Old 10-19-2005, 11:14 AM   #1
Jric
Member#: 84167
2005 Outback wagon
Default blowing headlights
My '05 Outback has gone through 2 left and 1 right headlights in the last 12 months (34,000 miles). Now I'm told it's because I keep the tire pressure at 40 psi (max tire pressure rated at 44 psi), rather than the recomended 30 psi and the increased "jolting" from the highway is causing the premature failure. Any other thoughts on the cause for this? If I reduce the tire pressure by the 25% recommeded, it will surely hurt my mileage. Are there some tougher after market bulbs such as used in racing that might fix this issue?
Jric is offline   Reply With Quote
Old 10-19-2005, 12:00 PM   #2
Yotsuya
Member#: 935
Jack Soo Fan Club
They're FOS; the tire is well within its inflation limits and shold not be the problem. You can try some different brand bulbs, but having three go is not a good sign unless they all came from the same maker and stock number. Then *maybe* you have a bad batch of bulbs.
Going through multiple bulbs that fast probably means there's some kind of electrical problem. There may be a flaw in the electrical line that's causing a surge or spike that's overloading the bulbs. You could have had a run of three bad bulbs, but that's not as likely as one flaw in the electrics. The dealer sounds unable/unwilling to test the current, and even if they do may not be able to recreate what may be your problem, as a surge could be the result of a particular jounce or other.
If the dealer won't do anything and you don't have any equipment at home, you may want to try disconnecting the daytime running lights (though I can't remember if Outbacks have them) which will reduce the amount of time the bulb is on. It's not an ideal fix, or even an acceptable one depending on your temperment, but it may be what you need to keep from replacing bulbs too often.
Yotsuya is offline   Reply With Quote
Old 10-19-2005, 01:03 PM   #3
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
tires are not the problem....they are FOS.....i cant believe a dealer would tell someone that. thats like telling a cop i was not speeding it was because the mirrors are aimed at the wrong angle so it "seemed" like i was speeding i have had stints with a bad batch of bulbs for a while i went through 4 sets in the span of about 2 weeks...then i got a set of yellowstars and havent changed them in about a year.
ATX25RS is offline   Reply With Quote
Old 10-19-2005, 01:23 PM   #4
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
^^What they said. Also, are you being EXTREMELY careful not to touch the bulb or let it touch the housing when you install it? Fingerprints or a bit of dirt will cause them to pop very rapidly. You may also check inside you housings and make sure there's no condensation.
bushflyr is offline   Reply With Quote
Old 10-19-2005, 02:23 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Since it's an 05 the dealer should be replacing those bulbs under warranty. I don't see how they can get away with blaming your tire pressure, although 40 psi is a bit high IMO.
You should not have to do any checking on the car yourself at this stage, however if you're so inclined try measuring the system voltage at the battery with a multimeter. If it's on the high side (15V or higher) that could explain the bulb failures.
Old 10-19-2005, 03:20 PM   #6
ATX25RS
Member#: 4597
ditto on the tire pressure.....i would only go that high if i was autoxing or something....and even then....
H1's are very fragile bulbs, but they are not that fragile.....do you always drive on the highway or something? i live in a city that does not know what "street repair" means so i drive on a lot rougher surface than the highway, but would never imagine that is why bulbs would go out.
Old 10-19-2005, 04:11 PM   #7
Jric
Member#: 84167
2005 Outback wagon
Thanks for the replies so far. All 34k+ miles are well maintained highway miles. Under warranty the dealer has been replacing the bulbs but my warranty is almost up (3/36). It's kind of a hassle to go blow an hour and a half to go out of my way to have these replaced. Under the law however isn't the dealer obliged to continue to address this after warranty. They say they will cover an individual bulb for upto 12 months of replacement. Sounds like some of you think the electrical system should be checked?
Old 10-19-2005, 04:16 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Frequent bulb failures with no other apparent reason can be the result of a faulty voltage regulator which allows the electrical system to operate above the safe voltage range of 13.5-14.5 V. This is certainly something the dealer should be looking at as a warranty item rather than just blaming your tire pressures. Should the regulator turn out to be NG, the alternator will have to be replaced since the regulator is an integral component.
FS : MA: 93-96 Headlights and grill voteforpedro18 1993 - 2001 Impreza Specific Parts 12 08-16-2010 11:54 AM
Headlight and foglight bulbs keep blowing out!! Blizwinter Interior & Exterior Modification 7 07-29-2004 01:26 PM
I keep blowing headlight bulbs Aaron'z 2.5RS Electrical & Lighting 13 02-26-2004 07:01 PM
STI headlights blowing fuse ATLscooby Interior & Exterior Modification 5 10-27-2002 09:58 PM
Am I alone in thinking that the New Style headlights blow the Olds out of the water? Ethon Member's Car Gallery 35 10-14-2002 03:11 PM
