Old 10-19-2005, 03:11 PM   #1
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Default Will an 04 OEM HID setup fit on my 03 JDM Projector headlights?
I have JDM (actually EDM but same difference) projector headlights currently fitted with an H1 HID kit which I am looking to replace. I am wondering here if a US OEM 2004 HID kit will fit right onto my projector headlights without modificaiton.
I am mostly concerned with bulb fitment since the OEM HID setup actually has a base at the bottom of the bulb versus my current setup which just has 2 wires running off the back of it. I am also wondering if the ballast would bolt right up to the back of my headlights, keeping it looking very clean.
I realize that the 04s have D2R bulbs and mine would normally take D2S bulbs, but from what I have read they should work fine. Additionally, I actually have a spare set of OEM D2S bulbs sitting here that I can use if it is a problem.
Thanks in advance!! Hopefully this will work out.
Bryan
Wrinkleboi is offline   Reply With Quote
Old 10-19-2005, 03:19 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
No, this won't work. Your EDM projectors require H1 bulbs, and any aftermarket HID setup such as you already have will use "rebased" HID bulbs on H1 bases. OEM type D2x bulbs will not fit into your housings.
Old 10-19-2005, 03:22 PM   #3
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
i was under the assumtion that my EDM lights used the same exact housing as the JDM lights with HIDs, and the aftermarket H1 bulbs only fit because of an adapter that is screwed onto the headlight where the bulb fits to.
i guess thats not right?
i believe you, thanks for the info. oh well, so much for an inexpensive OEM HID kit...
bryan
Old 10-19-2005, 03:29 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
I don't believe that is the case. AFAIK the projector units for HID and halogen are completely different. The internal optics certainly are, you're not getting the same lighting performance with a retrofit on halogens vs. OEM HIDs.
Old 10-19-2005, 03:32 PM   #5
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
so my HIDs in current state arent as bright as OEM ones? i knew that reflector housings were different but i figured my projectors were the same... hmph. oh well i still love my LHD beam pattern...
thanks for the info...
bryan
Old 10-19-2005, 03:39 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Projectors or reflectors, the optics are different to accomodate the output level and dispersion patterns of HIDs or halogens. You'll never get the same results with a retrofit as with the "real thing", however projector retrofits are usually far more acceptable than reflector ones.
Old 10-19-2005, 03:42 PM   #7
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
oh ok, i never really thought of what i have as a retrofit until now. i always pictured a retrofit as a hackjob, but i guess its any headlight designed for halogens that now has HIDs.
thanks for the good info...
bryan
Old 10-19-2005, 04:55 PM   #8
alpinev12
Member#: 90186
2006 Impreza WRX Ltd
2011 Audi S4
bryan
Hey what's up Wrinkleboi...I'm having a H7 kit installed on my '06 this Sat. I'm very curious myself how this will compare with OEM and a bit concerned with glare. I noticed you live in Langhorne...that's where I picked up my ride last month at Reedman-Toll. You're not too far from me as I'm in the Montgomeryville/North Wales area.
Rick B.
alpinev12 is offline   Reply With Quote
Will an 04 STI Intake Manifold fit 03 wrx EJ205? simon930 Built Motor Discussion 7 12-03-2009 10:23 PM
Will an 04-07 STI catback fit on 02 wrx? NavyBlueSubaru Factory 2.0L Turbo Powertrain 2 02-17-2008 07:18 PM
will a 04+ WRX Prodrive Spring fit on my car? GD6Noob Normally Aspirated Powertrain 12 04-21-2007 09:35 PM
pictures of my RHD JDM projector headlight with HID etam Legacy Forum 12 03-11-2004 09:28 PM
WTB: 02-03 JDM Projector Headlights dwnhillskater Private 'Wanted' Classifieds 3 01-02-2004 08:18 PM
Message Board Statistics All times are GMT -4. The time now is 12:23 AM.
