Old 10-19-2005, 08:12 AM   #1
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
Default Some different intercooler options...
Im buying an L impreza and swaping in an EJ20G. Ive been doing a bit of research but have been getting some conflicting information.
When I put in the new engine, I will need a scoop to get air to the intercooler (obviously). I was looking at some carbon fiber hoods, or some aluminum hoods. Another option I considered was getting a FMIC and turning the boost up on the TD05 to around 21 psi. I thought I could do this second option without a problem and it seemed like the better choice money/power ratio. Now Im having difficulties figuring out the fuel injectors... I thought the 450cc would be enough, then I heard that even 550 wouldnt be enough... Trying to get a "third party" opinion... any help?
WallyKincaid is offline   Reply With Quote
Old 10-19-2005, 09:36 AM   #2
99WRXEJ20
Member#: 34545
1999 GC8
74f
What kinda EM you plan on using? and I belive 550s should be enough.
99WRXEJ20 is offline   Reply With Quote
Old 10-19-2005, 09:52 AM   #3
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
Using stock JDM wiring harness. no aftermarket is required (as far as I know).
Old 10-19-2005, 11:51 AM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
the stock 425/440 (conflicting) is not enough to run 21 psi .. maybe 15ish
550 are fine i am using usdm STI injectors in a modified 1.8 rail but you will need some sort of EM to compensate for the bigger squirters (and less advance?) i am still at 15 on the stock crooked intercooler (w/ a tec2)
Old 10-19-2005, 12:01 PM   #5
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
This is all getting complicated again haha.... maybe Ill just buy the hood and run normal boost
Old 10-19-2005, 05:46 PM   #6
99WRXEJ20
Member#: 34545
1999 GC8
74f
and the stock boost sensor can only read up to 17psi. So you would need some sort of EM or a Fuel cut defenser w/ boost controller.
intercooling options j3t Pre-2002 Factory Turbo Powertrain 45 04-07-2009 10:24 AM
intercooler options WRX34 Subaru Conversions 0 10-27-2005 10:12 PM
Intercooler options?? AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 8 06-30-2004 02:34 AM
Intercooler options... pfhlipwrx Factory 2.0L Turbo Powertrain 5 01-14-2004 12:39 PM
intercooler options? Red RS Normally Aspirated with bolt-on Forced Induction Powertrain 14 10-25-2001 11:05 AM
Message Board Statistics All times are GMT -4. The time now is 10:51 AM.
