	31	0	80.42	4.18	5.224
5000	0	0	451.19	32	0	80	4.2	5.224
5061	0	0	454.59	31	0	80.97	4.2	5.224
5119	0	0	453.35	32	0	80.82	4.2	5.224
5144	0	0	454.69	31	0	81.21	4.18	5.224
5201	0	0	454.19	32	0	82.11	4.2	5.224
5259	0	0	452.57	32	0	81.9	4.2	5.224
5293	0	0	453.52	32	0	82.43	4.2	5.224
5350	0	0	451.2	32	0	82.17	4.2	5.224
5384	0	0	454.56	32	0	82.7	4.2	5.224
5435	0	0	451.8	33	0	82.32	4.2	5.224
5466	0	0	454.94	33	0	82.8	4.18	5.224
5315	0	0	203.81	20	0	1.13	2.34	3.337
4896	0.78	-2.34	75.05	20	0	1.04	2.4	-2.176
4685	0	-2.34	54.84	20	0	1	2.68	-5.659
FS: Cobb MAP sensor adapter and Zeitronix 3.5 bar MAP sensor crashnscar Engine/Power/Exhaust 5 12-12-2010 06:54 PM
FS (OH): WRX/STi rear o2 sensor, MAF sensor, MAP sensor coolblue05 Engine/Power/Exhaust 14 07-07-2009 02:52 PM
P0108 MAP sensor CEL code???? willeverk Newbies & FAQs 0 09-30-2007 01:40 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Engine Management & Tuning 2 07-05-2006 10:50 AM
Crankshaft Position Sensor Air Intake Temp Sensor CODES!! please Help!! GT40R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-02-2006 05:07 PM
